![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. Last edited by SilverDemon; 02-29-2012 at 02:11 PM. |
| The Following 26 Users Say Thank You to SilverDemon For This Useful Post: | 06Speed6 (12-17-2009), aaronc7 (12-17-2009), AmillieMS6 (12-22-2009), bioevolve (12-17-2009), breakfstincluded (10-17-2011), BudUMfan (02-13-2010), burntRice (02-26-2011), cpolly69 (12-17-2009), DingoDave (02-21-2011), djuosnteisn (12-17-2009), dougefresh_ (06-16-2011), FreeFlyFreak (12-22-2009), JacksonMS30 (06-08-2011), JefeSpeed (05-27-2010), karl-hungus (12-17-2009), madvillain (12-17-2009), mouse0330 (03-12-2010), nutsac76 (03-18-2010), psychophyr (02-08-2010), silversurfer3 (12-17-2009), Speed3eak (12-31-2010), SpeedSixxx (02-08-2010), spnkr21 (11-21-2010), starscream (02-07-2010), superskaterxes (12-17-2009), the_caruch (03-11-2010) |
| Not Ranked : 0 score Nice, I was actually thinking about merging the runners on my head and making a mani to match, but I was going to flow bench a spare head first before I did it on my big valve head.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | SilverDemon (12-17-2009) |
(Thread Starter) | Not Ranked : 0 score That would be nice, and I might do that once I build the head. But for right now I will knife edge the divider in the head plate to try and divide the air flow the best I can.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
| The Following 2 Users Say Thank You to SilverDemon For This Useful Post: | BudUMfan (02-13-2010), djuosnteisn (12-17-2009) |
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
| Not Ranked : 0 score cool
__________________ "08, I hate to break it to you, but if it gives kevin a boner, its porn" ![]() NATOR PERFORMANCE Nylon washer sponsered |
| The Following 2 Users Say Thank You to mexicant For This Useful Post: | aaronc7 (12-17-2009), SilverDemon (12-17-2009) |
![]() Join Date: Jul 2008
Rep Power: 1790 ![]() Thanks: 2,239
Groans: 62
Groaned at 156 Times in 148 Posts
| Not Ranked : 0 score very nice scott! |
| The Following User Says Thank You to MarkyMark For This Useful Post: | SilverDemon (12-18-2009) |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score look good so far buddy - keep up the good work!
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
| The Following User Says Thank You to cpolly69 For This Useful Post: | SilverDemon (12-18-2009) |
| Not Ranked : 0 score being you have the hardest part done already (tubular runners) i wouldent think its that hard to CNC or waterjet the flange out and weld a sheet metal plenum on there would it?
| The Following User Says Thank You to superskaterxes For This Useful Post: | SilverDemon (12-18-2009) |
(Thread Starter) | Not Ranked : 0 score delete
| The Following 3 Users Say Thank You to SilverDemon For This Useful Post: |
| The Following 17 Users Say Thank You to SilverDemon For This Useful Post: | Blackspeed (12-23-2009), BudUMfan (02-13-2010), cpolly69 (12-22-2009), djuosnteisn (12-22-2009), JefeSpeed (05-27-2010), madvillain (01-31-2010), MarkyMark (12-23-2009), meeker13 (06-01-2010), mike8748 (02-21-2010), mpsanger6 (12-23-2009), MPSdriver (12-24-2009), nutsac76 (03-18-2010), rigor (06-01-2010), SpeedSixxx (02-08-2010), starscream (02-07-2010), superskaterxes (12-22-2009), the_caruch (03-11-2010) |
| Not Ranked : 0 score Me likes. Can't wait to see the final outcome! And you sure move fast hombre!
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | SilverDemon (12-22-2009), SpeedSixxx (02-08-2010) |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score yea, your gonna have your first one done soon. any plans for the runners inside the plenum?
