  • 1 Post By meicalnissyen
 Old 06-30-2009, 12:09 AM   #1
manofhonor24's Avatar
Posts: 187   (View Stats)
manofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to beholdmanofhonor24 is a splendid one to behold
Default Stock turbo boost capabilities
What is the most boost pressure that the stock turbo's can handle before they start to fail/blowup?
Can a reworked turbo handle more?
What is the stock boost pressure of the stock turbo?
How much hp/torque gain is there 1,2,3 psi gain in boost pressure?
2006 Mazdaspeed6 Sport - Black Cherry Mica
Sure Aeros Short Ram Intake | Stage 1 SF +93 AP Map | 3.25 TMIC | Cobb Tuning Turbo Inlet Pipe | Turbosmart Hybrid BOV | Magnaflow catback Exhaust | ATP High Flow Catted Downpipe | Steedspeed Exhaust Manifold Ceramic Coated | ACT Clutch and Flywheel | Black JDM LED Tailights | CPE Rear Engine Motor Mount | SU Solid Shifter Spacers | Denso 2 Step Colder Spark Plugs | SU Boost Tubes
manofhonor24 is offline   Reply With Quote
 Old 06-30-2009, 05:03 AM   #2
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
I think the sensor is capped out at 22.8 PSI, I've ran this before.
A reworked turbo can handle more boost more efficently.
Stock boost is 15.6 PSI
it depends on the mods you have, there is no set PSI gain.
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline   Reply With Quote
 Old 06-30-2009, 05:31 AM   #3
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
The stock turbo is pretty limited. You can turn it up a bit but it is already getting hotter and hotter as you go. Everyone seems to run about 18psi. The turbo is too small for this motor.
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 06-30-2009, 06:34 AM   #4
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
ask darksun how high you can go......lol
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
The Following User Says Thank You to SgtP For This Useful Post:
phillyb (07-15-2009)
 Old 07-14-2009, 01:05 PM   #5
rremente's Avatar
Posts: 49   (View Stats)
rremente has a spectacular aura aboutrremente has a spectacular aura about
Reworked or upgraded turbo? What is better?
rremente is offline   Reply With Quote
 Old 07-14-2009, 01:20 PM   #6
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
so i shouldn't have mine set for 30psi?
 Old 07-14-2009, 01:50 PM   #7
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
it's also a factor of just how reworked you go - there are some folks out there now doing completely different guts to the k04 housings (for a price in between what you pay for pg's and a whole new garrett gt series) - with a total rebuild like that you may actually enter the situation where you can make more hp with less amounts of boost because the air is being moved and shaped in a whole new way
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
SpeedSixxx (07-16-2009)
 Old 07-14-2009, 08:41 PM   #8
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Probably greater than 30psi, provided that there is enough restriction.
Probably greater than 40psi, provided that there is enough restriction.
15psi
For what size pipe diameter, air temp, humidity, intercooler efficiency, a/f ratio, compression ratio, intercooler pressure drop, exhaust manifold to dp pressure differential, and rpm? Actually the answer is not much hp is gained for the wear and tear added. The engine produces around 120hp n/a at a absolute pressure of 14.7psi, 120/14.7= ~8 * 3psi = 24 crank hp * .8 correction factor for drivetrain loss = ~20whp for 3psi. Assuming all the above factors stay the same, which they dont.
2006 Mazdaspeed 6
 Old 07-14-2009, 09:05 PM   #9
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Seven
The answer to all of your questions is Seven.
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
meicalnissyen (04-04-2017), SharkDiver (07-14-2009)
 Old 07-14-2009, 09:31 PM   #10
cpolly69's Avatar
Groans: 27
and a half
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 07-15-2009, 11:05 AM   #11
rremente's Avatar
I am looking into gutting in my stock K04. Does anyone know any place that does this?
 Old 07-15-2009, 12:15 PM   #12
ozzzzz's Avatar
Posts: 24   (View Stats)
ozzzzz is just really niceozzzzz is just really niceozzzzz is just really niceozzzzz is just really nice
Try this link, PT-Performance.com
they claim efficiency to 24psi.
i have a reworked PG turbo I run at 20-21psi with no problems for 17k miles.
Never dynoed it but seat on the pants says 20 pulls harder than 18psi.
ozzzzz is offline   Reply With Quote
 Old 07-15-2009, 12:30 PM   #13
ozzzzz's Avatar
My bad ,efficiency to 25.5psi for the PT- performace turbo as stated on their website.
 Old 07-15-2009, 05:51 PM   #14
cpolly69's Avatar
Groans: 27
Mazdaspeed 3/6 K04 Hybrid turbocharger 330WHP!!! - StreetUnitForum.com
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 07-15-2009, 08:49 PM   #15
sleeperstang1994's Avatar
Posts: 569   (View Stats)
Groaned at 7 Times in 5 Posts
wow this thread feels like 24/7.............
