![]() Join Date: Mar 2015 Location: Princeton, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 48
Groaned at 7 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score Anyone know of how to measure shaft play on the stock k04? And how much is too much? I saw some rebuild kits as well and was wondering if anyone had any advice/suggestions for it. Is it possible to do a rebuild yourself or can the someone like the dealer or an 3rd party vendor take care of that for you?
__________________ 2007 Mazdaspeed 3 |
![]() Join Date: Jun 2009
| Not Ranked : 0 score I don't know how much is too much in terms of maximum allowable shaft deviation. I can say that I know one way to tell, but it's not a good one: wait until the compressor wheel starts scraping the turbo inlet! That's what happened to me. I noticed that the turbo was making some extra noise, just a slight change in pitch on light throttle changes. Upon inspection, I caught several things: 1. The shaft play was very noticeable. 2. The compressor vanes were actually scraping the side of the compressor housing at the point where they contact the snail, leaving little score marks. 3. Upon closer inspection, one of the compressor vanes was actually chipped. I've done turbo rebuilds before on T4 turbos on Saabs and feel confident in doing that. In this case, however, with an obviously damaged wheel on the compressor side, that was not even a remote option. I had my turbo rebuilt be Work Turbochargers (turborepair.com) in Pelham Alabama, a suburb of Birmingham. Because the compressor wheel had to be replaced, I opted to have them install a new CHRA inside a rebuilt housing. Even then, it was a reasonable $600, if I recall. A normal rebuild is about $350 if I recall. They did a great job, turn around was fast, and it is performing just like a new K04. Mazdaspeed 3 I'm sure there are other companies that do good work, but I had heard good things about them and am happy with what they did.
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score @MSMS3; you had all that and no smoke? I was going to answer, that the play doesn't matter, just fix it when it smokes
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | MD1032 (12-10-2015) |
When a CHRA is spinning at over 100,000 rpm under boost, eventually any shaft and bearings will wear enough to fail. The seals held.
(Thread Starter) | Not Ranked : 0 score What does that mean? I'm on Rotella T6 btw... great oil but then again I'm not really sure what makes it so great. Also, at what mileage did you end up having to do the rebuild? I'm thinking if all is okay at 90k miles I can just do it there but I'm at 50k now..... may just do it ASAP for peace of mind.
The +200 is idle rpm. I raised it up 200 over stock. It is now about 900. You have to have some form of aftermarket tune to adjust idle rpm. It really helps relieve the gen 1 positive crankcase pressure effect on the turbo oil flow.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 12-13-2015 at 03:02 PM. | |
| The Following User Says Thank You to MSMS3 For This Useful Post: | furinax (12-20-2015) |
Looking at the cost (~$400) I am less inclined to do this as a preventative measure... maybe at a major service interval like 90k miles or so, but until the turbo starts smoking or making noise I think it's safe to just leave it. How would I know if it was not reaching/holding target boost? Also, k04 is billet right?
__________________ 2007 Mazdaspeed 3 | |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score Turning your car off at stoplights sounds like an accident waiting to happen |
| The Following 2 Users Say Thank You to broda For This Useful Post: | Castillo817 (12-20-2015), MS3Shadow (12-20-2015) |
| Not Ranked : 0 score I would think that turning the car off at stoplights wouldn't save any gas. On startup, it runs rich, probably negating any benefits. As far as worried about your turbo, turning the car off at lights would accelerate wear on the turbo. Especially if you had been getting on it at all. It would heat soak everytime
I've only done it a few times anyway. A lot of modern cars shut off when stopped actually- they turn back on when you press gas... but I guess this doesn't apply to turbo cars.
| Not Ranked : 0 score ^ That too. If you beat on it and then don't let the car idle at all you're asking for bad things to happen. |
| Not Ranked : 0 score The stock tune on this car is pig rich. Very rich AFR, not merely at idle. It is a characteristic of turbos, and especially with high compression direct injection. It is protective and the cylinder cooling effect permits more timing advance for better power at higher rpm. Don't shut off and on at stop lights. No fuel saving. Starter will wear out sooner, and with a manual transmission on hills . . . just no.
| Shaft Play | K.Mah | 2010 MS3 - Turbo Induction | 11 | 10-27-2012 12:17 PM |
| Have shaft play .. getting an SST | johnnyspeed6 | MazdaSpeed 3/6 - Turbo Induction | 10 | 07-22-2009 05:34 AM |
| Too Much Shaft Play? | superskaterxes | Mazdaspeed3/6 General Discussion | 13 | 04-03-2009 08:17 AM |
| K04 shaft end play, how much is OK? | bnoon | MazdaSpeed 3/6 - Turbo Induction | 11 | 03-03-2009 07:49 AM |
| shaft play | b-ron | MazdaSpeed 3/6 - Turbo Induction | 8 | 08-19-2008 08:49 AM |
