Like Tree40Likes
 Old 07-19-2011, 03:43 PM   #1
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
Default Stupid questions about BT build I am considering.
Looking to pick up a used 3071 or ideally a 3076 in the next couple months or when one becomes available. Have a few questions.
The budget I have is a little over a $1200. Not much I know.
Will a normal diameter TIP and intake work well enough with either of those turbos? Ideally I would like to upgrade to a 3.5 inch but it will have to wait.
Also going to have to be running the stock exhaust manifold and CNT catless DP. I know the stock manifold is shit and I will lose power by running it but are there any other concerns beside the loss of HP due to running stock manifold and intake?
Also I am running the CX Racing core. I know that it is too small for big power. Does anyone know of a specific larger CX core that can fit with minor modification to my pipes or bumper?
Also since I spray methanol I assume that moving from a d05 to a d07 would be preferable?
I plan on tuning it conservatively myself until I can finish the build later on (intake/EX manifold) and then getting a DJ tune.
I know its not an optimal build but will it work?
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
The Following User Says Thank You to dsmluck For This Useful Post:
rfinkle2 (07-19-2011)
 Old 07-19-2011, 03:48 PM   #2
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
Groans: 371
ok well the stock tip wont work with a 71 or 76 due to the inlet size of the turbo being 4inches
as far as the stock mani it doesnt flow terribly bad and it will do well with the budget you have. As far as the cx core we just did a drop in 3076 on my buddies car with the stock mani and just a cpe inlet and his car is a monster, just make sure are get the 71 or 76 with the mazda hotside so it will bolt up with no problems, meth is great idea also and yes get the bigger nozzle
trust me you will be way happier with this setup over the crappy k04
irishking03 and rfinkle2 like this.
The Following 6 Users Say Thank You to I Love Brownies For This Useful Post:
djuosnteisn (07-26-2011), dougefresh_ (07-21-2011), dsmluck (07-19-2011), knarfies (07-20-2011), lito37 (07-20-2011), rfinkle2 (07-19-2011)
 Old 07-19-2011, 04:02 PM   #3
Groans: 371
Let me know if you need help with the swap i wouldnt mind going to colorado for a weekend, we could get the whole swap done in about 5 hours
dsmluck, SKiZ0TT and rfinkle2 like this.
The Following 3 Users Say Thank You to I Love Brownies For This Useful Post:
dsmluck (07-19-2011), RayRay (07-24-2011), rfinkle2 (07-19-2011)
 Old 07-19-2011, 04:13 PM   #4
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Do it, the ko4 is your biggest bottle neck. If you change one thing, change the intake just because your only other option (that I know of) is super ghetto.... This is to take two couplers together. It will work, but it is ghetto. Also, you will need to find a way to extend your hot pipe... You could probably use 2 couplers and a metal pipe, or just have someone weld it for under $50.
Lastly, switch to a three port. They used to bs a pain to boost tune w the old atr, but work flawlessly w the revision.
Ckmazdaspeed3 is offline   Reply With Quote
The Following 4 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
djuosnteisn (07-26-2011), dsmluck (07-19-2011), RayRay (07-24-2011), rfinkle2 (07-19-2011)
 Old 07-19-2011, 04:24 PM   #5
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
I have a CPE inlet for BT (4 inch mouth).
Let me know if you want to buy it.
2008 STi
Intake
Turboback
AP
 Old 07-19-2011, 04:26 PM   #6
Groans: 134
Buy it! Except I bet 4" is a bitch to fit... Probably need to relocate ecu
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 07-19-2011, 04:27 PM   #7
Do you have a small battery CK, or did you re-mount the ecu on the front of the battery box?
 Old 07-19-2011, 04:33 PM   #8
Groans: 134
Put it in the battery trey. I bet you could do that mod yourself, but u may need smaller battery for 4". Mine is 3.5 and that bitch is snug!
 Old 07-19-2011, 04:39 PM   #9
danesti's Avatar
Groans: 137
The one I'm selling is only 4 inch for the turbo inlet. Otherwise it fits similar to stock.
2008 STi
Intake
Turboback
AP
 Old 07-19-2011, 04:49 PM   #10
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Originally Posted by ms307nm View Post
Let me know if you need help with the swap i wouldn't mind going to Colorado for a weekend, we could get the whole swap done in about 5 hours
It'll be nice if in Austin area we could have pple like you around. I'm just wondering how helpful some of you are here.
May be I just moved to a wrong state dude.
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
 Old 07-19-2011, 04:54 PM   #11
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
It should actually work.
Everything Eric said is spot on. As long as it's a bolt-on turbo you should be able to get away with the CP-E inlet, I believe it was actually made to fit without moving the battery. I'd suggest running a bigger MAF housing as well.
