 Old 02-13-2010, 07:58 AM   #1
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
SpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the world
Groans: 778
Default A/R .50, .60 or .70?
I'm buying a new compressor housing for my GT35r.
The housing thats on it now has a .50 A/R and I'm not so sure what A/R I should get.
what are your opinions on the A/R I should go with? a .50 is just not for me but would you gizzards think a .60 or .70 A/R would be best for me?
2003 SilverStone Grey Honduh S2000
SpeedSixxx is offline   Reply With Quote
 Old 02-13-2010, 08:26 AM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Do you mean turbine AR? The AR. of the compressor housing isn't near as important..
If your talking about the turbine AR, what are your HP goals? The smaller the AR. the faster your spool, but you lower the peak HP potential... That said, even with a .50 AR you should be able to hit 400~450 with the gt35, and you'll spool a few hundred rpms faster than I do with my .83 AR tubine...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
Docnox (02-13-2010), SpeedSixxx (03-02-2010)
 Old 02-13-2010, 08:28 AM   #3
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Go with the .63 or .82
I would probably lean towards the .63 if your HP goals are in the upper 400s. It will give a slight spool advantage of the .82. The .82 is more towards the 500-525 range.
The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post:
LiEast (05-11-2011), SpeedSixxx (03-02-2010), wette460 (03-17-2011)
 Old 02-13-2010, 08:28 AM   #4
SpeedSixxx's Avatar
Groans: 778
i meant the compressor housing A/R
and your loot will be in your accoutntoday after 4 promise/./
 Old 02-13-2010, 09:20 AM   #5
The compressor size isn't all that important. The 70 is what I had but like I said the turbine is what matters most. You should focus on switching your turbine housing. That is what will make a diff.
 Old 02-13-2010, 09:21 AM   #6
Groans: 60
A smaller AR would generally be better if your planning on running higher pressure ratios, but it isn't going to make a significant difference in the turbo's performance one way or another as you won't be going anywhere near the flow limits of the gt35... Get whichever housing is going to fit better, don't worry about the AR..
I have a .70 a compressor housing, only because it was what the 4" inlet housing came with..
SpeedSixxx (02-13-2010)
 Old 02-14-2010, 06:44 PM   #7
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
yeah dude you should replace the turbine housing before the compressor housing. Bigger gains
 Old 02-14-2010, 08:07 PM   #8
KoukiS14's Avatar
Posts: 146   (View Stats)
KoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond reputeKoukiS14 has a reputation beyond repute
The .70 A/R is the "proper" compressor housing for a GT35R. As far as turbine A/R, the .63 A/R is capable of around 600 whp in two wheel drive applications if you've got a setup capable of the amount of boost that a GT35R is capable of. That rules out all Mazdaspeeds at the moment.
KoukiS14 is offline   Reply With Quote
The Following User Says Thank You to KoukiS14 For This Useful Post:
djuosnteisn (02-15-2010)
 Old 02-14-2010, 08:54 PM   #9
SpeedSixxx's Avatar
Groans: 778
I'm changing the compressor housing cause it came with a 3inch inlet and I already have a 4inch Cpe tip so it must be done. I'll get the .70 housing juss cause bigger is better
when I build the motor in a year and I have money saved to change the turbine to a t3 .63 A/R I'll then also change the turbo to manifold flange.....
This shit been sitting in my apt for a while now so it's goin on
 Old 02-15-2010, 08:33 AM   #10
Groans: 60
If you have an manifold that uses the OEM turbo placement the larger compressor housing will not fit. That's why the ATP gt35 comes with the smaller T04E housing..
SpeedSixxx (02-15-2010)
 Old 02-15-2010, 09:58 AM   #11
SpeedSixxx's Avatar
Groans: 778
what manifold do you have?
i'm using the medievil manifold which does use oem placement.
I know you said you got the .70 A/R housing so I assume your mani doesn't have oem placement?
why does it not fit and could I do anything to make it fit? shave any metal? cut a huge hole somewhere? lol
if the .70 doesnt fit does the .60?
 Old 02-15-2010, 10:35 AM   #12
why does it rule out the mazdaspeeds?
bcmurphy87 (05-10-2011), djuosnteisn (02-15-2010), SpeedSixxx (02-15-2010)
 Old 02-15-2010, 10:35 AM   #13
Groans: 60
My manifold is as far away from the OEM placement as you can get...
I don't know of anyone who has made the standard gt35 compressor housing work in the OEM location, so I have no idea what would be involved trying to make it work...
 Old 02-15-2010, 10:40 AM   #14
SpeedSixxx's Avatar
Groans: 778
i just don't understand why the .70 wouldnt fit? it's not so much bigger then the .50 and what would you say is "blocking" it from fitting? the valve cover? wires?
you sure ATP made the compressor housing a .50 cause of the clearence or was it the hot side they made so small so it would fit?
who has tried this and what was the prob>?
and SS you get my payment homie?
 Old 02-15-2010, 11:40 AM   #15
when i did the 3076 with the .60 it was about 1/4" from the bottom studs on the head and i had to wrench that bitch in there. any bigger and it def would not have fit.
 Old 02-15-2010, 12:01 PM   #16
Groans: 60
AFAIK, the actual compressor housing hits the block. I haven't seen it in person, but that's what ATP told me, and a big part of why I went the way I did with my setup..
Yep, got your payment. I'm stuck at work all day today, so I'll get the mounts shipped out either this afternoon or tomorrow.
