  • 2 Post By Downmented
 Old 10-16-2014, 07:16 PM   #1
frankc730's Avatar
Posts: 115   (View Stats)
frankc730 will become famous soon enough
Groaned at 9 Times in 5 Posts
Default some thoughts for a ms6 exhaust system
buying a tbe and can't decide between the corksport tbe or a atp catted dp/cpe catted down pipe with the cpe dual exit. is the second setup really worth the extra money ? which would sound better ?
frankc730 is offline   Reply With Quote
 Old 10-17-2014, 02:40 AM   #2
cciepunk's Avatar
Posts: 181   (View Stats)
cciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the worldcciepunk is the leader of the world
Groaned at 43 Times in 42 Posts
Cpe quality is really good and worth the extra money IMHO. It sounds great too. Never used the other ones, so I can't compare them.
cciepunk is offline   Reply With Quote
The Following User Says Thank You to cciepunk For This Useful Post:
HBspeed (10-22-2014)
 Old 10-17-2014, 08:13 AM   #3
frankc730's Avatar
I see u got the cpe catted dp. Did your turbo smoke at all
 Old 10-17-2014, 09:28 PM   #4
cciepunk's Avatar
Turbo hasn't smoked yet.
 Old 10-19-2014, 06:55 PM   #5
MBalik's Avatar
Posts: 500   (View Stats)
MBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the world
U want a high flow cat on ur dp to keep it that way
2013 White Pearl Pu
Back to stock.... for now
MBalik is offline   Reply With Quote
 Old 10-19-2014, 07:27 PM   #6
frankc730's Avatar
yea i was thinking of getting the one with a cat but i got a buddy who's got a ms3 stock turbo no cats and doesn't smoke at all never has got like 80k on it too
 Old 10-17-2014, 02:56 AM   #7
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
I personally run a CPE single exit, and im in love with its tone.
Raider and MarineMazda like this.
700HP CLUB
11.479@124mph
#DIX
The Following 2 Users Say Thank You to Downmented For This Useful Post:
Hammology (10-17-2014), MarineMazda (10-17-2014)
 Old 10-17-2014, 03:25 AM   #8
MarineMazda's Avatar
Posts: 354   (View Stats)
MarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the worldMarineMazda is the leader of the world
I run a CPe Single exit with PERM non-catted DP and the Car sounds awesome. Might throw a extra resonator in it this winter to help with HWY drone tho (Drone is to be expected on any straight pipe exhaust).
MarineMazda is offline   Reply With Quote
The Following User Says Thank You to MarineMazda For This Useful Post:
Downmented (10-17-2014)
 Old 10-17-2014, 03:41 AM   #9
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
CPE single exit, and a ebay dowpipe if you dont care about emissions.
Built motor
GTX3071
Meth
6th Port
 Old 10-17-2014, 05:28 AM   #10
frankc730's Avatar
Now which setup is the least likely to smoke my turbo ? Now Ik its inevitable if the turbo seals are already bad but I want to keep it from not smoking
The Following User Says NO Thank You to frankc730 For This Un-useful Post:
 Old 10-17-2014, 08:55 AM   #11
robertof's Avatar
Posts: 405   (View Stats)
robertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the world
I have a cpe single exit with a muffler, resonator and test pipe and it sounds awesome, no drone whatsoever and very mellow while cruising. I'm going to install a cpe catted down-pipe.
robertof is offline   Reply With Quote
 Old 10-17-2014, 01:34 PM   #12
igve2shtz's Avatar
Posts: 72   (View Stats)
igve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant futureigve2shtz has a brilliant future
I had a stock DP, Corksport 3" resonated test pipe, and the Corksport 3" dual exhaust. I got alot of compliments on the sound, mostly from STI owners. Sounded great outside the car, but it was pretty loud on the inside. And it shakes the house windows in the winter time when I start the car to let it warm up.
2006 MS6 Velocity Red Mica
SP63 built motor - SP63 9.5:1 Pistons - Manley Rods - JBR TRU-3" intake - BNR S3 - ETS 3.25" TMIC - Cobb XLE BPV - SP63 IM Port n' Polish - JBR TB TIG - JBR IM TIG - 3 Bar PnP (RPM) MAP - Autotech HPFP Internals - cp-e SafeSeals - NGK Plugs - Streetlite Flywheel - ACT 6 Puck Clutch - GrimmSpeed EBC - BSD - cp-e Catted Downpipe - Magnaflow CBE - cp-e RDM - cp-e Motor Mount - BC Coilovers - 215/45/18 Kuhmo 4x All-Season - Cobb Accessport V2- Prosport Premium Boost Gauge - Vent Pod - Dashhawk - Audiolink iPod Adapter
igve2shtz is offline   Reply With Quote
 Old 10-17-2014, 01:37 PM   #13
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I paid like $300 or $400 bucks for a shop to build me a 3" to dual 2.5" y-pipe + magnaflow mufflers, it sounds amazing and it was made for my car.
Catback is going to have very minimal effects on turbo backpressure.
