 Old 03-25-2008, 11:04 AM   #1
MisterMatt's Avatar
Posts: 45   (View Stats)
MisterMatt has a spectacular aura aboutMisterMatt has a spectacular aura about
Default Someone tell me what this is?
This has happened a couple times. curious what it is.
i'll be driving along and stomp on it and as its fighting for traction i'll hear the bypass valve psshh several times without me lifting off the gas.
lemme impersonate it with my mouth
errrrrrrrrrrrrrr pshhhhh..pshhhhhh....errrrrrrrrrrrrrrr (use your imagination)
i just have the cobb sri and corksport test pipe.
MisterMatt is offline   Reply With Quote
The Following User Says Thank You to MisterMatt For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 11:36 AM   #2
Are you bouncing off the rev limiter while losing traction?
 Old 03-25-2008, 11:36 AM   #3
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
THATS YOUR DSC kicking in dynamic stability control bleeding off boost, when u loose traction...
 Old 03-25-2008, 11:37 AM   #4
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
boost cut/fuel cut laloosh even has vid when it happend to him
NYpest is offline   Reply With Quote
 Old 03-25-2008, 11:43 AM   #5
gsrtype1's Avatar
Groans: 102
na its the dsc kicking in bleeding boost
 Old 03-25-2008, 11:46 AM   #6
NYpest's Avatar
step away from the "fosters" lol
 Old 03-25-2008, 11:57 AM   #7
gsrtype1's Avatar
Groans: 102
....lol
 Old 03-25-2008, 11:50 AM   #8
NYpest's Avatar
does it look and sound like this (chris vid)
 Old 03-25-2008, 11:54 AM   #9
gsrtype1's Avatar
Groans: 102
he said its when he looses traction its goes phssssh and here hereits comeing out of the bpv thats the dsc.. unless his dcs is off could be fuel cut but sounds like dsc
 Old 03-25-2008, 11:56 AM   #10
NYpest's Avatar
he said
i'll be driving along and stomp on it and AS its fighting for traction
 Old 03-25-2008, 11:57 AM   #11
NYpest's Avatar
Could be right!! i doubt it
 Old 03-25-2008, 01:24 PM   #12
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
Groans: 70
he is right,happedns to me all the time,its just the dsc kicking in
Grim is offline   Reply With Quote
The Following User Says Thank You to Grim For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 12:42 PM   #13
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
its definately boost cut/fuel cut, same thing happened to me the other night. i have data logs of it.
The Following User Says Thank You to bova For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 12:49 PM   #14
gsrtype1's Avatar
Groans: 102
you think that cuase u don't experiance traction issues 4whd with fuel cut u don't get pshhhh out th bpv.... like he is getting , like i get when i floor it in second with the dsc on, dsc light blinks and u can hear pshhh out the bpv bleeding boost
 Old 03-25-2008, 12:54 PM   #15
NYpest's Avatar
Boost cut !!!!!!
 Old 03-25-2008, 01:11 PM   #16
bova's Avatar
Groans: 45
dude the bypass valve is going off because the throttle plate is closing and the boost is bleeding off.
maybe if he stated what gear he was in and what rpm it happend at it could be diagnosed better.
NYpest (03-25-2008)
 Old 03-25-2008, 01:22 PM   #17
gsrtype1's Avatar
Groans: 102
i never hear phsshhhhh during boost/fuel cut..., BUT when i lose traction with the dsc on it goes pshhhhhhh...pshhh
 Old 03-25-2008, 01:31 PM   #18
NYpest's Avatar
hmmmmmm? na i still think its boost cut
 Old 03-25-2008, 01:47 PM   #19
Grim's Avatar
Groans: 70
lol
 Old 03-25-2008, 01:56 PM   #20
bova's Avatar
Groans: 45
ha well then i guess it sucks to have fwd if your dsc kicks in like that.
NYpest (03-25-2008)
 Old 03-25-2008, 02:17 PM   #21
NYpest's Avatar
AWD FTW
 Old 03-25-2008, 02:30 PM   #22
bova's Avatar
Groans: 45
haha boo yeah grandma except we weigh more so thats the only let down.
NYpest (03-25-2008)
 Old 03-25-2008, 02:36 PM   #23
NYpest's Avatar
take out the rear seats !!!!!!!
 Old 03-25-2008, 03:11 PM   #24
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
i say he needs new spark plugs and pulled coils.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
The Following User Says Thank You to mrlilguy157 For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 03:15 PM   #25
gsrtype1's Avatar
Groans: 102
yall go out on a semi slipery suface turn the radio off, turn the dsc on, roll down the windows and floor it in 1st and 2nd.. then yall will see what he is talking about.. pshh...pshhh as the tries break loose and the dsc kicks in..
The Following User Says Thank You to gsrtype1 For This Useful Post:
NYpest (03-25-2008)
 Old 03-25-2008, 03:18 PM   #26
NYpest's Avatar
not me FORGE BPV FTW!!!!!!!
 Old 03-25-2008, 03:39 PM   #27
Grim's Avatar
Groans: 70
well then take out"pshhhh pshhhh" and insert"clankkkk cllaankkk"
NYpest (03-25-2008)
 Old 03-25-2008, 04:07 PM   #28
bova's Avatar
Groans: 45
who is to say he is on a slippery surface?
 Old 03-25-2008, 03:57 PM   #29
NYpest's Avatar
so true so sad she may hold boost but sounds like 2 old bittys clinking tea cups
 Old 03-25-2008, 04:11 PM   #30
gsrtype1's Avatar
Groans: 102
it doesn't have to be on a slippery surface i was just saying that will garentee the effect, mine does it on most roads in second gear...
 Old 03-25-2008, 04:17 PM   #31
NYpest's Avatar
Im not saying you are wrong at all!
I have been in that situation with my MS3 and have not encountered the described above.
Its just my opinion that its Boost cut....... lol
 Old 03-25-2008, 04:19 PM   #32
gsrtype1's Avatar
Groans: 102
you ddin't experiance it cuase u were not listening closley...thats why i said roll down the windows and turn down the radio u will here it...
 Old 03-25-2008, 04:22 PM   #33
NYpest's Avatar
next time i will listen for it ......weid though i can hear my FORGE BPV over my radio....
 Old 03-25-2008, 04:24 PM   #34
gsrtype1's Avatar
Groans: 102
some times it is more pronounced then others.. don't realy knkow why?? but if yur on a slippery surface and start to floor it should go crazy...
 Old 03-25-2008, 05:01 PM   #35
MisterMatt's Avatar
happens usually in lower gears and more than likely with dsc on (i dont remember about the dsc). i thought fuel cut feels like you hit a wall and i sure dont feel that.
noob question alert!
how and why does boost cut happen?
 Old 03-25-2008, 05:32 PM   #36
NYpest's Avatar
did you watch the vid ??
 Old 03-25-2008, 05:55 PM   #37
MisterMatt's Avatar
yes, its not boost cutting because its cold. i live in houston. what other reasons are there?
 Old 03-26-2008, 08:33 AM   #38
gsrtype1's Avatar
Groans: 102
see if it does it with th dsc off... its the dsc dude. hey i live in the woodlands wich side of town do you live on? theres a big speed cruise to galveston this weekend
 Old 03-26-2008, 10:53 AM   #39
Grim's Avatar
Groans: 70
maby it only happens to people in texas lol,we seem to be the only ones this has happend to.
 Old 03-26-2008, 02:29 PM   #40
MisterMatt's Avatar
im in league city, i might make it to the cruise
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/someone-tell-me-what-442/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-25-2008 11:37 AM
Page generated in 0.56571 seconds with 25 queries