The Following User Says Thank You to sleeperstang1994 For This Useful Post:
 Old 07-15-2009, 09:38 PM   #16
wassup61's Avatar
Posts: 1,232   (View Stats)
All of the reworked stockers are of the same idea. Efficient to 25.x psi, larger wheel, stock housing, P&P, 270* bearing instead of a 90*.
All wagon, No traction
 Old 07-16-2009, 05:46 PM   #17
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
They want $1100 for this turbo and it still has the shity Ko4 oil seals and not a bearing type.If I was going to spend $1100 I would go for a GT28 or GT30 and have good seals.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 07-16-2009, 10:06 PM   #18
cpolly69's Avatar
Groans: 27
actually i talked to bryan at bnr that is building these - it will remain a journal bearing and not a ball bearing if that's what you mean but he will be using a totally different type of seal then what the stock setup or pg uses - so even if someone didn't get the pcv fix that's coming (which is the real source of the oil leaking problem) they could still use this turbo and hopefully not leak - all the other internal parts will be upgraded - not just the compressor wheel - as this price point is really in between pg's rework and a gt2871 (don't forget your inlet doesn't fit a gt2817) you are really getting what you are paying for - i am looking forward to the results of the first few folks who get one of these as he plans to do even bigger power later on - vw's use and build the k series turbos with great results - the big reason a lot of folks bailed on them in the mazda community is b/c of the leaking oil seal issue
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
SharkDiver (07-17-2009)
 Old 07-21-2009, 05:41 PM   #19
zamdam's Avatar
Posts: 37   (View Stats)
zamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these partszamdam is infamous around these parts
Groaned at 299 Times in 34 Posts
Majestic Turbo in Waco, TX
zamdam is offline   Reply With Quote
The Following 4 Users Say NO Thank You to zamdam For This Un-useful Post:
 Old 04-04-2017, 08:30 PM   #20
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
wrong
its 42
the answer to life, the universe, and, well, everything
Originally Posted by SSinstaller View Post
Seven
Jakeypoo likes this.
 Old 04-04-2017, 08:58 PM   #21
omgzilla85's Avatar
Posts: 84   (View Stats)
omgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to behold
Originally Posted by meicalnissyen View Post
wrong
its 42
You really bumped an 8 year old thread to say that?
Sent from my Nexus 5X using Tapatalk
2007 True Red MS3 GT - AP V3 - BNR S4 - eBay DP - JBR Tru 3.0 - TR8 FMIC - TS BPV - Autotechs - JBR EBCS - 3 BAR - JBR PMM - CS RMM - CS Shift Plate - DM OCC - Koni Yellows - Eibach Pro-Kit - Enkei Evo Xs - Freektuned
omgzilla85 is offline   Reply With Quote
 Old 04-05-2017, 05:18 AM   #22
Jonb82's Avatar
Posts: 416   (View Stats)
At least he quoted a decent movie/ book. Still... shame.
Sent while probably pooping
The Following 3 Users Say Thank You to Jonb82 For This Useful Post:
NC-MS3Rob (04-06-2017), Vansquish (04-05-2017), Yatta (04-06-2017)
 Old 04-05-2017, 07:56 PM   #23
sheston's Avatar
Posts: 1,847   (View Stats)
I've only been able to get 41
 Old 04-06-2017, 06:33 AM   #24
NC-MS3Rob's Avatar
Posts: 87   (View Stats)
NC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant futureNC-MS3Rob has a brilliant future
Highly underrated movie.
AP v3 -- Autotech -- HTP 3.5" Intake -- CS BPV -- JBR SSP -- COBB Shift Knob -- H&R RSB -- Custom E-cutout -- CP-e TMIC -- JBR IC Piping -- JBR Coolant Bypass -- DM TIGs -- CP-e DP -- JBR EGR Delete -- AEM 30-3000 WMI -- Akebono Ceramics -- Centric High Carbon Rotors -- s204 Lip
"The mind is like a parachute, it only works when open"
NC-MS3Rob is offline   Reply With Quote
 Old 04-06-2017, 08:17 AM   #25
Yatta's Avatar
Posts: 1,862   (View Stats)
If you start at 0, 41 is 42.
 Old 04-06-2017, 04:32 PM   #26
I wonder if Alans last words were,
so long, and thanks for all the fish
 Old 04-07-2017, 05:28 PM   #27
Jakeypoo's Avatar
Posts: 226   (View Stats)
Jakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond repute
Original or remake?
2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25.
Jakeypoo is offline   Reply With Quote
Turbo Mani & Boost badams118 MazdaSpeed 3/6 - Turbo Induction 7 04-13-2009 12:23 PM
how much boost can your stock turbo hold? johnac08 MazdaSpeed 3/6 - Turbo Induction 16 03-18-2009 01:12 PM
Big Turbo, Stock Boost Control Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 30 12-30-2008 04:57 AM
Should've bought a Garmin? Testing the iPhone 3G's GPS capabilities Haltech Automotive News 0 07-14-2008 10:50 AM
Page generated in 0.43708 seconds with 40 queries
