 Old 07-22-2014, 02:27 PM   #1
austin_wolfe's Avatar
Posts: 3   (View Stats)
austin_wolfe is an unknown quantity at this point
Default stock K04 turbo rebuild, and how to make it better
Hi everyone, I recently blew my motor on my mazdaspeed 6 so I'm doing a rebuild and one of the things i need to rebuild is my turbo as it has shaft play in it, I'm just wondering if its worth rebuilding or buying a new turbo? if I rebuild it what kit would you suggest and is there anything I can do to make it better or more durable then the way it is factory? I don't want to do all this work to it and then have something go bad shortly after I have it all together. Any input would be appreciated.
This is my first post on here so easy on the hate
austin_wolfe is offline   Reply With Quote
 Old 07-22-2014, 02:31 PM   #2
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
First off, you need to research before asking questions like this. A lot of people will jump on you very quickly if you don't.
To answer your question, a used k04 can be picked up for $150-200 and a rebuild kit is $100 and your labor... A BNR will run you about $1000 and does not smoke like a k04 will eventually. So that's your call on what is worth it to you. Personally, I would just go BNR.
 Old 07-22-2014, 02:35 PM   #3
if i went with a BNR would i have to do a retune? Budget is tight but I'm also wanting to do the job right
 Old 07-22-2014, 02:37 PM   #4
Jtaylor's Avatar
Posts: 656   (View Stats)
Get your flame suit ready
08 MazdaSpeed3
The Following 2 Users Say Thank You to Jtaylor For This Useful Post:
Gr8Speed (07-22-2014), kgb (07-24-2014)
 Old 07-22-2014, 02:38 PM   #5
Gr8Speed's Avatar
Yes. You're going to want a tune no matter what you do because the stock mapping is shit. $200 is the going rate for an e-tune though, so not as bad as some platforms.
 Old 07-22-2014, 02:39 PM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Yes, you will have to re-tune and there are at least 3 benefits I can think of:
1. the BNR/garret GT/GTX turbo will not smoke;
2. you will get more power from your engine, safely;
3. you will shift the torque curve in the upper RPM thus protecting the engine from the monster torque below 3000-3300rpm.
Whatever you change to your turbo you will need aftermarket fuel pump internals, of course.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 07-22-2014, 02:44 PM   #7
Ok thanks for the input
K04 turbo rebuild question tazz2828 MazdaSpeed 3/6 - Turbo Induction 34 07-14-2014 02:51 PM
Mazdaspeed k04 turbo rebuild P5turbo MazdaSpeed 3/6 - Turbo Induction 5 05-14-2014 06:41 AM
turbo rebuild specs thebestdj07 MazdaSpeed 3/6 - Turbo Induction 0 02-05-2014 03:16 PM
K04 Turbo Rebuild Help Tsortino91 MazdaSpeed 3/6 - Turbo Induction 20 02-24-2013 05:56 PM
Turbo Rebuild Question tazman34685 MazdaSpeed 3/6 - Turbo Induction 12 07-05-2012 10:26 AM
Page generated in 0.27461 seconds with 23 queries
