 Old 03-04-2008, 11:57 AM   #1
Rican219's Avatar
Posts: 120   (View Stats)
Rican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the worldRican219 is the leader of the world
Default Rebuilt Stock Turbo
I sent mine off. That is all
[SIGPIC][/SIGPIC]www.myspace.com/rican219
MODS:
TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk
Rican219 is offline   Reply With Quote
 Old 03-04-2008, 12:35 PM   #2
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groans: 57
you gotta share more. where who how much?
Laloosh is offline   Reply With Quote
The Following User Says Thank You to Laloosh For This Useful Post:
Juyoung (06-20-2013)
 Old 03-04-2008, 12:42 PM   #3
Yea, stop being jewish with the info!
 Old 03-04-2008, 12:51 PM   #4
Rican219's Avatar
Nick Mannario
Modern Performance Inc
732-222-3679
Basically he is taking my stock Turbo (Spare I have) Port and Polish the Exhaust Housing, Trim the rubine wheel, Machine Comp housing for bigger comp wheel, install new seals, 14lbs Waste gate.
This setup will flow 39lb/hr and 575cfm
All for around $800 give or take a few bucks.
Big Tim from another forum turnned me onto this guy and he is awesome.
MODS:
 Old 03-04-2008, 12:59 PM   #5
Laloosh's Avatar
Groans: 57
very intresting...another reworked stock turbo option. Kinda pricey though....does he have cores?
 Old 03-04-2008, 01:14 PM   #6
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
you will have issues with boost control using the 15lb spring WGA
whoosh@Realtune is offline   Reply With Quote
 Old 03-04-2008, 01:15 PM   #7
Nick Mannario
732-222-3679
+1
I have heard great things about Nick from various forum members
 Old 03-04-2008, 01:26 PM   #8
Rican219's Avatar
Not sure on the cores. I have a spare that me and my friend have been using.
MODS:
 Old 03-04-2008, 01:27 PM   #9
Rican219's Avatar
ORLY?
Explain so I can change it if possible
MODS:
 Old 03-04-2008, 09:36 PM   #10
driver311's Avatar
Posts: 1,769   (View Stats)
Once paired with a bc, low boost levels will be a thing of the past.
I want a stiffer spring in my wg.
 Old 03-04-2008, 09:46 PM   #11
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
You will def have issues with that WG.
I had the 14psi WG on my GT30 (turbo itself doesn't matter), and controlling boost was crazy. I ordered a 7psi WG and I can now safely and easily control m boost using my MBC.
Performance Racing is offline   Reply With Quote
 Old 03-05-2008, 11:29 AM   #12
thank you for confirming Pathik
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
simply_pandora (06-03-2013)
 Old 03-05-2008, 11:39 AM   #13
Laloosh's Avatar
Groans: 57
this is what im talking about. People sharing their info before others make the same mistakes.
 Old 03-05-2008, 11:45 AM   #14
phailerider's Avatar
Posts: 4,639   (View Stats)
What should be be expecting on the gt3071? I think I read somewhere that the original wastegates they were sending out had problems.
The Following User Says Thank You to phailerider For This Useful Post:
atvfreek (04-27-2013)
 Old 03-05-2008, 11:45 AM   #15
ultraspeed619's Avatar
Posts: 268   (View Stats)
ultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the worldultraspeed619 is the leader of the world
IIRC there's a guy on m6c that had his turbo reworked and mentioned that his turbo has started smoking again after 6 months... i think his SN is joeyD. i'll try and find that thread in bit.
MAZDASPEED6
Engine: Cobb SRI/AP | CPE FMIC/DP/MM/HPFP | MagnaFlow 3in CBE | HKS TwinPower Ignition | Denso plugs |
Suspension/Wheels: SSR GT10 19x8 +37 | RPM Street Springs | AutoExe F/R braces | WhiteLine RSB | GT Spec Ladder Bar/Trailing Braces |
Exterior: SSG AE Lip Kit | HomeDepot Front Lip Mod | JDM Tailights | Black Emblems |
Interior: AutoExe ShiftKnob | TWM STG2 | ProSport BoostGauge | Dashawk |
ultraspeed619 is offline   Reply With Quote
 Old 03-06-2008, 10:12 AM   #16
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
could be the seals giving out? juicing up the stock turbo puts more stress on it...right?
