 Old 04-10-2017, 08:42 PM   #1
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Default Source for recirc hose
I have the ST manifold installed on my speed 3 and I had to do some custom cold side pipes obviously so my bpv is down near the ground and my HTP 4" intake's recirc port is pretty far away, so much so that any standard recirc hose is far too short. I tried a hose place here in town (All Hose) and they don't have 1 1/4" silicone hose that out cars use. Does anyone know where I can get a large chunk, say 2 to 3 feet of just silicone recirc hose I can cut to fit. Would be a bonus to get an orange one if possible.
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 04-10-2017, 09:22 PM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
I can't remember where I ordered mine, just google it, where I got it from you can buy it by the inch.
2010 black mica speed3
Soon:built motor
 Old 04-10-2017, 10:39 PM   #3
HaXiR's Avatar
cool thanks, ive done some googling and trying to find something
Current:
 Old 04-11-2017, 07:46 AM   #4
Djohns's Avatar
https://www.siliconehose.com/silicone-straight-hose/ Here ya go bud.
Soon:built motor
 Old 04-11-2017, 09:00 AM   #5
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
The oem is 1 1/8" so i used as mentioned above 1" silicone heater hose. Use some silicone spray and work it on but it will work.
Why orange i doubt you will even see it.
MECP
2012 BM
Rfinkle tune in progress
 Old 04-16-2017, 08:28 PM   #6
HaXiR's Avatar
Orange because my Htp intake will have the hose very visible and it will match my VC. And ok, 1 1/8" ill look.
Thanks bruh, ill give em a call or whatever and see if they can help me out
Current:
Last edited by HaXiR; 04-16-2017 at 08:28 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-16-2017, 08:30 PM   #7
AwAfrican's Avatar
Posts: 1,038   (View Stats)
You can always just buy heater hose from Napa that's all that the OEM one is
2013 Black MS3
 Old 04-16-2017, 09:46 PM   #8
Ziggyboy's Avatar
Posts: 239   (View Stats)
Ziggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the world
pegasusautoracing.com
Everything you should need to get the job done. This is the site I used for my Ford manifold adventure. I used the aluminum joiner to peace together a clean look. Good quality and prices were decent.
2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it
Ziggyboy is offline   Reply With Quote
HI! MS3 recirc. hose Jasnall Mazdaspeed3/6 General Discussion 9 06-09-2008 09:46 PM
Page generated in 0.30199 seconds with 24 queries
