 Old 06-01-2010, 11:52 AM   #1
TheNewGuy's Avatar
Posts: 144   (View Stats)
TheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond reputeTheNewGuy has a reputation beyond repute
Default Proper wastegate?
Which wastegate would you suggest for a GT3071r setup? what sizing is proper? what factor determines the size? sorry im not very adverse with wastegate knowledge, all i know is that they are of the most important parts of a turbo system but also most commonly overlooked...id like to learn about wastegates for the ms6 and the turbo setups so anyone who wants to share what they know please do so.
-Grant
Mazdaspeed6
I work stock evo's like its my job.
I make yellow lights my Bitch.
Mods: gt3076r
TheNewGuy is offline   Reply With Quote
 Old 06-15-2010, 07:35 AM   #2
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
im not BT myself, but you should be able to search this i believe
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 06-15-2010, 06:07 PM   #3
TheNewGuy's Avatar
yeah i did i was just trying to get an answer quicker haha
Mazdaspeed6
Mods: gt3076r
 Old 06-15-2010, 06:10 PM   #4
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
38mm Tial V band
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
The Following 3 Users Say Thank You to BrianZX10R For This Useful Post:
danesti (06-15-2010), nighthawk358 (11-04-2010), spiker98 (11-08-2010)
 Old 06-15-2010, 06:11 PM   #5
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
listen to brian. i ran a 44mm... didnt hurt anything, just didnt need to have a WG that big.
your next question... which spring? i suck with that so im no help
2008 STi
Intake
Turboback
AP
 Old 06-15-2010, 06:17 PM   #6
BrianZX10R's Avatar
Groans: 88
depends on how much boost u plan on running and how u wanna control it. I personally just wanted to run spring pressure so i ran a 20 psi spring for constant 20psi. if u will have some sort of boost control get a spring the same or a few PSI less then the least amount of boost u wanna run, and up it with the boost controller to your desired setting
2007 Kawasaki ZX10r
 Old 11-04-2010, 09:04 AM   #7
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
Sorry to wake up an old thread but when you are running on just spring pressure do you just bypass the wastegate actuator?
When using the wastegate actuator you get a spring for your min boost then use a boost controller to set it to a higher target?
What is the stock Wastegate spring set to anyway? I'm guessing it is around 10 psi (where stock boost is limited to in first and second gear).
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline   Reply With Quote
 Old 11-07-2010, 10:10 PM   #8
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
yup you're exactly right. stock spring 12lbs
 Old 11-08-2010, 07:08 AM   #9
RichB's Avatar
Yea, I was looking at how the stock wastegate is plumbed and it makes a lot more sense now.
What are the pros and cons of doing straight spring pressure?
If I was doing a custom set-up I'd probably tune to 18 PSI and get a 15 PSI spring in the wastegate but I never thought about straight spring pressure. Which route is the better way?
How to connect the stock wastegate solenoid to an external wastegate cageyvet MazdaSpeed 3/6 - Turbo Induction 0 03-17-2010 05:02 PM
proper re-worked break-in k0m Mazdaspeed3/6 General Discussion 14 01-18-2009 07:03 AM
What is proper AFR for MS3? Matrix311 MazdaSpeed 3/6 - ECU Computer Tuning 13 12-08-2008 10:06 AM
Page generated in 0.29837 seconds with 25 queries