NATOR PA
 Old 07-19-2011, 05:02 PM   #12
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
As for your intercooler question, I seriously doubt the core is big enough. I have the CXRacing kit, and I've been thinking about getting a bigger core for the K04. This one is 1" thicker and 1" taller, it's what I've been thinking about purchasing. It will fit perfectly, but you would need to take an inch off the 2 "L" brackets that mount to the top of the core (since its an inch taller)
In case the link doesn't work right, its the IC0013 core... same length as the core that comes with the kit, again, just 1 inch thicker and taller (similar dimensions to the COBB core) cxracing.com: Front Mount Intercooler 28"x8"x3.5", 3.5" Core: 22x8x3.5, 2.5" Inlet & Outlet, Talon Eclipse Jetta
Fatguy729 is offline   Reply With Quote
 Old 07-19-2011, 05:11 PM   #13
frodaddyweez's Avatar
Posts: 988   (View Stats)
frodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the world
Subbed. Thinking of a 71 myself. Yeah it sucks that not many people in Texas that are BT are on this forum. I'm looking at doing a similar setup as you but without meth at the moment. I'll get the mani down the road later.
2009 Mazdaspeed3: PTE 5857 25psi etuned by tooslow2010 --> SOLD
2011 Mustang Shelby GT500 w/SVTPP: 2.3L Trinity TVS w/2.4" VMP pulley, L&M NSR cams, JLT 123mm Intake, FRPP CobraJet Twin 65mm Throttle Body, 56# Injectors, VMP Fuel Pump Booster, AFCO Dual Pass Heat Exchanger, FRPP L Springs, BMR Adjustable Panhard Bar, Shaftmasters Aluminum One-piece Driveshaft, Lethal Performance Catless H-Pipe, Flowmaster Outlaw Axleback, 315 NT05r's
Lund Tuned 683whp/622wtq 11/11/16
Upcoming mods: Full-length Headers and ID1300s for E85
1995 Mazda Miata: Stock (daily)
frodaddyweez is offline   Reply With Quote
The Following User Says Thank You to frodaddyweez For This Useful Post:
Angr-E1 (07-19-2011)
 Old 07-19-2011, 07:22 PM   #14
Groans: 371
hey man my brother lives in housten so i could kill 2 birds with one stone if you ever need help.
Tom, you are spot on with that cpe inlet that dane sti has for sale it would work with standard size panisonic battery without relocating the battery or ecu. bigger maf would be nice but stock housing is ok with our buddies car.
im sorry but i completely disagree with you. my buddy is running the same exact set-up as the op described and his car is running 22psi till redline and it pulls like a freight train. we are at 5500 feet up here and his meth is on order next week and we will pry take him up to 25 psi and that cx core will do just fine. iirc that core is rated to 400hp so i dont see any reason to change it unless we really find out it becomes a bottle neck
joel jmhinkle is running a core that is rated for 450 and when we went to the dyno he made close to 500 whp. really his ic did become a bottle neck but it actually went over what it was rated for. when we up his boost to 25 psi and take his timing up on the dyno we will really find out if that cx core is only good what its rated for.
bertrand_CX_7 and RayRay like this.
The Following 5 Users Say Thank You to I Love Brownies For This Useful Post:
bertrand_CX_7 (07-19-2011), dsmluck (07-19-2011), knarfies (07-20-2011), MS3-a(sore)ASS-rex (07-19-2011), RayRay (07-24-2011)
 Old 07-19-2011, 09:24 PM   #15
dsmluck's Avatar
Groans: 60
Serious? That would be awesome. Its always just me working on my car by myself. I figured I would have to give myself the better part of a weekend to do it. Only other turbo swap experience was on my old GSX. I found a way to turn a 3 hour job into a full day. I doubt I will have all of the parts necessary before the end of August. I will be at the mercy of someone parting out a 71 or 76 during that time. If it works out and you have the time I would more than welcome the help and some company during the swap.
Good info. Thanks! Gonna stay MBC I think for the time being because its easy to adjust.
How much you asking for that bad boy? I assume I could use a step down coupler to get it to mate up to my intake?
Last edited by dsmluck; 07-19-2011 at 09:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-19-2011, 09:29 PM   #16
dsmluck's Avatar
Groans: 60
Problem then is I am hitting the money wall. Granted it may not be the best idea to go BT when I am far from rolling in money but I honestly cannot stand knowing im a turbo away from an extra 75hp when I have already spent soo much time and money over the last two+ years for maybe 60hp.
Is there a cheap(er) option for a big maf?
 Old 07-19-2011, 09:35 PM   #17
dsmluck's Avatar
Groans: 60
That would be perfect and not too difficult to get it in there. It will have to wait a few months until after I get a turbo but I think I will go that route. If I have to run lower PSI until I upgrade I will manage. Seriously i have massaged the stock k04 for all its worth and I am likely sitting on 260whp at my altitude. I think a BT would be an epic improvement. Thanks for the heads up.
