![]() Join Date: Sep 2011 Location: Newington, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
(Thread Starter) | Not Ranked : 0 score Anyone have any advice on the easiest way to pull the Turbo out? Planning on replacing it this weekend and dont want to pull the manifold.
__________________ Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon... |
| The Following User Says NO Thank You to plak424 For This Un-useful Post: | Vansquish (07-10-2015) |
| The Following 5 Users Say Thank You to Code Monkey For This Useful Post: | cyclist20 (07-10-2015), MazdaspeedKills (07-13-2015), plak424 (07-10-2015), qtrmile beast (07-13-2015), WetzMS3 (07-10-2015) |
![]() Join Date: Oct 2014 Location: sugar land, texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score BNR Stage 3 Checklist. Freeks BNR install BNR S3 Swap How To lots and lots and lots of great instruction for the removal of the stock piece.
__________________ guzzlin' a guinness stout. |
| The Following User Says Thank You to acousticdefbot For This Useful Post: | plak424 (07-10-2015) |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Please search and you will find many how to's on this. Short answer, yes, you can do this, but removing the EGR makes it easier also. |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
Less of a pain than removing the exhaust manifold...
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 | |
| The Following User Says Thank You to taf0422 For This Useful Post: | MazdaBoy2.3 (07-10-2015) |
![]() Join Date: Mar 2014 Location: madison/LAX, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 96
| Not Ranked : 0 score it sucks but pulling it out is the easy part..lol
__________________ SOLD 2009 CWP Speed3 Cobb Ap/AT Internals/Cobb Downpipe/Cobb SRI,TIP/TS BPV/sure shortcut/JBR 88a RMM/JBR TMM/JBR solid shifter bushings/Freektune OTS+ |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score Ive taken one out the top, bottom and intake side. Personal favorite is out the bottom.
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
| The Following User Says Thank You to maisonvi For This Useful Post: | g00s3y (07-10-2015) |
(Thread Starter) | Not Ranked : 0 score Thanks for the info. I searched the site on google and didn't find much. Knew I was missing a bunch.
Groans: 438
| Not Ranked : 0 score I've taken it out the side and bottom. Bottom is definitely easiest.
__________________ All good things must come to an end... |
(Thread Starter) | Not Ranked : 0 score How do you even get it out that way? Do you have to remove the DP? I looked at doing it that way last weekend and it looked like it wouldn't fit past the axle.
Groans: 438
| Not Ranked : 0 score Yes, remove the dp, and you can "rotate" it over the axle.
Groans: 192
| Neutral : +1 score Easiest and fastest (atleast to me) straight out the intake side. I've installed/removed as big as a gtx3076 that way. Remove intake, battery, egr, dp bolts, mani bolts and slide out. Obviously all the coolant / feed lines
![]() Join Date: Feb 2013 Location: Montgomery, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 204
Groaned at 49 Times in 12 Posts
| Not Ranked : 0 score Try doing it in an MS6. I went into a murder-rage at least 3 or 4 times while removing the k04 and installing the BNRS3.
__________________ 2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016! BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn |
| The Following 2 Users Say Thank You to biggman026 For This Useful Post: | esr010 (07-10-2015), speedfreak44 (07-10-2015) |
Groans: 75
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC | |
(Thread Starter) | Not Ranked : 0 score Got it out, went out through the intake side. Wound up having to drain the coolant when I pulled the egr for whatever reason. Maybe I need to replace my thermostat again.
![]() Join Date: Oct 2013 Location: Kingston, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 706
sent via tapafail!
__________________ 2013 Black MS3 CS SRI & TIP / CPE Catted DP / AT Internals / Cobb AP V3 [FREEKTUNED] COBB RMM / COBB shift weight & Shift knob / JBR SSP / CPE EGR Delete | |
(Thread Starter) | Not Ranked : 0 score Yeah but usually the whole reservoir won't drain through the egr valve line
| Not Ranked : 0 score Touche sent via tapafail!
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score That's what she said.
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score How much coolant do you think you added after the egr delete? About to do this as well but since I live in florida was just going to top off with distilled water if it was not a lot (no freeze worries)
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score If you have your car level (not on jack stand) when you take the egr coolant return line off, you won't lose a ton. Just stuff a rag in there and take the egr off makes life much easier.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| Not Ranked : 0 score I had only the front jacked up went from full line to about 1/3 above the low line. If your car is cool when doing it you'll loose less as well mine was warm sent via tapafail!
| Looking for a stock turbo removal and installation guide | TheBugGuy | 2010 MS3 - How-To's | 6 | 04-24-2018 10:14 PM |
| Need urgent help, stock turbo removal | Mandinca | MazdaSpeed 3/6 - Turbo Induction | 32 | 01-14-2014 10:38 AM |
| removal of exhaust manifold bolt behind turbo | dooderek | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 02-27-2011 08:07 PM |
| Stock PCV Valve Removal | dizzin9 | MazdaSpeed 3/6 - Turbo Induction | 16 | 03-09-2010 09:21 AM |