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 03-06-2008, 08:20 PM   #17
Rican219's Avatar
If it's the stock seald then maybe I could see that. Mine is being built with the seals from a Garrett turbo machined down to fit mine. Going to be alot stronger
MODS:
 Old 03-06-2008, 10:06 PM   #18
Thats the way to do it. I dont have much faith in Hitachi's seals.
 Old 03-07-2008, 08:06 AM   #19
clos561's Avatar
:bananadog gywow:
yea they obviously proven to be really shitty...wtf i thought these were funny lol (the bananas)
 Old 03-08-2008, 03:53 PM   #20
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
i'd like to see how this turns out for you! we'll see how the wastegate works on the 3071r. Just go pick up a vacuum tester from autozone to see what wastegate the 3071r has. I plan on running 14-16psi for awhile on the 3071r, just for adaptation of the ecu. I'll be doing the install on Tuesday night (if my turbo gets here tuesday like the tracking number says it will!) and then that weekend I'll be driving 4hrs to dallas (yay for ECU adaptation!). I won't even get to enjoy the car for another 3 weeks
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 03-09-2008, 05:56 PM   #21
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Let me know when you drive down, I'd love to meet up and see you handiwork.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 03-12-2008, 10:14 AM   #22
you bet. PM me your phone number and actual location in the DFW.
side note: just got off the phone with ETS, again, they pushed back the build date of the intercoolers another week. i'm not pleased with them. thats the 2nd week they've pushed them back, and still don't have a confirmative date.
sorry to jack.
 Old 03-13-2008, 10:15 AM   #23
sorry to jack.
Buy IDRVSLO's CS FMIC, he lowered the price again!
 Old 03-21-2013, 06:00 PM   #24
leon78's Avatar
Posts: 2,595   (View Stats)
Default Re: Monthly Installs
For sure man...they open at 1100, I'm down to help any and everybody out....I'll be there either way to change my oil.
Lol @cdmarch; wrong quote driver.
Sent from my yotaru
2013 Scion FR-S (Whiteout)
Less parking more racing
 Old 03-21-2013, 06:06 PM   #25
btstarcher's Avatar
Posts: 4,852   (View Stats)
LOL wut?
SnailTune in progress
 Old 03-21-2013, 06:19 PM   #26
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
Da fuq, just went full retard.
 Old 03-21-2013, 07:41 PM   #27
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Default Re: Rebuilt Stock Turbo
@leon78; is posting in the wrong thread.
Sent from my Nintendo DS using Tapatalk 2
 Old 03-22-2013, 06:40 AM   #28
leon78's Avatar
My Tapatalk went ape shit last night...my bads.
The Following User Says Thank You to leon78 For This Useful Post:
Mike@Stratified (03-22-2013)
 Old 08-30-2013, 04:11 PM   #29
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
My 386 didn't have a Turbo function.
Sent from my Nexus 10 using Tapatalk 4
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/rebuilt-stock-turbo-39/
MazdaSpeed 6 - Turbo Induction [Archive] - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-01-2008 10:52 PM
OMG the stock turbo sucks!!! ptperformance Mazdaspeed3/6 General Discussion 71 07-18-2008 03:40 PM
ATP Turbo Items for Speed3/6 IN STOCK! Performance Racing Mazdaspeed3/6 General Discussion 18 04-22-2008 08:56 AM
Stock pump looks OK on stock engine enganear MazdaSpeed 3/6 - ECU Computer Tuning 33 04-08-2008 09:21 AM
Stock turbo upgrade mdogg MazdaSpeed 3/6 - Turbo Induction 20 03-31-2008 02:14 PM
Page generated in 0.46932 seconds with 35 queries
