![]() | | #41 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score
Forza and I will be the only Stage IIIs out there for a while. Worst case, Bryan's going to make them himself if there's enough demand, but for most... a 2860 wheel is great coming from stock.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
![]() | | #42 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
![]() | | #43 | ![]() |
| Not Ranked : 0 score Has boost creep been tested on the stock turbine housing? I doubt it flows that much better than the ATP one, and possibly even worse.
![]() | | #44 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score can someone cross post those pics from the other site please?
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #45 | ![]() |
| Not Ranked : 0 score It's been tested without issues unlike ATP's notoriously poor design.
![]() | | #46 | ![]() |
![]() Join Date: May 2009
Rep Power: 372 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score on the SST, do you have to run a 3" inlet ?
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
![]() | | #47 | ![]() |
![]() Join Date: Apr 2009 Location: Great White North
Rep Power: 512 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,214
(Thread Starter) | Not Ranked : 0 score From what I've read, they don't support a 3" inlet anymore (Can anyone confirm?). But either way, that implies you have a choice in inlet size....
__________________ Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio. |
![]() | | #48 | ![]() |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score I always wondered which reworked K04 is better? the one from ptp or the one from pg? the pg is 150$ cheaper |
![]() | | #49 | ![]() |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groans: 166
Groaned at 56 Times in 41 Posts
| Not Ranked : 0 score based on the horror stories of waiting months for the simplest things from PG, I would personally pay the extra for the PTP
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
![]() | | #50 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I run the BNR stage 2 turbo and love it , no more smoke , hold boost , stock inlet size option , bolt-on on the exhaust . Expensive yes but , imo it's the best turbo available without forged internals . Everything is new from Garrett except the hot side . Bryan from BNR have a great customers service . I got 287 whp & 312 torque (speed6) at only 18 psi . Turbo is good for 24 psi but i'll keep it at 18 psi . here a picture of the stock K04 VS the BNR stage 2 . bnrsupercars@yahoo.com http://www.mazdaspeedforum.org/forum/foru...1&d=1266764289
__________________ Mazdaspeed6, CP-E dyno 275WHP/255 WT ,BNR turbo ,CP-E intake,CP-E turbo inlet,CP-E flash,CP-E standback,CP-E fuel pump,CP-E mount,Turbosmart bov,Corksport catback,ATP catted downpipe,ETS tmic ,Saikou Michi OCC, Turbinetech mounts,TWM short shifter stage II + bushings + shifter plate ,Aem boost et wideband gauge,Dashhawk,Autoexi tower bar, Apexi turbo timer,Mazdaspeed mags,huiles Amsoil,Fiberimages CF hood & truck ,Speedline CF grill, R1 concept disques de freins,EBC red stuff pads,Hankook tires,Megan racing coilover ,Kicker amplifier . |
| The Following 5 Users Say Thank You to blackwidow For This Useful Post: | 802MS3 (02-21-2010), Alpha (02-21-2010), Blackspeed (02-23-2010), DSIT995 (02-21-2010), Fobio (02-21-2010) |
![]() | | #51 | ![]() |
Also, were you still able to run a stock style TIP as the new inlet looks slightly larger than the stocker?
![]() | | #52 | ![]() |
| Not Ranked : 0 score The turbo spool 750 rpm later but punch harder at the 5000rpm ++ The inlet can be machined down by Bryan for the stock inlet size . I have the CP-E inlet with the stock size and fitment is perfect . Bryan made a nice job . For the outlet i changed the coupler because i have the first batch of turbo but for the next batch Bryan have a new adaptor on it so the stock coupler will fit .
![]() | | #53 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
BNR Turbo+Grimmspeed EBC = Possible Win? I hope
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors | |
![]() | | #54 | ![]() |
| Not Ranked : 0 score No boost creep , Yes i took the stock inlet size ,some little modif on the coolant hose and some little trim on the hot shield on the turbo . Also you will need to move the turbo selenoid on the firewall because it is on the stock turbo so i just screw it on the firewall . Here a picture . http://www.mazdaspeedforum.org/forum/foru...1&d=1266771754
![]() | | #55 | ![]() |
![]() | | #56 | ![]() |
| Not Ranked : 0 score Best choice IMO Good luck !
