![]() Join Date: Dec 2008 Location: Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Groaned at 5 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score My long term fuel trims are the following: idle = 4 to 6 Part throttle = 7.0 Engine breaking = 7.8 Medium throttle & WOT = 10.2 These LTFT are after about 100 miles of driving. My only mods right now are the MSCAI2 with straighteners. I have checked all the typical areas for leaks. I tightened up all the intercooler piping and intake piping couplers. The car does not seem any faster with the intake. |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Those LTFT's are just fine. Ideally you want them to be zero, but aftermarket intakes tend to lean the car out a bit. This is why you are seeing fuel being added. I wouldn't worry about those numbers. |
![]() Join Date: Mar 2008
I would be.. You LTFT should be NO higher than 5% at WOT and really shouldnt be any bit higher than 3. Good thing is that a protune will do great things to your setup and you shouldnt cause too much harm with how it is currently running.
__________________ On motor #3 Turbo #2 Now have a SSM 08 STi!! | |
![]() Join Date: Jan 2009 Location: Obama Land
| Not Ranked : 0 score Did you drive very easy for a prolonged time? |
(Thread Starter) | Not Ranked : 0 score Yes for about 100 miles |
![]() Join Date: Apr 2008 Location: Atlanta, GA
Rep Power: 334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score Are these LTFTs positive or negative? One other thing to check is how far the intake pipe goes into the filter. If it goes to far then it can effect everything from fuel to boost. |
![]() Join Date: Dec 2008 Location: Cincinnati
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 658
Groans: 60
| Not Ranked : 0 score From what I have read anything between +-(6%~8%) is reasonable. Zero, or close to it, is ideal. |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 853 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Agreed. If they go higher than 15 (I believe that's it) you get a MIL/CEL if it's sustained for a period of time.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
![]() Join Date: May 2008 Location: Lehigh Valley, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 376
| Not Ranked : 0 score I wish my LTFT's were that low |
| Not Ranked : 0 score Wow that's high. You checked for leaks?
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 31 Times in 16 Posts
| Not Ranked : 0 score mine is 17% at idle, and WOT -1% lol. i wonder if i have a leak.. |
| Not Ranked : 0 score yes I've checked for leaks. I can't find any. Everything is tight and installed correctly. I had even higher readings when I had just the Cobb SRI... I'm not the only one either. |
| Not Ranked : 0 score Well my LTFT's came down today finally... 5.5% at idle and 7.8% at WOT. All I did was beat the crap out of the car. I've been driving like an old man for the most part for the past couple hundred since the ECU reset for inlet install. Today I decided to do a few WOT runs. What also is interesting is that I got some mild KR in the upper RPM's the first couple times and then it went away and kept feeling better. I think the ECU just gets used to how you drive and maybe doesn't react to changes as quickly as we think. |
![]() Join Date: Aug 2008 Location: Baltimore
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score yea my ltft are around 15 but ive been drivin like an old lady for a few months maybe ill beat the shit outta it for a few days and see what happens lol
__________________ CP-E cai, CP-E catless dp, CP-E fuel pump, CP-E flash, Standback V2, CP-E fmic, ATP inlet, SU mm Tuned by PTuning CP-E and Cobb .. why cant we get along :friday: LoL |
| Not Ranked : 0 score i jus checked mine out and my shits all over the place lol at idle its 19.5, if i barely touch the gas like 100 200 rpms tops its 14.3 and if i do jus a hair over that like maybe 1/8 throttle its 8.6 lol why the hell is it all over the place like that within that little bit of a change of rpm
| ALL-IN. ![]() Join Date: Jan 2009 Location: Alberta
Rep Power: 1397 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 872
Groans: 30
I would inspect all hose connections thoroughly. | |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score The OP has fuel trims I dream about! I might have a leak, but I've checked every hose I can find.
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
![]() Join Date: Aug 2008 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groans: 68
| Not Ranked : 0 score I'm getting some high LTFT also. Here is my thread http://www.mazdaspeedforum.org/forum/foru...og-inside.html Not sure what's causing it though. Edit: I also have been driving like a granny the past 200 miles to let my ECU relearn this new map. I don't know if that's a factor or not though.
__________________ 2010 Dodge Ram Hemi 1967 Camaro RS/SS 2008 Caliber SRT-4 (SOLD) 2008.5 MS3 GT (R.I.P.) |
| Not Ranked : 0 score i checked for leaks didnt come across anything boost leak tested it and retighten everything ... if i gotta leak it cant be much of one because my car is still runnin like a champ .. i donno this cars anal
Groans: 91
| Not Ranked : 0 score I did some WOT runs the other day for a thread on this forum and my trims have suddenly gotten a lot better. It might have to do with the warmer weather we've been getting. Or maybe I just needed to blow the carbon out of this mother fucker
![]() | | #24 | ![]() |
| Not Ranked : 0 score That is good to hear. |
![]() | | #25 | ![]() |
Groans: 91
| Not Ranked : 0 score Update. My trims are staring to move to relatively sane levels! It's great. I recently installed an ETS 3.25" TMIC, Denso ITV22 step colder plugs, and added two shims to the blue spring on my Forge valve. I did some WOT logs (starting in 4th gear at 3000rpm) to show someone in another thread, and I noticed my LTFT's starting looking a lot better! At this point I'm idling no higher than +3.9, Cruise is around +3.1, Moderate gas puts it around +5.8, and hard throttle/WOT puts it around +11 to +13. These trims aren't perfect, but they're a hell of a lot better than what I had. I'm not sure if my recent mods helped or just the warmer weather I've been driving in, but I'm one happy camper right now! My knock retard warning on the DH has been missing in action as well! (knocks on wood)
| LTFT: What can it tell you? | badams118 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 03-17-2009 10:06 AM |
| LTFT going back to 0 at WOT | aaronc7 | Cobb Access Port/Maps | 93 | 02-16-2009 09:12 PM |
| Standback, LTFT & CEL | badams118 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 01-05-2009 10:58 AM |
| Is my LTFT okay? | RMCAT | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 09-10-2008 08:40 AM |
