| Not Ranked : 0 score i wish the updated one works. I was wondering if the pump could push air also or just the oil. I didn't see the type of pump head....And despite it is self priming, it may need to accumulate enough liquid before being able to push it away and only generate vacuum when there is enough oil in it... You can monitor the pump current with a device like that. https://www.nktechnologies.com/curre...sing-switches/ IT will let you know if the pump current fail below the threshold. regardless of it is from a short that blow the fuse or if it is an open circuit by a broken wire or burned motor... For the oil return, you may weld a T at the turbo return or dril one in the pan....
| GB smoking turbo fix!!! | ptperformance | Mazdaspeed3/6 General Discussion | 654 | 11-26-2013 08:31 AM |
| Smoking turbo | Reginspeed6 | Mazdaspeed3/6 General Discussion | 8 | 03-08-2013 11:16 AM |
| Causes/Solutions: Smoking turbo after DP Install | kgb | MazdaSpeed 3/6 - Turbo Induction | 28 | 02-25-2009 10:58 AM |
