  • 1 Post By nattun
 Old 08-11-2011, 11:39 AM   #1
nattun's Avatar
Posts: 260   (View Stats)
nattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default Symptoms of a bad MAP sensor?
A few weeks ago I picked up a dashhawk. I decided to monitor boost with it and my boost gauge for comparison. The dashhawk was never even close to actual boost levels. Its almost always in vacuum and off more that 5psi at higher boost levels. I posted before and others said I needed a MAFcal. Eventually I got a HT and set the cal to my intake, same result.
I also seafoamed my car and got a cel, I checked it with my DH. It was a misfire code which is understandable but I also got another one, something about a bad MAP sensor. I dont remember the code.
I was seeing 15.x stock and now 17.x with HT. Seems to me the boost levels are correct and everything else seems to be fine so I dont know whats going on. Any ideas?
hotshot1058 likes this.
2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled
2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820
nattun is offline   Reply With Quote
 Old 08-11-2011, 12:08 PM   #2
if you dont write down the code its hard to help you.
also 15.9 and 17.1 arent unusual for hotter/colder days. the ECU till target the boost it needs to hit a load target.
 Old 08-11-2011, 12:11 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Its also usually the other way around, your boost gauge probably isnt correct.
2006 Mazdaspeed 6
 Old 08-11-2011, 12:51 PM   #4
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I got an intake temp DTC that told me my MAP sensor was bad.
- Tapadatass
 Old 08-12-2011, 02:41 PM   #5
nattun's Avatar
Yeah I shouldve written it down because it hasnt came back but the dashhawk reading is still way off. I was just saying Im seeing normal boost levels for stock and hypertech tunes with my gauge. Im pretty sure my boost gauge is correct because I am seeing normal levels and I tested it against a NIST certified gauge before I installed it.
What are the symptoms of your clutch going long101 Mazdaspeed3/6 General Discussion 24 09-02-2012 12:43 PM
Sensor 1 low input(Knock sensor)? SpeedKAF MazdaSpeed 3/6 - Turbo Induction 0 07-02-2011 10:30 AM
Failin VVT symptoms ? jracer Mazdaspeed3/6 General Discussion 0 11-20-2010 12:25 PM
What are the symptoms of a Boost Leak? Arrowpoint MazdaSpeed 3/6 - Turbo Induction 7 03-11-2009 09:26 PM
Symptoms of an exhaust leak? Baseballpler Mazdaspeed3/6 General Discussion 10 01-19-2009 08:55 PM
Page generated in 0.25916 seconds with 23 queries
