![]() Join Date: Jul 2008 Location: The Ocean State
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
(Thread Starter) | Not Ranked : 0 score What is the minimal overlap recomended for the wastegate flap to maintain a proper seal? PTP mentioned in another thread that the pic below showed "plenty of room to port it out" if thats the case, how thin would I dare go? Im down to port it, but only if I feel confident im not gonna junk yard it by doing so.
__________________ 07 CB Speed3 COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system |
![]() Join Date: Mar 2008 Location: NJ
| Not Ranked : 0 score What is your car doing? I took out some material along the hump in the flow path and smoothed it a good bit. I feel that the hump is there to make exhaust flow to the wg so I rounded the edges alot. I enlarged my wg opening about 1mm all the way around. Just make sure you don't compramise the sealing surface you will see a clear ring where the flapper door sits.
__________________ If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap. |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score What you want to do is look at how the unit flows. Make changes in the areas that would induce proper or more flow to the exhaust gasses. By doing this you should see a higher boost hold to redline and lower EGT's. I would also have to say that if you plan on doing the port work I would get it ceramic coated as well. This makes a huge difference in spool time for the turbo. Start porting and I will post pictures of what we have done to our units so you have a kind of guide to port off of. |
| GT Series Turbo Questions. | JimmyMac | MazdaSpeed 3/6 - Turbo Induction | 71 | 11-07-2013 05:47 PM |
| Head Porting Potential | pbblaster | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 11-25-2008 06:29 PM |
| Upgraded/reworked turbo questions | red07 | Mazdaspeed3/6 General Discussion | 5 | 11-08-2008 12:08 PM |
| Exhaust manifold porting costs? | Mellman | Mazdaspeed3/6 General Discussion | 2 | 03-20-2008 06:29 PM |