MINI H1 6.0 - CAR LED TAILS
 Old 10-17-2014, 01:42 PM   #14
[R]usty's Avatar
Posts: 2,204   (View Stats)
I'm with Dale on this one. The MS6 exhaust is easy to fabricate. Get it custom made save tons of money.
2010 Mazdaspeed3 w/tech
 Old 10-19-2014, 07:27 PM   #15
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Just wanted to throw this out there, since the y-pipe was hard to track down...
I ordered a 3"IN/OD Y-pipe from
Chad Krueger
Big Rig Chrome Shop, Inc
3735 South Washburn St
Oshkosh, WI 54904
(920)769-0611 x105 / 1-800-714-6093 x105
Big Rig Chrome Shop - Semi Truck Chrome Shop, Truck Lighting and Chrome Accessories
chad@bigrigchromeshop.com
and a spring bolt 3" flange from ebay for $40
added a couple magnaflow 14" mufflers and $350 later got it installed at a local shop.
3" front to back
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following 2 Users Say Thank You to ms6mil For This Useful Post:
cocoanton (06-01-2015), mxlplx71 (10-19-2014)
 Old 10-19-2014, 07:49 PM   #16
frankc730's Avatar
i really just want to get the atp catless cause if my turbo smokes without cats means having a cat woulda just covered it up so why not save the money to put towards new turbo
 Old 10-20-2014, 06:27 AM   #17
MBalik's Avatar
Not necessarily. Your seals might still be good.
2013 White Pearl Pu
 Old 10-20-2014, 08:48 AM   #18
frankc730's Avatar
I'm pretty sure they are still good I've let it idle for 15-20 min and never seen any sort of smoke.i would like to take the second cat off and see it would give me a better indication
 Old 10-20-2014, 10:04 AM   #19
MBalik's Avatar
U can delete the second cat it's as long as u still have ur main cat. You can replace it with a high flow cat to minimize the chances of your turbo smoking. Going catless increases the chance of that happening greatly
2013 White Pearl Pu
 Old 10-20-2014, 10:33 AM   #20
frankc730's Avatar
Yea it just sucks cause I'm gunna prolly spend the extra money for a cat and if it ends up smoking kinda wasted the extra money but I get what ur sayin
 Old 10-22-2014, 08:03 AM   #21
HBspeed's Avatar
Posts: 74   (View Stats)
HBspeed is a splendid one to beholdHBspeed is a splendid one to beholdHBspeed is a splendid one to beholdHBspeed is a splendid one to beholdHBspeed is a splendid one to beholdHBspeed is a splendid one to beholdHBspeed is a splendid one to behold
For this I've got full cpe, with cpe downpipe, dual exit exhaust , high flow cat, sounds great & great performance. As far as the notorious smoking problem when putting on a bigger downpipe and bigger exhaust with a stock turbo, it is hit and miss if u will have the problem, but if you do the best way to get rid of it IMHO is to bring your idle up. I smoke pretty bad originally, but after bumping up the RPM at idle I rarely if ever see smoke, and she sounds better a couple hundred rpm higher.
HBspeed is offline   Reply With Quote
 Old 10-22-2014, 08:07 AM   #22
frankc730's Avatar
Yea so either way cats or no cats it may smoke so I mean I don't really see a problem going catless other than it being loud as fuck
Is the dual exit "quiet" like cpe says it is
 Old 10-22-2014, 08:16 AM   #23
HBspeed's Avatar
And yes I went through all of the other fixes of banjo oil restricter bolt (~$20), heavier oil (Rotella 5w-40), turbo seals were replaced twice, and there was a recall fix on some models that I had done... None of them worked. I took the car to the dealer for some warranty stuff and they performed an unsolicited oil change for me and put in their normal oil. That was the only time I smoked after I bumped up my idle. So I have seen a direct correlation to oil type and idle rpm. The oil restricter bolt may or may not be doing anything.
 Old 10-22-2014, 09:11 AM   #24
frankc730's Avatar
Just curious do u have a TIP that has the breather tube that's runs from the valve cover to it I heard that eleviates some pressure cause I got that and I'm wonder if it will help
 Old 10-22-2014, 08:28 AM   #25
HBspeed's Avatar
The dual is manageable... Still aftermarket deep beautiful sound, but not nearly as loud as most aftermarket exhausts and daily driveable IMHO
 Old 10-22-2014, 10:11 AM   #26
HBspeed's Avatar
Yeah, I have the CPE Nviscid TIP with CPE XcelXL air intake
Exhaust System RaceTech_mzr Gen2 MS3 General Discussion 37 07-01-2012 11:11 AM
Exhaust System RaceTech_mzr Mazdaspeed3/6 General Discussion 10 06-07-2012 06:33 PM
Exhaust System Matx MazdaSpeed 6 - Engine, Transmission & Driveline 19 04-13-2010 12:45 PM
PTP's CAT back exhaust system, soon to be TBE system. ptperformance Mazdaspeed3/6 General Discussion 56 10-05-2008 02:08 PM
Page generated in 0.44477 seconds with 31 queries