 Old 07-19-2011, 09:50 PM   #18
dsmluck's Avatar
Groans: 60
Good to hear about the intercooler. Gives me motivation for the BT build. Also glad to hear that you can run the bigger inlet with the stock MAF. Gotta keep this build cheap.
 Old 07-19-2011, 09:55 PM   #19
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
nice, post as many pics as possible.
subbed
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 07-19-2011, 09:55 PM   #20
Groans: 371
yeah man shit is pretty fun and pretty simple. ive already done the swap 4 times so i know it really well. once the mani is off its a breeze and i can get the mani off in about an hour or so.
i will be doing my gtx3076 soon cause i decided to save up a little more and go with that turbo. only thing is im going with ewg cause it sounds sexy
keep me posted on when and if you need help so i can plan a trip up there
just to give you an idea my buddy spent 1800 for all brand new parts and some crazy 2 day shipping. i think you will have no problem hitting your budget with used parts
The Following User Says Thank You to I Love Brownies For This Useful Post:
MS3-a(sore)ASS-rex (07-20-2011)
 Old 07-19-2011, 10:11 PM   #21
dsmluck's Avatar
Groans: 60
subbed
I will. Waiting until next week to make sure my school grants are in order and then I will post up a WTB.
In the meantime though if anyone knows of someone wanting to part out a 71 or 76 in good condition let me know.
EWG is definitely sexy. I will let you know once I have all the parts secured. Might be a bit though. Had a 3071 a while ago awaiting install before and the government decided to take a bunch of my money so had to sell it. Hopefully this time is much less eventful.
If it works out and you can come down you can stay at my place. You been down to Denver before? You have no idea how bad I dread tackling this swap myself. I think most of the guys here with BT just pay someone to do it. Nothing wrong with that but I don't like to pay someone to do something I can learn by working on it myself or with help.
Last edited by dsmluck; 07-19-2011 at 10:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-19-2011, 10:15 PM   #22
Groans: 263
cool, i got time. i wanna do the same. put a big turbo on shit.
i hope everything goes well.
YOU CAN DO IT!!!!!!
dsmluck likes this.
2010 Black Mica
The Following User Says Thank You to rghispanic88 For This Useful Post:
 Old 07-19-2011, 10:24 PM   #23
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
i want to see a BT swap for $1200
it's fun to do bad things
 Old 07-19-2011, 11:38 PM   #24
dsmluck's Avatar
Groans: 60
Don't see why not. Snagged a 3071 last time for $950. Already have the major supporting mods. Just gotta be patient about fining a turbo.
 Old 07-20-2011, 03:56 AM   #25
azokaei's Avatar
Posts: 75   (View Stats)
azokaei is just really niceazokaei is just really niceazokaei is just really niceazokaei is just really nice
So your buddy running the 3071r was running IWG? and did he have it ported? if he didn't how was the boost creep?
HPS CAI, Corksport Downpipe, Custom Test Pipe, Resonator Delete, Forge BPV, Cobb Accessport Stage 2, WR Oil Catch Can, Ptp Pcv Fix, more to come!
azokaei is offline   Reply With Quote
 Old 07-20-2011, 04:12 AM   #26
Groans: 224
You can make yourself a custom intake instead. Using silicone couplers and a maf housing from somewhere like siliconeintakes.com. We have a denso style MAF so keep that in mind when putting everything together. I'd also highly recommend an air straightner if at all possible.
NATOR PA
 Old 07-20-2011, 04:28 AM   #27
Groans: 134
Oh yeah, mbc works too, you just lose the safety of ebc.
 Old 07-20-2011, 07:43 AM   #28
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
If you have the AP you can still set throttle and fuel cut for boost limits because the car still reads boost off the MAP.
At least I think so. I will double check with Brandon @ Cobb today because I'm running MBC.
 Old 07-20-2011, 07:51 AM   #29
Groans: 371
yeah i have been to denver quite a few times, i actually have some friends (chicks) that live dt up there so we can go celebrate with them after the install. its only a 5 hour drive from santa fe but i might fly so i dont have to rack up the miles on my car.
@azokaei i dont know if your talking to me but my buddy is running the 3076r from atp and he got the higher boost iwg spring of 14psi instead of 7 psi. the install went so smooth to only find out he could only make 3psi of boost. found out his iwg was staying straight open
so on my day off rob and i troubleshot his problem and atp had installed the wga backwards and it was binding on his coolant to egr line. after removing the turbo and redoing the wga i reset the pre-load on the iwg to right about 17 psi and now his wgdc is about 10% at 21psi. atp has to custom make each high boost wga so the install was a fail on there part
dsmluck and RayRay like this.
dsmluck (07-20-2011), knarfies (07-20-2011), MS3-a(sore)ASS-rex (07-20-2011), RayRay (07-24-2011), rfinkle2 (07-20-2011), triplejumper18 (07-20-2011)
 Old 07-20-2011, 07:55 AM   #30
On that note: I wouldn't feel too comfortable running the stock 2.5 bar map sensor @ boost any above 21.25 psi.
