 Old 09-16-2011, 11:56 AM   #41
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Sorry guys I can't post it I'll be rocking the iPhone until tuesday
 Old 09-16-2011, 12:00 PM   #42
When I get home, I'll post those tables.
If necessary, you can give the values per rpm column, boost error etc. via tapacrap.
 Old 09-16-2011, 12:27 PM   #43
TWOptSL0W's Avatar
Groans: 125
I don't haz atr app on iPhone they should get that shit @Cobb Tuning I have an idea gimme 10% now
 Old 09-16-2011, 02:44 PM   #44
mdd5148's Avatar
Posts: 303   (View Stats)
mdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the world
Yea I know them but is there a vendor that sells them any cheaper? Not being cheap I'm just not trying to spend money uselessly
GrimmSpeed Boost Solenoid Mazdaspeed3 2007-2009 at RallySportDirect.com
I picked mine up here. Its a few bucks cheaper.
2005 Porsche 911 - Pure Sex
Staggered 19" HRE P47's
2007 Mazdaspeed6 GT - #10318 - Sold
AWR Passenger Side Mount | AWR Transmission Mount | CPE RMM | CPE Intake | CPE Inlet | CPE Downpipe | CPE Catback | CPE Fuel Pump | CPE Manifold | TIAL 44mm Wastegate | Grimmspeed EBCS | Custom FMIC | HKS BOV | GT3076 | Cobb AP | Labonte Stage 2 meth | TWM Stage 2 Short Shifter | VEI boost gauge | CPE Tow Plate | LED Tail Lights | LED Mirrors | CX7 Antenna | 18x8.5 Rays Gram Light 57F
2006 Miata Sport - She took it...
Stock For Now...
mdd5148 is offline   Reply With Quote
 Old 09-17-2011, 06:55 AM   #45
Sorry about not posting the tables last night.
SSinstaller (09-17-2011), TWOptSL0W (09-20-2011)
 Old 09-17-2011, 09:12 AM   #46
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Somethings off here. If the boost error ramp limiter max is 10%, and the base WGDC is 52% at 4000rpm, why is the log showing 98% WGDC at 4K? If I had to guess I'd say the ECM is targeting a load that's unattainable at that point...
Do NOT got WOT again.. IMO the shitty OEM EBCS is the only thing saving you from even bigger spikes...
Is this a boost targeting tune? Are the RPM comp tables set to -90 and 10 like they should be?
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
Fobio (09-17-2011), rfinkle2 (09-17-2011)
 Old 09-17-2011, 12:31 PM   #47
TWOptSL0W's Avatar
Groans: 125
not sure where you got that from but that is NOT my wgdc table. basically mine is zero everything before a low throttle position like 25 or something then all 80 before 3k and then its 100 between 3k and 5k then goes i think 80->50->30->0
 Old 09-17-2011, 12:41 PM   #48
Groans: 60
You need to change that.. I don't need to see anything else to know that those WGDC values are way off..
Next chance you get set 1K-3K to 100%, 3.5K to 70%, and 4k-redline to 35%, and post the log
 Old 09-17-2011, 02:03 PM   #49
TWOptSL0W's Avatar
Groans: 125
I had it at 70 but I wasn't reaching my target boost. I'm thinking crappy oem solenoid can't keep up. When I get a chance I'm going to check if the iwg is stuck and order a grimmspeed
 Old 09-17-2011, 03:29 PM   #50
When you said that you could not post pics, because you were using your phone to access msf, I thought we agreed that you would let ssinstaller know what wgdc you were running per rpm.
I posted the wgdc table for reference.
It wasn't my intention to cause any confusion, just to have a visual reference.
Get off your phone if you want help with your map.
 Old 09-17-2011, 03:39 PM   #51
Groans: 60
Can anyone viewing this thread open TWOptSL0W's map and post all the WG tables in here..
 Old 09-17-2011, 03:57 PM   #52
TWOptSL0W's Avatar
Groans: 125
I can't I'm in georgia until Tuesday for a funeral...fuckin 14 hour drive
 Old 09-17-2011, 06:02 PM   #53
Oh boy,,, now I feel awful.
My apologies for your loss, and please be safe.
 Old 09-17-2011, 07:17 PM   #54
TWOptSL0W's Avatar
Groans: 125
its all good ill try to get them up tuesday ....how did you get nice cut pictures of the tables? can you export them or something or did you just clean up a print screen?
 Old 09-17-2011, 07:36 PM   #55
Groans: 60
Just print screen and crop it in paint.
 Old 09-17-2011, 07:39 PM   #56
TWOptSL0W's Avatar
Groans: 125
ok thats what i figured i just wasnt sure. ill get that on tuesday, but the more i think about it, the more i think my wastegate is stuck shut
 Old 09-20-2011, 04:39 PM   #57
TWOptSL0W's Avatar
Groans: 125
heres my wgdc, i dont remember why i had the lower rpms as 80, but i think there was a reason. either way, these numbers were working fine for me, but i think my wg is just stuck now. i went ahead and ordered me a grimmspeed ebc so ill have to make a new one anyway
The Following User Says Thank You to TWOptSL0W For This Useful Post:
rfinkle2 (09-20-2011)
 Old 09-20-2011, 05:32 PM   #58
You can also use the wgdc boost error comp (overboost portion) table if you want to try keeping some of the table populated.
 Old 09-20-2011, 06:52 PM   #59
TWOptSL0W's Avatar
Groans: 125
well i solved my problem...the wastegate was stuck shut. i'm going to have to mess with it this weekend and see what i can do with it, but i muscled it open and now it works fine so i dunno. im still going to go with the grimmspeed in interrupt mode so that i will have faster spool because the stock solenoid isnt cutting it. now i need to make tables for that...
edit...spoke too soon, its stuck again. ill have to take it apart this weekend
 Old 09-24-2011, 11:02 PM   #60
TWOptSL0W's Avatar
Groans: 125
well heres your problem...
The Following 3 Users Say Thank You to TWOptSL0W For This Useful Post:
Fobio (09-24-2011), rfinkle2 (09-25-2011), skeurton (09-24-2011)
Log from today Ex_WRX_driver 2010 MS3 - ECU Computer Tuning 1 07-02-2011 11:40 AM
Today or Later? Stealth01 MazdaSpeed 3/6 - Suspension & Brakes 6 02-26-2011 05:22 PM
CEL today PheOniX MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 04-05-2010 09:47 AM
Overboosting 25psi on Stock Tune!? SoyBean MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 11-23-2009 02:50 PM
411whp with gt3076 @ 25psi... howd he do it phailerider MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 01-05-2009 01:32 PM
Page generated in 0.46536 seconds with 24 queries