![]() | | #57 | ![]() |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | |
![]() | | #58 | ![]() |
| Not Ranked : 0 score what is that 1st pic of? Looks like k04 then Gt28? Did they ceramic coat the hotside for u? Bryan didnt really seem like stg3 was an option, but thats ok. I think that stg2 will be fine for my goals. Even though stg3 would be ideal. Thanks for the info
![]() | | #59 | ![]() |
| Not Ranked : 0 score They are stage 1, 2 & 3. The Stage 1 is the OEM housing with a different wheel. You're right, the stage 2 & 3 are GT28 housings. IIRC, the Stage 2 is a 2860 wheel and the stage 3 is a 2871 wheel.
| The Following 2 Users Say Thank You to FORZDA 1 For This Useful Post: | Blackspeed (02-23-2010), DSIT995 (02-21-2010) |
![]() | | #60 | ![]() |
Groans: 166
| Not Ranked : 0 score Will these work with the stock boost control?
![]() | | #61 | ![]() |
| Not Ranked : 0 score Can't confirm through testing, but the word is yes. IMO the OEM BCS is rather fragile and tends to die early when you start running it at high duty cycles. Mine was beginning to leak and stick, so I went ahead with the Perrin 3-port for my OEM turbo in prep for the bigger turbo.
![]() | | #62 | ![]() |
Im sending in my k04 to them(BNR) today. Cant wait!
![]() | | #63 | ![]() |
![]() | | #64 | ![]() |
Groans: 44
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- | |
![]() | | #65 | ![]() |
| Not Ranked : 0 score $1,200 IIRC. A small price to pay considering the ease of installation and lack of EWG necessity.
| The Following User Says Thank You to Alpha For This Useful Post: | Fobio (02-23-2010) |
![]() | | #66 | ![]() |
| Not Ranked : 0 score Here a little datalog on my Standback with the BNR stage 2 , 15 psi was the target boost , i have the stock selenoid .
![]() | | #67 | ![]() |
| Not Ranked : 0 score Nice, so u made 287awhp @ 15psi? Or was it higher for that run, cuz bryan said u can run these up to 24psi. At 15psi u well within the efficency range of the BNR. Those are good #'s for such low boost levels. U got a nice setup
![]() | | #68 | ![]() |
| Not Ranked : 0 score Dyno run was at 18 psi . 15 psi is my daily driving map . But at only 15 psi the car pull very hard .
![]() | | #69 | ![]() |
![]() Join Date: Aug 2009 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score Do you have DP??? don't see it in your sig... Those are good numbers |
![]() | | #70 | ![]() |
| Not Ranked : 0 score Dyno sheet available for posting?
![]() | | #71 | ![]() |
| Not Ranked : 0 score Stock downpipe ! Green was 15 psi before/after and red was before/after 18 psi .
| The Following User Says Thank You to blackwidow For This Useful Post: | Alpha (02-25-2010) |
![]() | | #72 | ![]() |
| Not Ranked : 0 score So if I am reading that correctly, you only added maybe 100 RPMs of lag with the new turbo?
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score The BNR turbo spool 500-750 rpm later than the stock K04 , not 100 rpm
![]() | | #74 | ![]() |
| Not Ranked : 0 score Its only been 3 days since I sent in my turbo and I already want it! With a DP and ExMani I bet/hope I can make some good powa. I wonder if any of the GT2871 maps would work well w/ this setup. Maybe worth a try b4 a dyno tune
![]() | | #75 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Actually those are not GT housings.. the compressor housings are from Hitachi.. those are the same compressor housings as the stock turbo's off 2nd generation Rx-7's..Brian actually started building hybrid turbo's for the 2nd gen rx7 about 5 or so years ago... I wouldn't be surprised if he has piles of these compressor housings kicking around to use... |
![]() | | #76 | ![]() |
I agree that 500-750 rpms would make more sense, but the dyno doesn't appear to reflect that. ???
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #77 | ![]() |
![]() | | #78 | ![]() |
| Not Ranked : 0 score For the dyno I said before/after tuning , was with the BNR turbo .
![]() | | #79 | ![]() |
| Not Ranked : 0 score Ok, I thought it was 15/18 PSI stock/BNR turbo...
![]() | | #80 | ![]() |
| Not Ranked : 0 score Green was 15 psi and red 18 psi before/after tuning but all run was made with the BNR turbo .
| The Following User Says Thank You to blackwidow For This Useful Post: | daren83 (05-12-2011) |
