Like Tree10Likes
 Old 11-30-2016, 08:40 PM   #1
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Default Super-Cheater K04
Ported K04-882 (Mazdaspeed) Turbine Housing
-Heavily ported turbine entry housing & wastegate. No porting past the first bend of the housing.
-Bored and radius'ed for larger turbine wheel
-Wastegaste bored 2mm over.
Ported K04-582 (CX7) Compressor Housing
-Light porting of whole A/R.
-Bored and radius'ed by Turbolab for larger billet compressor wheel
Turbine Wheel
-Mamba "Extreme" K04 Turbine
-Clipped 10 degrees and balanced with comp wheel by Bullseye Power
K04 Extreme Turbo Turbine Wheel Borg Warner K03 K04 AUDI VW
Compressor Wheel
-Turbolab billet wheel
Bottom line:
Why are you doing this, when you could buy an atp or S3?
I wanted to have fun with non-stock turbos, but be obviously breaking stock/prepared class rules of AX/rallycross based on visual inspection.
Will it work?
I don't know, let's find out.
Well, if it works, how much power will it make?
I guess- IF it works, it might make somewhere between an S2 and a S3, just based on the size of the turbine wheel and compressor wheel.
Why did you use a CX7 Compressor housing- isn't a Mazdaspeed housing better?
I bought a used turbolab modified turbo to start this project that came with that housing, but as far as I can tell, the only major difference between the CX7/MS compressor housing is the inlet diameter (which was bored out for the larger compressor wheel anyways).
Reference:
K04 Differences: K0422-582 vs. K0422-881 / K0422-882
k04 CHRA pictoral disassembly
SofaKingAwesome and WetzMS3 like this.
-feejay
-wetzel
The Following 15 Users Say Thank You to zenit For This Useful Post:
Code Monkey (12-01-2016), Design (12-02-2016), Djohns (11-30-2016), dsb_chicago (01-24-2017), FlyingLotus (12-02-2016), impossible (01-25-2017), JSmith (11-30-2016), KiwiFlavor (12-01-2016), Mazdazilla6 (12-03-2016), MSMS3 (12-03-2016), Nailedit187 (12-01-2016), SofaKingAwesome (12-07-2016), tegxsi (12-02-2016), WAMBUSHHHH! (12-01-2016), WetzMS3 (12-01-2016)
2.1M Audi vehicles used cheater software Haltech Automotive News 0 09-28-2015 08:30 AM
Mercedes named top cheater on Europe's fuel economy test Haltech Automotive News 0 11-09-2014 01:10 PM
O2 cheater? deadbeatrec Gen2 MS3 General Discussion 15 11-14-2011 10:54 AM
SEMA Preview: 900-HP Super Challenger and Super 'Cuda Haltech Automotive News 1 10-14-2008 04:41 PM
Super rich may avoid super expensive cars because of bad image Haltech Automotive News 0 10-02-2008 06:10 PM
Page generated in 0.65680 seconds with 36 queries
