 Old 07-15-2017, 01:52 PM   #1
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Default Super conservative tune for stock HPFP
My turbo is leaking about as fast as I can dump oil in. I'm looking either at the BNR S1 or Corksport turbo. With all the studs and miscellaneous stuff there is a minimal price difference. I would prefer the corksport turbo however I never had my HPFP done, and would not be able to for a few weeks after the install, would it be safe for me to just get a custom E-tune and drive it without upgraded internals?
tom10122 is offline   Reply With Quote
 Old 07-15-2017, 03:22 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You need the hpfp before any tune. Just disconnect the ebcs and run spring pressure on the new turbo until you can afford the hpfp and tune...
 Old 07-15-2017, 03:33 PM   #3
tom10122's Avatar
When I say conservative tune, I mean essentially de-tuning the car. Running considerably less than stock boost.
Sent from my XT1565 using Tapatalk
 Old 07-15-2017, 03:40 PM   #4
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
No
2018 Audi RS3
2007 Acura TSX 6MT
 Old 07-15-2017, 06:12 PM   #5
Groans: 60
That can be accomplished without wasting money on a temp tune. Use that money on the hpfp..
 Old 07-15-2017, 07:32 PM   #6
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
No you cannot, just get your turbo rebuilt if the wheels haven't touched the housing yet
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
 Old 07-16-2017, 01:07 PM   #7
Posts: 2,826   (View Stats)
BNR Stage 1 replicates stock K04 flow and spool. Identical performance on stock tune. It uses a Garrett 28 series CHRA inside a modified K04 housing. Stock performance with no more "smoking turbo" concerns.
Compatible with all stock bolt ons and K04 tunes.
E85/hpfp/tune MZRSPEED 2010 MS3 - Dyno Sheets/Discussions 4 01-27-2014 05:57 PM
Trying to tune with AP which map for sri,tih,dp,hpfp from cobb help please Breathless 2010 MS3 - ECU Computer Tuning 10 03-05-2012 08:18 PM
Upgraded HPFP w/o Tune? f-castrillo 2010 MS3 - Engine, Transmission & Driveline 36 09-10-2011 07:14 PM
Upgraded HPFP on stock tune Meder MazdaSpeed 3/6 - ECU Computer Tuning 21 02-01-2011 04:05 PM
Page generated in 0.27203 seconds with 24 queries