Lex is coming out soon with a device that will help.
Assuming the map sensor is accurate +/- .5psi
Ckmazdaspeed3 (07-20-2011), triplejumper18 (07-20-2011)
 Old 07-20-2011, 08:17 AM   #31
knarfies's Avatar
Posts: 2,568   (View Stats)
knarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the world
ya that buddy hes talking about is me haha.
ya was pretty shocked to see that atp made such a noob mistake but the turbo is a monster now. with the cxracing kit you shouldnt have to cut the hot pipe just make sure have the appropriate 45 (edited )degree coupler.
Before i was able to get time with dustin to sit down and tune for a couple of hours we had the stock solenoid disconnected and i was holding 20 psi actually with just spring pressure. Installed the 3 port just to learn that i didnt need it so now running the stock solenoid fine and dandy.
only problem ive had was the return coolant line from the turbo but thats just oddness right there. nothing that cant be fixed with a new hose etc.
with the stock mani i start spooling around 3700 hundo and hit full boost at 4200 so i cannot complain. gotta love 22 psi at redline : )
knarfies is offline   Reply With Quote
The Following 4 Users Say Thank You to knarfies For This Useful Post:
dsmluck (07-20-2011), I Love Brownies (07-20-2011), rfinkle2 (07-20-2011), triplejumper18 (07-20-2011)
 Old 07-20-2011, 08:26 AM   #32
Groans: 196
You guys have seen my ATP Rage Comic right?
I have a Bosch 3 BAR MAP sensor in my garage as well.
The Following User Says Thank You to triplejumper18 For This Useful Post:
 Old 07-20-2011, 08:32 AM   #33
lito37's Avatar
Posts: 172   (View Stats)
lito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the worldlito37 is the leader of the world
Groaned at 7 Times in 4 Posts
my battery relocation, getting ready for the same thing.
lito37 is offline   Reply With Quote
The Following 2 Users Say Thank You to lito37 For This Useful Post:
knarfies (07-20-2011), rfinkle2 (07-20-2011)
 Old 07-20-2011, 09:00 AM   #34
meh, no ideas
Jedyboyrokr's Avatar
Posts: 528   (View Stats)
Jedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the world
Groaned at 20 Times in 4 Posts
Burn813 is trying to get rid of his BT
89 toyota supra 1JZ Twin Turbo---Sold
2006 MS6 GT few mods ---Sold
Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th
Jedyboyrokr is offline   Reply With Quote
The Following User Says Thank You to Jedyboyrokr For This Useful Post:
 Old 07-20-2011, 09:02 AM   #35
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Jed the turbo is already gone
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline   Reply With Quote
 Old 07-20-2011, 09:21 AM   #36
Groans: 134
Yeah, that makes sense. I'm not sure why, but I thought that the lack of boost cut was a major drawback.... But now that I think about it, you have to bs right.
 Old 07-20-2011, 09:23 AM   #37
Groans: 371
actually you will need a 45* not a 90* coupler coming off the compressor side of the turbo to make the cx kit work with that turbo without any modification
 Old 07-20-2011, 01:32 PM   #38
azokaei's Avatar
are you running a catless or catted downpipe?
How did you adjust the preload on the iwg?
 Old 07-20-2011, 01:35 PM   #39
The arm on the iwg to actuator rotates.
Edit: see post 41.
 Old 07-20-2011, 01:37 PM   #40
Groans: 371
on his there is a nut that you would loosen or tighten to adjust the preload setting and he is running catless
after we preloaded we went to go test it to see what we preload it at and would just adjust it to our liking. we hooked it up to a mechanical boost gauge and an air compressor to test how many psi the iwg would see and when it would open. i took video and will get it up loaded tonight so you can see what im talking about
azokaei (07-20-2011), dsmluck (07-20-2011), rfinkle2 (07-20-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/stupid-questions-about-bt-build-i-am-86364/
Considering A Christmas Santa This thread Refback 07-20-2011 06:49 AM
A few build questions....... jracer MazdaSpeed 3/6 - Big Turbo Builds 11 02-21-2011 02:04 PM
Stupid thread, stupid question but will ask anyway JohnMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-26-2011 12:51 AM
Build status & questions Speedie6 Mazdaspeed3/6 General Discussion 15 05-19-2009 08:51 PM
Stupid/annoying issue - noob questions aaronc7 MazdaSpeed 3/6 - Turbo Induction 16 11-18-2008 05:47 PM
Page generated in 0.67207 seconds with 37 queries
