![]() Join Date: Jun 2013 Location: DFW
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score
She decided to spend the money at the dealer for the updated pcv/valvecover setup as well as vvt chatter fix. Vvt chatter went away, but smoking came back pretty quick. The AC bearing also went bad and was driven bad for some time which resulted in the entire clutch assembly being trashed. I'm amazed it didn't seize and burn the belt off after seeing it. Ordered a BNR stage 1 and new AC compressor to get it back on the road and hopefully finally rid of the smoke, then selling it since we still have my Genpu MS3 and want an suv, no need for 2 of the same car. | |
![]() Join Date: Jan 2010 Location: Central Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 48
__________________ Cosmic Speed3 - Cobb AP | JBR Tru-3.0 Intake | EBay Racepipe | MD OCC | Eibach | Enkei | Aeroforce Interceptor gauge | JBR SS, Knob, PMM, RMM, TMM, RSB... | |
![]() Join Date: May 2009
Rep Power: 371 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score A word of warning for those under warrantee: Take out the bnoon bolt before you take your car in ! I had the ptp pill & bnoon bolt, no smoke for a long time but @100K it turned into a crop duster after idling for 30 seconds or more. I had an extended warrantee and I had to provide ALL oil change records and it got approved for a new turbo. The service guy told me the bnoon bolt (forgot to take it out) caused the turbo to fail and I'm lucky that it got fixed under warrantee. So make sure you have ALL your oil change records and NO bnoon bolt installed when it goes to the dealer !!!!! FYI the dealer charges about $2300 for a new turbo (installed).
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
| The Following 2 Users Say Thank You to flyrevs2 For This Useful Post: | ItsNox (05-26-2014), Mattyhawk1 (05-22-2014) |
![]() Join Date: Oct 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 603
| Not Ranked : 0 score I don't think the K04 have better seals. I remember that the orifice holes in the oil banjo bolt was changed.
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP RPM: Sport Springs, Shark Fin, LED side markers CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM | |
| Display Modes | |
| smoke on idle? | kraz3y | MazdaSpeed 3/6 - Turbo Induction | 20 | 01-09-2013 03:26 AM |
| Thoughts on venting the oil return line, another possible smoke fix? | bnoon | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 12-10-2010 09:36 AM |
| idle smoke getting serious | Chriscote | MazdaSpeed 6 - Engine, Transmission & Driveline | 16 | 11-03-2010 01:43 PM |
| Smoke at idle | sleeper329 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-13-2010 01:56 PM |
| smoke at idle | ms3-87 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 05-31-2008 01:15 PM |
