 Old 12-25-2010, 01:58 AM   #41
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
I've had 2 of their products and both ran like champs...
 Old 12-25-2010, 02:16 AM   #42
Smoker6's Avatar
Posts: 984   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
I've used a couple of different BPV's/BOV's on my speed6, and I'm the most satisfied with the Synapse I've been running for the past year, nothing but praise. Absolutely no point in me "upgrading" to this, but I suppose 2 ports instead of 3 is nice.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline   Reply With Quote
 Old 12-25-2010, 10:20 PM   #43
smakdown61's Avatar
Posts: 1,069   (View Stats)
If you look at their "engineering" for any of their stuff for this car its all marketing bs. You can get the same results for half the price on a regular aftermarket bpv.
smakdown61 is offline   Reply With Quote
The Following User Says Thank You to smakdown61 For This Useful Post:
MSMS3 (12-27-2010)
 Old 12-26-2010, 12:40 AM   #44
that1rowdyracer's Avatar
Posts: 245   (View Stats)
that1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the worldthat1rowdyracer is the leader of the world
this looks like its alot easier to install compared to the last one, which from what I saw was a bitch to hook up.
that1rowdyracer is offline   Reply With Quote
 Old 12-26-2010, 02:06 PM   #45
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
those fittings are nice. how does the line connect to the Y fitting? it just goes inside?
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline   Reply With Quote
 Old 12-26-2010, 02:39 PM   #46
hnda etr's Avatar
Groans: 90
Yes, they just push in.. These are te same type of quick connect fittings that come in the devils own meth kits
 Old 12-27-2010, 04:38 PM   #47
Posts: 2,826   (View Stats)
So true. And, you can get the same results for free by just putting the stock BPV back on. It is extremely effective up to the maximum safe boost for the K04 turbo. Free is always good, especially when there is no power to be gained by spending money on an expensive BPV, and power to be lost by running any diverter valve with other than full recirc on this engine.
 Old 01-02-2011, 04:37 PM   #48
the stock valve may work fine, but isn't nearly as quick though. for the record, i took my synapse dv off b/c i put the stock airbox back in.
 Old 01-02-2011, 10:45 PM   #49
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
seems like it only needs vacuum, no more boost fitting i presume?
Mazdanspeed3 is offline   Reply With Quote
 Old 01-02-2011, 11:39 PM   #50
hnda etr's Avatar
Groans: 90
Correct
Sent from my iPhone using lame ass Tapatalk
 Old 11-24-2014, 10:09 AM   #51
mrQQ's Avatar
Posts: 1,164   (View Stats)
I bought this. The part which goes to recirc hose was SOOOOOO hard to push into the DV, that I don't think i'd be able to take it out.
mrQQ is offline   Reply With Quote
 Old 03-12-2015, 08:17 PM   #52
brainiac5572's Avatar
Posts: 4   (View Stats)
brainiac5572 is a splendid one to beholdbrainiac5572 is a splendid one to beholdbrainiac5572 is a splendid one to beholdbrainiac5572 is a splendid one to beholdbrainiac5572 is a splendid one to beholdbrainiac5572 is a splendid one to beholdbrainiac5572 is a splendid one to behold
Groaned at 13 Times in 1 Post
Didnt know about "con" they tried to pull... just went with recommendation from Stratified as i'm going BT. Put it together (will be a bitch to put together if flange and other piece are not seated all the way to get ring teeth around it... once seated, it was no problem other than big fingers trying to thread small nut/bolt). Will install it this weekend and update this post with my initial impressions.
Update... 4/5/2016... valve seems to work flawlessly... I opened it up this weekend to see if it needed any cleaning, but it was perfectly clean and greased... put it back together... no leaks that I'm aware of... will do a "soapy water" test to see if it's leaking anywhere
brainiac5572 is offline   Reply With Quote
 Old 07-19-2017, 05:28 PM   #53
mousecop's Avatar
Posts: 1   (View Stats)
mousecop has a little shameless behaviour in the past
just replying so i can see the pics
mousecop is offline   Reply With Quote
The Following 2 Users Say NO Thank You to mousecop For This Un-useful Post:
MSMS3 (07-23-2017), Thor Hammer (07-20-2017)
 Old 07-19-2017, 06:31 PM   #54
monkey.bones.007 (07-19-2017), MSMS3 (07-23-2017), Thor Hammer (07-20-2017)
Synapse Engineering:my Review of Synchronic and my dyno...soon samoan MazdaSpeed 3/6 - Turbo Induction 9 04-27-2008 12:42 AM
Page generated in 0.31941 seconds with 32 queries
