 Old 08-09-2011, 08:32 AM   #1
CTSpd6's Avatar
Posts: 143   (View Stats)
CTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond reputeCTSpd6 has a reputation beyond repute
Default Stock BPV question
At what point is the stock BPV not able to hold boost. I recently flashed the Stage 1+SF 93 map and i did a couple WOT pulls. When i got to around peak boost, i would hear this high pitch noise like an air horn. I only hear it when i'm WOT and at/near peak boost and that's why i'm thinking its the stock BPV. How much boost can it handle?
2006 Mazdaspeed 6 | MS CAI | DP | TP | AP
CTSpd6 is offline   Reply With Quote
 Old 08-09-2011, 08:33 AM   #2
WorstEpEver's Avatar
Posts: 418   (View Stats)
WorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the world
Since you have AP, do some logs at WOT. You will be able to see if it's holding boost or not.
If you hear a whoosh go off before you lift, it probably is the stock bpv however.
09 MGM Sport
AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB
WorstEpEver is offline   Reply With Quote
The Following 2 Users Say Thank You to WorstEpEver For This Useful Post:
Broxer (08-09-2011), CTSpd6 (08-09-2011)
 Old 08-09-2011, 08:35 AM   #3
That sounds like a boost leak for sure, although some logs might help as worst ep said.
Some stock bpvs leak, others don't.
If you can do a boost leak test, you will be able to get an idea what the noise is / coming from a little better.
BlueStreak (08-09-2011), Broxer (08-09-2011), CTSpd6 (08-09-2011), LuczOr (08-10-2011)
 Old 08-09-2011, 08:37 AM   #4
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
My stocker has been able to hold 20psi without an issue. A high pitched noise could be a boost leak, not necessarily from the BPV.
The only issue I've had with my stock unit is that it opens during partial throttle during slow acceleration.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following 2 Users Say Thank You to Broxer For This Useful Post:
CTSpd6 (08-09-2011), rfinkle2 (08-09-2011)
 Old 08-09-2011, 08:40 AM   #5
ZsSpeed3's Avatar
Posts: 150   (View Stats)
ZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant futureZsSpeed3 has a brilliant future
I'm using the stocker right now, no issues for me and reaching 15psi yesterday.
Edit: not pushing
09 Black Mica MazdaSpeed 3
Mods: SURE Aeros, SURE Return, SURE Countershift, SURE Anchors, TRZ Dogbone RMM, E4 Perfomance STS, PG Test Pipe, H&R Sport Springs
Appearance: Xentec HID Kit 35W 8K, Independant Fogs, 15% Tint, Blacked out LED Side Markers, LED License plate lights, Blacked out emblems, Smoked Taillights, Blacked out third brake light
ZsSpeed3 is offline   Reply With Quote
 Old 08-09-2011, 08:44 AM   #6
Blue 2 shims
Nazarite's Avatar
Posts: 2,254   (View Stats)
Groans: 66
@ZsSpeed3 then you've got a problem because stock you should be at 15.4. @Broxer I'm spiking 21 and holding 19 on the stock bpv as well. @CTSpd6 everyone's is different like these guys are saying. Some hold, some don't, only your logs can tell you what your case is.
Nazarite is offline   Reply With Quote
The Following 3 Users Say Thank You to Nazarite For This Useful Post:
Broxer (08-09-2011), mazdaspeed619sd (08-22-2011), rfinkle2 (08-09-2011)
 Old 08-09-2011, 08:46 AM   #7
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Originally Posted by ZsSpeed3 View Post
I'm using the stocker right now, no issues for me and I was pushing it to 15psi yesterday.
Pushing it to 15psi lol
All in all, as others have mentioned, some stockers hold incredibly adequate while others take a face plant..
With that said, you need a monitoring device, go through all your piping and make sure everything is tight. While all the signs lead to a boost leak, that doesn't necessarily mean its a BPV leak.
Good Luck
The Following 3 Users Say Thank You to helmetface For This Useful Post:
Broxer (08-09-2011), CTSpd6 (08-09-2011), rfinkle2 (08-09-2011)
 Old 08-09-2011, 09:00 AM   #8
ZsSpeed3's Avatar
I am using my DH to monitor and I haven't upgraded my turbo or anything. It was in the 15's almost 16, just didn't want to say something that made wasn't true. So.....wasn't "pushing" it, that's what it was holding till I let off the pedal.
