 Old 01-15-2010, 09:14 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Stock turbo oil and coolant lines
I have sourced a turbo drain to an-10 adapter and a block to an-10 adapter, and a .06" restrictor m12x1.5mm banjo to an-4 oil feed fitting. So that part is done.
How does the stock turbo oil feed line attach to the block/head/whatever? I may need to plug it, I havent decided yet if I want to run a line off of the remote oil filter or the stock location. If its a banjo, anyone know if it is the same size as the turbo one?
How and where do the coolant lines connect to the engine? Is it a gay barb fitting? If it is, I am going to drill it out because I cant use barb ends with SS hose.
Can someone confirm that the coolant feed on the turbo is m14x1.5?
2006 Mazdaspeed 6
 Old 01-23-2010, 09:02 AM   #2
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
did you ever figure this out
 Old 01-23-2010, 06:57 PM   #3
Speeeeeed
06Speed6's Avatar
The oil drain and block are T25 turbo drain fittings to an-10 with a m6x1mm bolts.
The oil input on the turbo is a m12.1.5mm banjo with .06" restrictor to an-4.
The block side oil input is a straight m12.1.5mm ORB to an-4.
The coolant in is a straight ORB m14x1.5mm to an-6.
The coolant out is a 90* swivel m14.1.5mm ORB to an-6.
The block coolant in and out will have to be cut drilled and tapped.
2006 Mazdaspeed 6
 Old 01-23-2010, 07:34 PM   #4
austin102085's Avatar
Posts: 1,195   (View Stats)
Groans: 32
so what are u doing with this?
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
 Old 01-23-2010, 10:32 PM   #5
whats ORB?
 Old 01-24-2010, 11:00 AM   #6
Speeeeeed
06Speed6's Avatar
o-ring boss fitting, its a straight cut flare with a o-ring.
2006 Mazdaspeed 6
 Old 01-25-2010, 06:43 PM   #7
Fagwagon's Avatar
Groans: 75
so are you saying this will work for both the drain fitting on the turbo and the drain fitting on the block?
this
 Old 01-25-2010, 07:51 PM   #8
Speeeeeed
06Speed6's Avatar
Yes but buy the russell one on summit, it is o-ringed. The one on the atp web page uses a gasket which is not included and is a extra cost and the supplied bolts dont fit. I have both of them.
Russell Performance 697070 - Russell Turbocharger Oil Drain Flange Fittings - Overview - SummitRacing.com
2006 Mazdaspeed 6
 Old 01-25-2010, 10:04 PM   #9
i tried using that EXACT fitting on both my turbo and the block and although it fits on both its near impossible to find a hose between the two that wont kink. this is for the MS6 guys of course.
 Old 01-26-2010, 07:29 AM   #10
Speeeeeed
06Speed6's Avatar
Yeah its tight for sure, but I think its possible.
There is actually a an-8 drain flange thats available but I wanna try it with the an-10 first.
2006 Mazdaspeed 6
 Old 01-26-2010, 07:36 AM   #11
well i used this part for the turbo side but then i got another one and cut off the threaded part and tapped the existing hole for a 3/8th NPT fitting. i then found a 3/8th NPT to 10an 90deg fitting and threaded it in there so i basically had the diamond flange with a tight radius 10an fitting on it. it fit nicely between the block and TC but when i went to use the 10an braided hose it kinked and i couldent use it. the stock oil drain line is like the perfect path and its near impossible to replicate that with a flexible hose. right now im running the stock drain line with the GT30 and its working perfect.
djuosnteisn (01-26-2010)
 Old 01-26-2010, 11:57 AM   #12
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
+1 for stock drain line.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 01-26-2010, 12:22 PM   #13
Fagwagon's Avatar
Groans: 75
I think the stock drain line is going to be a bit too small for my holset tho from what ive been reading...not only that but im sure its not going to line up right even tho the flanges are the same.
 Old 01-26-2010, 05:30 PM   #14
Speeeeeed
06Speed6's Avatar
If I figure out what conbination of fittings are needed, ill let you guys know.
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
djuosnteisn (01-26-2010), Fagwagon (02-06-2010)
 Old 01-26-2010, 05:39 PM   #15
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
My fab man did a push lock line with a fire sleeve and the stock fittings. Its been working so far with no issues.
kore2000 is offline   Reply With Quote
 Old 02-06-2010, 07:20 AM   #16
Fagwagon's Avatar
Groans: 75
did you figure it out yet? lol
 Old 02-06-2010, 10:22 AM   #17
Speeeeeed
06Speed6's Avatar
Still waiting on parts.
2006 Mazdaspeed 6
EWG on stock turbo? SgtP MazdaSpeed 3/6 - Turbo Induction 18 09-15-2009 03:35 PM
Turbo/Oil Lines Update Please JumpingJackson Mazdaspeed3/6 General Discussion 12 09-05-2009 03:16 PM
Page generated in 0.35745 seconds with 25 queries
