  • 1 Post By taf0422
 Old 07-09-2015, 09:11 PM   #1
plak424's Avatar
Posts: 298   (View Stats)
Default Stock Turbo removal
This might be a dumb question but I was wondering if it's possible to remove the stock Turbo by unbolting then sliding out towards the drivers side with the battery box and intake removed? I took the intake and battery box out last week just to check and it seems like it'll be close.
Anyone have any advice on the easiest way to pull the Turbo out? Planning on replacing it this weekend and dont want to pull the manifold.
The Following User Says NO Thank You to plak424 For This Un-useful Post:
Vansquish (07-10-2015)
 Old 07-09-2015, 09:12 PM   #2
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
cyclist20 (07-10-2015), MazdaspeedKills (07-13-2015), plak424 (07-10-2015), qtrmile beast (07-13-2015), WetzMS3 (07-10-2015)
 Old 07-09-2015, 09:57 PM   #3
acousticdefbot's Avatar
Posts: 319   (View Stats)
BNR Stage 3 Checklist.
Freeks BNR install
BNR S3 Swap How To
lots and lots and lots of great instruction for the removal of the stock piece.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
The Following User Says Thank You to acousticdefbot For This Useful Post:
 Old 07-09-2015, 09:59 PM   #4
speed23's Avatar
Posts: 1,480   (View Stats)
Please search and you will find many how to's on this. Short answer, yes, you can do this, but removing the EGR makes it easier also.
 Old 07-10-2015, 08:36 AM   #5
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Originally Posted by shurik View Post
It's a pain but is definitely doable.
Less of a pain than removing the exhaust manifold...
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
MazdaBoy2.3 (07-10-2015)
 Old 07-10-2015, 10:21 AM   #6
Colepidd55's Avatar
Posts: 211   (View Stats)
Colepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond reputeColepidd55 has a reputation beyond repute
it sucks but pulling it out is the easy part..lol
SOLD
2009 CWP Speed3
Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+
Colepidd55 is offline   Reply With Quote
 Old 07-10-2015, 10:25 AM   #7
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Ive taken one out the top, bottom and intake side. Personal favorite is out the bottom.
g00s3y (07-10-2015)
 Old 07-10-2015, 05:11 PM   #8
plak424's Avatar
Thanks for the info. I searched the site on google and didn't find much. Knew I was missing a bunch.
 Old 07-10-2015, 05:48 PM   #9
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I've taken it out the side and bottom. Bottom is definitely easiest.
 Old 07-10-2015, 06:56 PM   #10
plak424's Avatar
How do you even get it out that way? Do you have to remove the DP? I looked at doing it that way last weekend and it looked like it wouldn't fit past the axle.
 Old 07-10-2015, 07:13 PM   #11
g00s3y's Avatar
Groans: 438
Yes, remove the dp, and you can "rotate" it over the axle.
 Old 07-10-2015, 07:17 PM   #12
taf0422's Avatar
Groans: 192
Easiest and fastest (atleast to me) straight out the intake side.
I've installed/removed as big as a gtx3076 that way. Remove intake, battery, egr, dp bolts, mani bolts and slide out. Obviously all the coolant / feed lines
ms6mil likes this.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 07-10-2015, 07:43 PM   #13
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
That's exactly what I meant. That little tube is a pain along with all the other stuff to get to in a tight space
Try doing it in an MS6. I went into a murder-rage at least 3 or 4 times while removing the k04 and installing the BNRS3.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
The Following 2 Users Say Thank You to biggman026 For This Useful Post:
esr010 (07-10-2015), speedfreak44 (07-10-2015)
 Old 07-10-2015, 07:47 PM   #14
maisonvi's Avatar
Groans: 75
Lol, bottom is not an option on the 6
 Old 07-12-2015, 11:34 AM   #15
plak424's Avatar
Got it out, went out through the intake side. Wound up having to drain the coolant when I pulled the egr for whatever reason. Maybe I need to replace my thermostat again.
 Old 07-12-2015, 04:02 PM   #16
AwAfrican's Avatar
Posts: 1,038   (View Stats)
Coolant runs thru the egr... When I did my egr delete I just topped up after
sent via tapafail!
2013 Black MS3
 Old 07-12-2015, 05:05 PM   #17
plak424's Avatar
sent via tapafail!
Yeah but usually the whole reservoir won't drain through the egr valve line
 Old 07-12-2015, 05:05 PM   #18
AwAfrican's Avatar
Touche
sent via tapafail!
2013 Black MS3
 Old 07-13-2015, 07:00 AM   #19
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
That's what she said.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
 Old 07-13-2015, 08:40 AM   #20
speedfreak44's Avatar
Posts: 1,391   (View Stats)
How much coolant do you think you added after the egr delete? About to do this as well but since I live in florida was just going to top off with distilled water if it was not a lot (no freeze worries)
The line up:
 Old 07-13-2015, 09:03 AM   #21
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
If you have your car level (not on jack stand) when you take the egr coolant return line off, you won't lose a ton. Just stuff a rag in there and take the egr off makes life much easier.
Silver 2007 Speed3 GT
 Old 07-13-2015, 09:07 AM   #22
AwAfrican's Avatar
I had only the front jacked up went from full line to about 1/3 above the low line. If your car is cool when doing it you'll loose less as well mine was warm
sent via tapafail!
2013 Black MS3
Looking for a stock turbo removal and installation guide TheBugGuy 2010 MS3 - How-To's 6 04-24-2018 10:14 PM
Need urgent help, stock turbo removal Mandinca MazdaSpeed 3/6 - Turbo Induction 32 01-14-2014 10:38 AM
removal of exhaust manifold bolt behind turbo dooderek MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-27-2011 08:07 PM
Stock PCV Valve Removal dizzin9 MazdaSpeed 3/6 - Turbo Induction 16 03-09-2010 09:21 AM
Page generated in 0.40643 seconds with 32 queries