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following User Says Thank You to socks For This Useful Post: | SilverDemon (12-22-2009) |
(Thread Starter) | Not Ranked : 0 score The runners will protrude inside the plenum, as to how much? I am not sure. I know the air likes to flow over a rim, rather than dropping off into a port. More research will have to be done on my part before the final height will be determined...
| The Following 4 Users Say Thank You to SilverDemon For This Useful Post: | BudUMfan (02-13-2010), FreeFlyFreak (12-22-2009), SpeedSixxx (02-08-2010), superskaterxes (12-22-2009) |
ALSO!!! dont forget the PS pump basically blocks that last bolt near cylinder 1. your head flange looks uber thick so make sure you CNC down that last corner where that bolt will go because it will never fit otherwise.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: | djuosnteisn (12-22-2009), FreeFlyFreak (12-22-2009), SilverDemon (12-22-2009), SpeedSixxx (02-08-2010) |
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 141
Groaned at 26 Times in 11 Posts
| Not Ranked : 0 score Sexy!! Great job
__________________ Rota wheel whore #1 MOdS list shaved with a razor moldings (EDGE cream)~de-BaGEd FTW~ painted StoCk wheels secret color ~ rattl;e caned RooF~ jdm painted brake conversion~ clear tint ~ light weight black hood and trunk with wing option ~ japanese amber side markers/ running lights ~ tw0 light weight car seats ~ shifter weight reduction ~ stock recaros with red stitching ~ mp3 mazda stereo for sale: ms3 transmission second gear is worn out. Perfect if you want to Upgrade it or if you don't want to have any down time if you're trans is messed up! PM me with offers |
| The Following 2 Users Say Thank You to silversurfer3 For This Useful Post: | SilverDemon (12-23-2009), SpeedSixxx (02-08-2010) |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score Looks good man! I'll shoot you a PM back!
__________________ Kriebs Speed and Power Development. AIM: KriebsSPD |
| The Following 2 Users Say Thank You to mkriebs For This Useful Post: | SilverDemon (12-23-2009), SpeedSixxx (02-08-2010) |
| Not Ranked : 0 score Is this Al or SS? Looks sweet so far.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following 2 Users Say Thank You to cld12pk2go For This Useful Post: | djuosnteisn (12-23-2009), SilverDemon (12-23-2009) |
| Not Ranked : 0 score Super nice work on the plates, its really coming together.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | SilverDemon (12-23-2009) |
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. Last edited by SilverDemon; 02-29-2012 at 02:12 PM. |
| The Following 14 Users Say Thank You to SilverDemon For This Useful Post: | 06Speed6 (02-03-2010), BudUMfan (02-13-2010), djuosnteisn (01-31-2010), Fobio (02-01-2010), JefeSpeed (05-27-2010), KoukiS14 (01-31-2010), madvillain (01-31-2010), MarkyMark (02-01-2010), nutsac76 (03-18-2010), predapio (02-13-2010), RayRayBauder (02-07-2010), rigor (06-01-2010), SpeedSixxx (02-08-2010), starscream (02-07-2010) |
Groans: 27
| Not Ranked : 0 score awesome sauce dude!
| The Following User Says Thank You to cpolly69 For This Useful Post: | SilverDemon (01-31-2010) |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 283
Groans: 213
Groaned at 274 Times in 187 Posts
| Not Ranked : 0 score coming out real good man, that fuel pres sens is a bitch huh? lol |
| The Following User Says Thank You to Buildabong For This Useful Post: | SilverDemon (01-31-2010) |
| Not Ranked : 0 score That looks amazing!
| The Following User Says Thank You to mkriebs For This Useful Post: | SilverDemon (01-31-2010) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score wow great job, are you planning on making a run of these when finished?
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | nutsac76 (03-18-2010), SilverDemon (01-31-2010) |
![]() | | #25 | ![]() |
I do not think I will make any more, it simply is a huge task just to get the one done, let alone making a batch of them.
![]() | | #26 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score awesome job man. That thing is gonna be sexy!!! Or is sexy I mean. |
| The Following User Says Thank You to spnkr21 For This Useful Post: | SilverDemon (01-31-2010) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Boo on not making anymore, you'd be filthy rich. I have a spare pressure sensor if you need one for prototyping or investigating. Just lemme know and i'll send it out next week. ..At least i'm 99% sure i have a spare lol.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | nutsac76 (03-18-2010), SilverDemon (02-01-2010) |
![]() | | #28 | ![]() |
Groans: 78
| Not Ranked : 0 score seriously, gather up all the guys who would be interested (I WOULD!!!) and get a list going to see if you can justify sending that shit to china to be produced for a profit.
