![]() Join Date: Sep 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
(Thread Starter) | Not Ranked : 0 score I've heard stories of people saying their's leaked, but did anyone actually test it according to the service manual? I pulled mine off and hooked it up to a pump. Its opening around 15 inches of vacuum, which isn't "great" according to the manual, but still within limits. Just wondering if anyone else who claimed their BPV was leaking ACTUALLY tested it or just claimed it was for justification to rice their shit. |
![]() Join Date: Dec 2010 Location: Springfield, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,536
Groans: 354
Groaned at 213 Times in 109 Posts
| Neutral : -1 score
__________________ 2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now) 2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy |
| The Following User Says Thank You to zpele For This Useful Post: | karl-hungus (09-26-2011) |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 760 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score if it's not in spec, you will know it by checking your idle and light throttle LTFTs. if the BPV pops open, your motor will pull fuel ("normal" LTFTs start going down significantly for similar temp/humidity/etc.). all you really need is a DH or AP to check what's important: LTFTs at idle and light throttle, and also WGDC at WOT to see if it maxes. |
| Not Ranked : 0 score the ones that do check, are just checking their WGDC with the DH/AP. all you need to do (usually) is see if it maxes on like 16-18psi, if it does, you know you're leaking SOMEWHERE... |
(Thread Starter) | Not Ranked : 0 score I wish I was getting 16-18lbs... I've spiked at 16 once, but usually only hold 13 or so. Maybe its time to invest in a defi as well. |
| Not Ranked : 0 score check your WGDCs, because you need to see if you're only holding 13psi because the car has achieved the load it was targeting, or your BPV is just leaking all over the place. |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score you are on stock tune right? stock tune tapers down to 13-14 toward red line...on stock tune you will spike to 15-16 for about 500 rpm then begin to taper off |
| Not Ranked : 0 score I tested mine by taking the lid off the trash can and throwing the plastic turd in, and then bolting on a Forge. Blue spring no shims. |
| The Following User Says Thank You to Raider For This Useful Post: | Brennan (03-03-2012) |
(Thread Starter) | Not Ranked : 0 score I've lurked long enough to get the understanding that there are no gains to be had from an aftermarket vs a working stock bpv... any reason you switched besides sound? |
| Not Ranked : 0 score With a boost gauge, I saw the stock one was leaking boost, so it went in the trash. BPV is not that loud, either. No gains are correct. But when it boosts to 15 and drops like a rock, yeah trash it. |
![]() Join Date: Jun 2009
| Not Ranked : 0 score I'm holding 19-20 psi under load with slow taper to 16-17 at 6,000 rpm on the stock bpv at coming up on 60,000 miles with mods below. Most "leaking" valves don't leak. Follow procedure outlined above to test. On stock tune you may not see more than 13-14 psi at 5,500-6,000 rpm depending on barometric pressure, ambient temp, etc.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following User Says Thank You to phate For This Useful Post: | darkstar5440 (09-17-2013) |
| nothing to see here.... ![]() Join Date: Jul 2010 Location: Round Lake, IL
Rep Power: 279 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 455
Groans: 39
Groaned at 43 Times in 18 Posts
And how about LTFT's numbers? Thanks.
__________________ 2008 Mazdaspeed 3 GT in Black Mica: 60ft: 2.167 1/8: 9.052 1/4: 13.922 @ 100.37 (26psi tire pressure & stock tires) CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP ![]() ![]() : | |
| Not Ranked : 0 score honestly, it's been too damn long since i've run the stock tune to know what it puts out for WGDC numbers. i suspect it won't go anywhere over 70-80% when the going gets tough (4500rpm+)...but that's just a guess... |
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
| Stock rods needed for testing | Lex | MazdaSpeed 3 - Engine, Transmission & Driveline | 185 | 02-01-2010 03:27 PM |
