 Old 05-19-2008, 02:14 PM   #1
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
Default prosport electrical boost gauge install??
anyone have a good how to?? the directions that came with it are pointlesssssss
thanks guys
bombdotcom is offline   Reply With Quote
 Old 05-19-2008, 02:55 PM   #2
javanc's Avatar
Posts: 423   (View Stats)
javanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the worldjavanc is the leader of the world
Just some hints as i can remember from my install. Use "add a circuits" from autozone. They plug into a fuse port allowing you to tap into the circuit. Buy 3. Plug into the "tailights" for the white at night look, or if you want all red then dont plug the white in at all. Plug white into "taillight", red into "doorlock" and the orange into "ig. sig" and the black into the ground that is on the far left where the foot rest/ dead pedal is. Take off the plastic kick panel and see the already grounded wires there. Put a spade on your ground and slip it under the ground bolt that is already there.
Then run all your wires over to the pass. side fuse block, make sure you label them and then butt splice your wires to the add-a-circuits.
Then run the supplied cable from the supplied boost sensor thru the firewall where the hood release cable goes thru. I recoomend using a coat hanger pushed thru from the engine side, tape the wire to it real good and pull it into the engine bay.
Take the top of the steering column trim off by gently pulling it up at its corners. This will allow you to see so that you can pull your wires up to the steering column where your gauge is attached. I reccomend the coat hanger again with tape to help pull the wires up.
I know its a very disorganized how to but its all i could do in the 10 minutes i had to write.
javanc is offline   Reply With Quote
The Following User Says Thank You to javanc For This Useful Post:
tbear2001 (06-07-2010)
 Old 05-19-2008, 04:28 PM   #3
bombdotcom's Avatar
thanks so much man. i have the amber gauge, so plug it into the tail light? ya i need run and buy some supplys, do u reccomend buyina brass tee fitting?? and as far as when u tap into the vacuum line,so u just buy a new hose?
 Old 05-19-2008, 04:42 PM   #4
You could get brass, but i would just get the plastic tee instead... less weight.
You will need a little piece of vac line depending on where you mount the sensor.
I tee'd off the BPV vac line.
 Old 05-19-2008, 05:09 PM   #5
digitaljedi's Avatar
Posts: 1,222   (View Stats)
digitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the world
Groaned at 51 Times in 34 Posts
i teed off the same spot, best place imho. i have the redish light, looks best, almost matches the stock speedo lighting, except for the purple back light, i wish it matchedperfectly but oh well.
2008 speed3- FOR SALE!!!!!!!!!!!!!!!!!! SEE HERE!
http://www.mazdaspeedforum.org/forum/forum/f665/2008-speed-3-sale-177096/
2000 Honda S2000(track car)
digitaljedi is offline   Reply With Quote
 Old 05-20-2008, 06:38 AM   #6
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
i would buy new vacuum tubing. I used the stuff that came with it and I think it looks like crap. I bought 10 feet of it when I bought the Tee's for my synapse install so I will be redoing the gauge tubing then also.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 07-25-2008, 01:19 AM   #7
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
I just installed my Prosport Electrical Boost Gauge and the Automatic headlight sensor stopped working and I dont know why..Its in auto and its at night and the headlights dont turn on. I used the Add a circuits and used Ig Sig for Orange and Red (did not use the white). Tomorrow Im going to check everything again and Im going to plug the Red in a Constant. Can anyone tell me what went wrong?
nighthawk358 is offline   Reply With Quote
 Old 07-25-2008, 01:37 AM   #8
Did you check to see if it blew the fuse?
 Old 07-25-2008, 01:53 AM   #9
Miembro
Groans: 27
I dont think so..the gauge works fine but the auto just doesnt work. Which fuse should I check if it stopped working? Sorry for the stupid question, I just want to make sure.
 Old 07-25-2008, 01:55 AM   #10
Miembro
Groans: 27
Thanks for the Fast reply. I love this forum hehe
 Old 07-25-2008, 07:06 AM   #11
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
download my write-up here: StreetUnitForum.com
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 07-25-2008, 09:13 AM   #12
pidass's Avatar
Posts: 347   (View Stats)
pidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the worldpidass is the leader of the world
weird, the only issue i have with the auto-lights is that I have my guage set for white during the day and red when the lights come on.
The problem is there is some kind of delay with the auto-lights so if I turned on the car when it's dark (which I did a lot when I worked my last job). The gauge would stay white and not switch back to red.
I've gotten a relay a member of m3f suggested would fix the issue but have yet to hook it up. Anyone else worked around this?
07 MS3 GT w/Nav + Mods
pidass is offline   Reply With Quote
 Old 08-10-2013, 01:38 PM   #13
2con's Avatar
Posts: 16   (View Stats)
2con is an unknown quantity at this point
I am having the same issue. Another member suggested wiring a capacitors in but cannot find the right one. Which relay did he suggest using?
2con is offline   Reply With Quote
 Old 08-10-2013, 02:16 PM   #14
KusteLokal's Avatar
Posts: 2,664   (View Stats)
KusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the world
Groans: 124
Really? Bumping a 5 year old thread?
Tappin from S3
1995 Miata 1.8
2006 MS6 Sold
KusteLokal is offline   Reply With Quote
The Following User Says Thank You to KusteLokal For This Useful Post:
Don06speed6 (08-10-2013)
 Old 12-19-2013, 02:57 PM   #15
Abnmarine's Avatar
Posts: 20   (View Stats)
Abnmarine is on a distinguished road
Tappin from S3
I guess they could of started a new thread and then get chastised for not doing a search.
2008 MS3 GT Autotech HPFP, Cobb V3, Test Pipe, FMIC, NGK 1 step colder plugs, JBR RMM, CorkSport SRI/TIP, Short Throw Shifter, Hotchkis Rear Swaybar, Prosport Boost Gauge
Eonon D5151, Alpine F3 Amp, Alpine Type R Components, 10" Bazooka sub, backup camera
ASA AR-1 18 inch rims with Hankook 225/45/ZR-18 tires
Abnmarine is offline   Reply With Quote
 Old 12-19-2013, 03:31 PM   #16
Post whoring a 3 month old, 5 year old thread revival?
2012FailWheelDrive (12-19-2013)
 Old 12-19-2013, 07:18 PM   #17
Abnmarine's Avatar
Not really. Came across this when searching for the install. They can keep my post counts to zero. I don't really care about them.
 Old 12-22-2013, 02:33 PM   #18
Posts: 2,826   (View Stats)
Don't post unless you have something new to add or the question you ask cannot be answered by a search of prior threads. Just dumb ass stupid to resurrect a dead thread without something new to add. A great way to get ignored when you really need help.
General Aftermarket Gauge install wiring trufanatic MazdaSpeed 3 - How-To's 38 04-04-2012 07:26 AM
gauge help det_ms3 MazdaSpeed 3/6 - Turbo Induction 9 05-26-2008 11:45 PM
Page generated in 0.36687 seconds with 32 queries
