Like Tree6Likes
 Old 10-24-2013, 03:41 PM   #81
randomtask16's Avatar
Posts: 48   (View Stats)
randomtask16 is a splendid one to beholdrandomtask16 is a splendid one to beholdrandomtask16 is a splendid one to beholdrandomtask16 is a splendid one to beholdrandomtask16 is a splendid one to beholdrandomtask16 is a splendid one to beholdrandomtask16 is a splendid one to behold
Originally Posted by jm211 View Post
Drive so there is no smoke from idle then go WOT. Get any buffs of smoke rigt as you mash the accelerator?
I will next chance I get to drive her car. From my testing before we pretty much get no smoke at all under WOT unless I launch from 1st and there is still smoke left from idling. Like I mentioned above, and smoke is generally gone by the time we/she shifts to 3rd.
Originally Posted by Mandinca View Post
I get clouds at WOT but none at idle. The clouds go away after a few bursts of WOT until after I have cruised for a while. Then if I mash it again the clouds are back. I use a qt every 200 miles so I'm assuming the CATS are hiding the oil usage (no blue smoke) then blasting it out when I mash it.
Anyway, enough thread hijacking from me.
My oil burning caused my EGR to become almost completely clogged and foul my plugs every 2000 miles. I haven't looked at the EGR valve itself but the port in the IM gets almost completely blocked with gunk. I have to pull the IM to clean it out. PITA.
If you haven't done it before there are some good write-ups on how to do it - I can send you the one I used which is very good.
The first time I did it it took me about 6 hours. I have it down to under 3 now.
An air ratchet helps to speed things up.
Turbo replacement is a bit more complicated and near impossible if you have a MS6 since the transfer case obscures the oil return bolts on the underside of the turbo. The 3 is easier because you can see them from under the car.
Both jobs require a few tools but nothing very unusual or expensive.
I found that I used the following :
Screwdrivers
Pliers
Deepwell metric sockets (up to 14mm)
Regular metric sockets
Flex head ratchet wrenches (very useful) – Harbor Freight sell them for a good price
A 22mm open head wrench (for the EGR flange nut at the IM)
Various size extensions
Universal joint for your socket set up
Floor stands and O2 sensor removal tool if you plan on doing the turbo
Gloves (or extra skin for your knuckles)
A five gallon bucket of patience.
yeah those symptoms sound like blow by. I had the same thing when the ring lands in my toyota went, smoked bad under WOT, gushed oil etc etc
As far as the labor goes it can't be that bad. I'm coming from 3000GT/Stealth TT AWD V6. Done turbo swaps and all sorts of other mods on those. Also did full motor swap by hand on my toyota, tore down motor etc. MS3 is on the "easier" side by comparison. I've also read the write ups on how to media blast the valves clean, I got a compressor finally and just need the media blaster kit from harbor freight and a free saturday.
I'll check back in once we clean things up a bit and do some further testing. Thanks again for the replies guys.
randomtask16 is offline   Reply With Quote
 Old 05-22-2014, 10:47 AM   #82
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
A word of warning for those under warrantee:
Take out the bnoon bolt before you take your car in !
I had the ptp pill & bnoon bolt, no smoke for a long time but @100K it turned into a crop duster after idling for 30 seconds or more. I had an extended warrantee and I had to provide ALL oil change records and it got approved for a new turbo. The service guy told me the bnoon bolt (forgot to take it out) caused the turbo to fail and I'm lucky that it got fixed under warrantee.
So make sure you have ALL your oil change records and NO bnoon bolt installed when it goes to the dealer !!!!!
FYI the dealer charges about $2300 for a new turbo (installed).
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to flyrevs2 For This Useful Post:
ItsNox (05-26-2014), Mattyhawk1 (05-22-2014)
 Old 08-11-2014, 07:52 AM   #83
10 month update :
She decided to spend the money at the dealer for the updated pcv/valvecover setup as well as vvt chatter fix. Vvt chatter went away, but smoking came back pretty quick. The AC bearing also went bad and was driven bad for some time which resulted in the entire clutch assembly being trashed. I'm amazed it didn't seize and burn the belt off after seeing it.
Ordered a BNR stage 1 and new AC compressor to get it back on the road and hopefully finally rid of the smoke, then selling it since we still have my Genpu MS3 and want an suv, no need for 2 of the same car.
 Old 08-12-2014, 06:48 AM   #84
kpuser1's Avatar
Posts: 91   (View Stats)
kpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond repute
10 month update :
Yeah I had the valvecover done also but it lasted me about 40k miles. I just ordered a bolt and hope that works, if not i'm thinking bnr also. Good luck..
Cosmic Speed3 - Cobb AP | JBR Tru-3.0 Intake | EBay Racepipe | MD OCC | Eibach | Enkei | Aeroforce Interceptor gauge | JBR SS, Knob, PMM, RMM, TMM, RSB...
kpuser1 is offline   Reply With Quote
 Old 09-12-2014, 06:38 AM   #85
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Originally Posted by HaXiR View Post
How much does the dealer charge for the PCV fix? I'm at 80k miles out of warranty and I'm getting turbo smoke now that I put my test pipe on. Ordered a bolt and having my tuner up my idle. I wouldn't mind getting the pcv fix though either.
and what was the difference between the "new" turbo they put on vs. what came with it?
I dont know about the pcv fix, I did mine myself. I believe the new turbo is just a KO4 with better seals.
Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM
Mandinca is offline   Reply With Quote
 Old 09-13-2014, 07:42 AM   #86
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
I don't think the K04 have better seals. I remember that the orifice holes in the oil banjo bolt was changed.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/smoke-idle-fixes-my-thoughts-notes-76005/
Mazda 3 MPS - Smokey exhaust - Page 1 - Jap Chat - Pistonheads This thread Refback 11-01-2015 04:17 AM
Mazda 3 MPS - Smokey exhaust -  Gassing Station - PistonHeads This thread Refback 09-08-2015 12:22 AM
HSV & Monaro Forum This thread Refback 02-16-2015 06:27 AM
Stage 3, Blown Turbo Seal, now what?? - Page 4 Post #31 Pingback 11-10-2014 06:08 PM
Central Ohio Chat Thread - Page 18 Post #31 Pingback 06-11-2014 08:25 AM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 03-28-2014 09:42 PM
Mazda 3 MPS - Smokey Auspuff - Pistonheads This thread Refback 01-14-2013 10:20 AM
Mazda 3 MPS - Smokey exhaust - PistonHeads - PistonHeads mobile This thread Refback 12-20-2012 09:58 AM
MPS 6 / tyhjäkäynnin kierrosten nosto (versatuner tms?) This thread Refback 12-20-2012 06:13 AM
Mazda 3 MPS - Smokey exhaust - PistonHeads This thread Refback 12-16-2012 12:20 PM
Mazda 3 MPS - Smokey exhaust - PistonHeads This thread Refback 11-12-2012 12:05 PM
Mazda 3 MPS - Smokey exhaust This thread Refback 07-16-2012 02:10 AM
Mazda 3 MPS - Smokey exhaust This thread Refback 04-06-2012 09:46 AM
Mazda 3 MPS - Smokey exhaust - PistonHeads mobile This thread Refback 04-02-2012 01:21 PM
Mazda 3 MPS - Smokey exhaust This thread Refback 04-01-2012 01:09 PM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
Thoughts on venting the oil return line, another possible smoke fix? bnoon MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-10-2010 09:36 AM
idle smoke getting serious Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 16 11-03-2010 01:43 PM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.28492 seconds with 24 queries