 Old 02-15-2010, 01:00 PM   #17
SpeedSixxx's Avatar
Groans: 778
I just called ATP and the guy had no idea what I was on about..lol
he said to email them for the 20th time..so I will
i'm thinking tho...maybe bring my mani anywhere they can heat it up and maybe pull the turbo flange away from the block a lil bit? SUPERSKATE, you said with the .60 A/R you had to monkey that cosby in place and that there was hardly 1/4 inch of room..what about on the other side of the compressor? how much room from that side of the compressor to the firewall? maybe a lil bit of bending will do the trick.
another thing..and I really do see what ppl are talking about is...my medievil mani
how every damn mani they made was different from the warping to the actual cut of the head flange to the tube distance and diameter. so maybe although it is an OEM turbo placement design they were a bunch of fuck tards and nothing was the same I.E. the distance from the turbo flange to the actual cyl head block.
I WANT ME A .70 godd damn it.. WHAT A WIN BOAT I HAVE...love my car@!!!!!
The Following User Says Thank You to SpeedSixxx For This Useful Post:
 Old 02-15-2010, 06:55 PM   #18
KoukiS14's Avatar
I did say, "at the moment." We haven't seen any 35 psi 600 whp Mazdaspeeds just yet. Keep working and wow us though.
 Old 02-15-2010, 07:10 PM   #19
I still don't know why your so fixated on the cold side when changing out the hotside would make much more of a difference
bf360 (02-15-2010)
 Old 02-15-2010, 07:32 PM   #20
speedsixx,
as far as i can remember, there was more then enough room between the comp and the firewall without the IWG actuator of course.
 Old 02-15-2010, 10:10 PM   #21
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Finally something interesting to read! The proper thing to do is getting your mani and dp sized for the turbo you want to run but what do i know im just a plumber. Fitment is key take Socks car for instance, we saw what a slight fitment issue can do to such a nice set up.
 Old 02-16-2010, 12:45 AM   #22
SpeedSixxx's Avatar
Groans: 778
I wrote in my last post why I NEED a new compressor housing. I have a dooky .50 A/R polished 3 inch inlet 35r compressor housing.
I have a CPE 4 inch TIP.......I want a .60 A/R compressor housing (as ATP says is ok)
with 4 inch anti surge (bullet hole type-machined) inlet NON polished (me like to pant)
and for the reason why I am not going to change my hot side JUST YET is because if I did that I would then have to hack up my beautiful manifold and have a t3 flange welded on.
plus I just dented my rim so bad a few hours ago there is a huge triangle chunk missing and now it doesn't hold air =( my tires were about fucked anyway.
I just ordered new rims and tires so now i'm gonna have to wait just a lil bit longer to get my new compressor housing.
I WILL change my hot side over to t3 .63 A/R when I build the motor.
If you remember what I wrote to you saying that I want near 400 awhp for now cause I'm on oem internals...I don't want to push it that hard. An ATP hot side will do for my power goal until I build the motor.
I have 55k on the motor now, nearing 100k I'll rebuild the motor.
ty for the concern but as of now all i'm worried about is driving on a damn donut for a week in the fresh snow and getting me a new sexxxy 4 inch, anti surge compressor housing .60 A/R
=( i'm gonna go sulk over my rim =(
 Old 02-16-2010, 05:02 AM   #23
spnkr21's Avatar
Groans: 105
Default Re: A/R .50, .60 or .70?
I have cp-e stock turbo inlet. Gimme a pm if u want it
2012 WRX HB w/mudflaps yo!
SpeedSixxx (02-16-2010)
 Old 02-16-2010, 09:48 AM   #24
SpeedSixxx's Avatar
Groans: 778
i have cpe 3 inch inlet as well, but i plan on selling it when I get the 4 inch comp housing.
you get the oil line yet?...should be there today or wed the latest...i hope today
 Old 03-02-2010, 06:40 PM   #25
SpeedSixxx's Avatar
Groans: 778
superskates pics of your turbo installed please..i wanna see what the .60 A/R comp housing looks like near the block.
I found a used 35r .70 A/R comp housing for 150 but i don't wanna rush and buy it knowing that at least on the stock manifold the .70 won't fit.
as stated before I have a Medievil manifold and I may not even run into any problems using a .70 A/R comp housing as a stock mani guy would.
 Old 02-26-2011, 11:14 AM   #26
SpeedSixxx's Avatar
Groans: 778
please close this thread!
 Old 02-26-2011, 12:22 PM   #27
mason's Avatar
Posts: 946   (View Stats)
LOL!
The Following User Says NO Thank You to mason For This Un-useful Post:
SpeedSixxx (02-26-2011)
 Old 02-26-2011, 12:25 PM   #28
SpeedSixxx's Avatar
Groans: 778
Originally Posted by mason View Post
LOL!
LOL wut? close this fuckin thread please
 Old 03-16-2011, 02:38 PM   #29
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Almost a year exactly.... pretty close anyway.
And since this thread isn't closing.....
how much longer til your new hardware is up and running man?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 05-10-2011, 03:13 PM   #30
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
well i just ordered a gt35 with teh 70 compressor i hope i can get it to fit. Im already hacking my pg v3 mani to flang it for t3 and ewg. maybe they can tweek it to fit. They do sick fab work so im not worried about the quality just the fitment.
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
SpeedSixxx (05-11-2011)
 Old 05-11-2011, 01:42 PM   #31
SpeedSixxx's Avatar
Groans: 778
good luck with the 35r..
i'm sure you won't have a problem gettingit to fit.
keep us updated.
i'll be makin a thread in the coming week or so.
Last edited by SpeedSixxx; 05-11-2011 at 01:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-11-2011, 10:13 PM   #32
wette460's Avatar
Posts: 385   (View Stats)
wette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the worldwette460 is the leader of the world
Hey SS, I see this thread was forever ago, but I was wanting to know what your powah levels are with that 35R setup. That is quite a nice setup you have there man!
T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels
wette460 is offline   Reply With Quote
Page generated in 0.48888 seconds with 29 queries