 Old 08-09-2011, 09:07 AM   #9
CTSpd6's Avatar
Thanks for the responses. I will do some logs after work.
 Old 08-09-2011, 09:19 AM   #10
Blue 2 shims
Nazarite's Avatar
Groans: 66
Hey man, we're just messing with you because you're talking about holding stock pressure while the guy right above you said he pushed it 5 psi more. Surely you see the irony. But hey, at least you're holding stock psi, some guys bpv's can't do that.
The Following 2 Users Say Thank You to Nazarite For This Useful Post:
rfinkle2 (08-09-2011), ZsSpeed3 (08-09-2011)
 Old 08-09-2011, 09:23 AM   #11
CTSpd6's Avatar
Good Luck
With a boost leak, is it normal that i'm only hearing this noise at WOT near peak boost? I would think that i would hear it more often than that.
 Old 08-09-2011, 09:30 AM   #12
The more pressure you put on a loose connection, the more likely you are to hear it.
If it sounds like someone is blowing through a blade of grass, or pinching a balloon opening and letting the air squeal out, it is probably a silicone coupler vibrating against a hard pipe.
Boost leaks are almost impossible to diagnose from in the car while driving.
BlueStreak (08-09-2011), CTSpd6 (08-09-2011), helmetface (08-09-2011)
 Old 08-09-2011, 09:43 AM   #13
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
My OEM BPV worked perfectly at 21psi, but definitely began leaking at 23. If you look at the design, I believe that Mazda intended it to leak at higher (21psi+) boost levels....
FORZDA 1 is offline   Reply With Quote
The Following 5 Users Say Thank You to FORZDA 1 For This Useful Post:
BlueStreak (08-09-2011), helmetface (08-09-2011), mazdaspeed619sd (08-22-2011), redneckrecon (08-09-2011), rfinkle2 (08-09-2011)
 Old 08-09-2011, 09:51 AM   #14
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I am currently running 22.5PSI with no leaks.
I have also successfully boost leak tested the BPV to values higher than that (remove return hose, plug TIP connection to return hose and pressurize system).
'07 CWP MS3
Forged.
The Following 3 Users Say Thank You to BlueStreak For This Useful Post:
Lex (08-10-2011), Monotonous ONE (08-11-2011), rfinkle2 (08-09-2011)
 Old 08-09-2011, 01:48 PM   #15
helmetface's Avatar
Groans: 219
Boy do I know this one haha
@ZsSpeed3 - Ya I was only giving you flak because thats the ~pressure the stockers was meant to run at, give or take.
 Old 08-09-2011, 03:32 PM   #16
ZsSpeed3's Avatar
Whateva.... tampon has been removed. ha ha
 Old 08-09-2011, 04:20 PM   #17
pinggoy's Avatar
Posts: 93   (View Stats)
pinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud ofpinggoy has much to be proud of
if you have a DH boost/vac should be around -21.00.. i might be wrong.
8.5 Mazdaspeed tres.-
JBR SHIFT KNOB- JBR SHIFTER BUSHING- COBB SRI- SU ED TURBOSMART BPV- PROSPORT CF E-BRAKE- HYPERTECH- DASHHAWK- CP-E TMIC- CP-E RMM- CORKSPORTS RECIRC TUBE.
on the list-
SURE SSP- MUDFLAPS-CPE HPFP-COBB AP.
pinggoy is offline   Reply With Quote
 Old 08-09-2011, 04:41 PM   #18
ZsSpeed3's Avatar
My DH is messed up, missing a whole bunch of PID's. Won't let me do the Boost/Vac, just Boost PSI. Dumb thing, need a PC to update. all i have is a Mac.
 Old 08-09-2011, 07:42 PM   #19
pinggoy's Avatar
can you not update it? there is a download somewhere on this site for DH.
on the list-
 Old 08-10-2011, 12:38 PM   #20
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You can tweak the stock BPV so it holds whatever you throw at it. Takes about 5 minutes and may not cost you anything. TRex posted my writeup here before I was a member, called something like "stock BPV leak? I may have a cost effective semi-solution". I've been running it for ~20k miles without a problem.