| The Following User Says Thank You to madvillain For This Useful Post: | SilverDemon (02-01-2010) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks!! Sending stuff to China to get made does not sit well with me. If, and this is a big "IF" I were to make these, I would do them here in the U.S. I know a few shops that this is the only kind of work they do, and the cost would be ok if 30 units could be made. DJ, I appreciate the offer, but I am using my sensor to mock up something. But in case I fubar mine, I might be hittin' you up for your spare.
| The Following 5 Users Say Thank You to SilverDemon For This Useful Post: | BudUMfan (02-13-2010), djuosnteisn (02-01-2010), madvillain (02-01-2010), predapio (02-13-2010), SpeedSixxx (02-08-2010) |
![]() | | #30 | ![]() |
Groans: 78
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] | |
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | SilverDemon (02-01-2010), SpeedSixxx (02-08-2010) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score LOL!! I will see what I can do on the dyno. I would really like to have my spare motor built, intake mani done, the CP-E flashes should be done late this week or early next week, then get it to the dyno
| The Following 5 Users Say Thank You to SilverDemon For This Useful Post: | BudUMfan (02-13-2010), djuosnteisn (02-01-2010), madvillain (02-01-2010), SpeedSixxx (02-08-2010), superskaterxes (02-01-2010) |
![]() | | #32 | ![]() |
Groans: 78
| Not Ranked : 0 score damn, get to work!
| The Following User Says Thank You to madvillain For This Useful Post: | SilverDemon (02-06-2010) |
![]() | | #33 | ![]() |
![]() Join Date: Jan 2010
| Not Ranked : 0 score lets get a list of 30 ppl to makem lol so worth it. |
| The Following User Says Thank You to cwpms3gt For This Useful Post: | SilverDemon (02-06-2010) |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have to prove my method of madness first!!! LOL
| The Following User Says Thank You to SilverDemon For This Useful Post: | nighthawk358 (11-18-2010) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I fabbed up the throttle body portion of the plenum. This is just tacked welded together to see if this will fit into the space available.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. Last edited by SilverDemon; 11-18-2010 at 07:21 PM. |
| The Following 17 Users Say Thank You to SilverDemon For This Useful Post: | 06Speed6 (02-07-2010), ATE BALLER (02-09-2010), bioevolve (02-08-2010), BudUMfan (02-13-2010), cld12pk2go (02-08-2010), cpolly69 (02-07-2010), djuosnteisn (02-07-2010), JefeSpeed (05-27-2010), madvillain (02-07-2010), MATT DAMOND (02-19-2010), MKTMS3 (02-07-2010), nighthawk358 (11-18-2010), nutsac76 (03-18-2010), predapio (02-13-2010), rigor (06-01-2010), SpeedSixxx (02-08-2010), starscream (02-07-2010) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score It would be good to tack some plate inside to guide the incoming air to the area closest to the TB. The flow looks like it would be off quite a bit.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | nighthawk358 (11-18-2010), SilverDemon (02-07-2010) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score So, as to split the air horizontally or vertically?
![]() | | #38 | ![]() |
| Not Ranked : 0 score Kinda like that, just to roughly split the incoming air in half between the 4 cyl. You would probably need another plate to guide air back towards cyl 4.
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | nighthawk358 (11-18-2010), SilverDemon (02-08-2010) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score AHHH!! Gotcha!! I need to make this part a tad narrower, once I get the fitment, I will look into applying this idea. Thanks again!
![]() | | #40 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
| Not Ranked : 0 score well, Lemme start the list of ppl that DEMAND that "SilverDemon-aftermarket CO." make these for sale!!! 1: SpeedSixxx
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() |
| The Following 4 Users Say Thank You to SpeedSixxx For This Useful Post: | jgrangers4 (02-21-2011), madvillain (02-12-2010), nighthawk358 (11-18-2010), SilverDemon (02-08-2010) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/silverdemon-s-intake-manifold-44765/ | ||||
| Get Ready for some XtremeBoost!!! - Mazda6 / Atenza | This thread | Refback | 02-19-2010 01:15 PM | |
| Intake manifold | QuickSpool | 2010 MS3 - Engine, Transmission & Driveline | 0 | 11-18-2009 06:19 PM |