Lex (08-10-2011), rfinkle2 (08-10-2011)
 Old 08-10-2011, 01:39 PM   #21
Read your post in that thread - so is the flange leaking to atmosphere thus allowing metered air to escape or is the boost leaking into the bottom chambers and out into the intake?
If leaking to atmosphere could it not be epoxied?
Most aftermarket BPVs cause flutter - the HKS and pull type BPVs are well known for this. A little surge at LOW boost pressures is not bad - surge at high boost pressures starts to load the turbo shaft.
 Old 08-10-2011, 11:40 PM   #22
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
My stock valve was holding great at stock boost levels.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
 Old 08-11-2011, 05:35 AM   #23
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
Groaned at 56 Times in 41 Posts
I had that happen to me and I just unplugged it from the OBD port and plugged it back in.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 08-11-2011, 06:20 AM   #24
[MSF STIG]
FORZDA 1's Avatar
Yep, but it isn't "tunable" it's either stock or whatever(?) the spring will hold.
 Old 08-11-2011, 01:45 PM   #25
Eth Fiend
phate's Avatar
Yes, the flange leaks to atmosphere. It's such a miniscule amount, I doubt it affects the tune. I think it does, however, affect the BPV operation. Epoxying the flange is a possible fix, but I haven't really done anything with it since I wrote that post. The car runs extremely well, even with the flange leaking slightly.
I've heard the flutter argument about shaft loading, but I've never seen any proof of this happening. Where surge does have an effect is at WOT/fully loaded. Yes, in that case, turbos sometimes explode.
The converse argument for flutter is that it prevents a possible overrun situation. Meaning there is zero restriction on the turbo outlet while the BPV/BOV is open, where the turbo can spin as fast as possible.
I'm not saying either is correct, because I don't have direct empirical evidence supporting either theory. I do, however, know of many turbo cars that have fluttered for thousands upon thousands of miles without a problem.
mazdaspeed619sd (08-22-2011), rfinkle2 (08-11-2011)
 Old 09-10-2013, 08:30 AM   #26
blackspeed223's Avatar
Posts: 54   (View Stats)
blackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of light
Sry to bring up an old post but i saw this because im having the same problem and was wondering what you did to fix it. if you could help me out that would be awesome if not ill keep searching. thanks
blackspeed223 is offline   Reply With Quote
 Old 09-10-2013, 09:23 AM   #27
Is your problem a boost leak? If so locate it using a boost leak test
Is the issue the BPV opening at part throttle? This is absolutely normal. If you want to VTA your OEM BPV you need to use the Guardian Angel which keeps it closed.
 Old 09-10-2013, 09:42 AM   #28
I don't think it's a boost leak I just have the problem of where the bpv is opening up when just cruising up to speed at about 3 grand. All my numbers are good atf is 14.7 at idle 11.6 at wot. FP is round 430 at idle and between 1650-1750 at wot.
 Old 09-10-2013, 05:09 PM   #29
ok i have searched high and low and this is the only one that i have found but still no answer... i did the same tune as the OP and i have the same problem w the BPV blowing off in slow acceleration before i even take my foot off the pedal. just wondering if this is a problem or not. I dont suspect boost leak seeing as how it holds boost at high RMP.
 Old 09-10-2013, 05:12 PM   #30
How do you know the BPV is flowing off? Can you hear it?
If it's blowing off during acceleration it might be faulty. Try blowing/sucking on the top port. If you can blow through that port the diaphragm is torn inside.
 Old 09-10-2013, 05:15 PM   #31
Yes cuz when I was driving I felt it kinda fall and looked at the boost and saw it drop. So I turned down the radio and went through the gears again and before I would get to 3 grand it would blow of and boost would drop
Stock bpv question 86AmishMs3 Mazdaspeed3/6 General Discussion 7 06-15-2011 12:19 AM
Resetting Stock ECU Question vr4_3000 MazdaSpeed 3/6 - ECU Computer Tuning 9 04-06-2011 04:22 PM
SRI/CAI and Stock Air Box question(s) Liquidplatspeed6 Mazdaspeed3/6 General Discussion 15 06-16-2010 11:58 PM
question what is our stock tire size ms3 GFish Mazdaspeed3/6 General Discussion 4 09-27-2008 10:42 PM
Question: How to clean stock exhaust? killyoutoo MazdaSpeed 3/6 - Appearance 7 04-02-2008 07:55 AM
Page generated in 0.49347 seconds with 34 queries
