 Old 04-11-2014, 06:19 PM   #1
zrenine's Avatar
Posts: 18   (View Stats)
zrenine is on a distinguished road
Groaned at 8 Times in 4 Posts
Default Test Pipe, Fuel Pump Internals w/Stage 2 OTS stock speed6?
So I have an 07 mazdaspeed 6 and I've been running the cobb ots stage 1 maps on a completely stock engine for almost a year now with no problems. I just ordered a Test Pipe from ProTuningLab 2.5inch catless (which from my research is like an ebay or ATP TP) and the CorkSport MZR fuel pump internals. My first question is, do I have a more likely chance of the turbo smoking even if I'm running 5w40? It has never smoked before. And will this be sufficent flow to run the stage 2 OTS maps from either corksport or cobb? I've heard that you need a downpipe. Also, what kind of gains should I expect on completely stock car with stock CBE? The only mods I have done are a CS rear engine mount and Accessport stage 1 91 OTS from cobb and JBR egr delete and 1 step colder autolite plugs gapped at cobb recommended specs. .028 if i remember correctly. Car has just over 72,000 miles and I'm just nervous about the smoking k04 that I've read about. Any insight would be helpful as I am still under warranty and not looking to get too crazy with mods. Thanks!
zrenine is offline   Reply With Quote
 Old 04-11-2014, 06:34 PM   #2
nmmazdaspeed3's Avatar
Posts: 173   (View Stats)
nmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond repute
I have an 09 MS3 and my turbo started smoking at 50k miles. As soon as it started I did research here on the forums. As a result of those searches, I bumped up my idle, added an OCC (which I should have done much sooner) and upgraded the banjo bolt. I haven't smoked since. I'm holding off as long as possible before having to replace the turbo. My hopes are that I caught it soon enough. I ran the Cobb OTS tunes for a while and just recently switched to a FreekTune. I highly recommend not bothering with any more OTS maps and work with Justin. He's running a sale right now and it's well worth the small price. Check out the vendor section for the sale info.
nmmazdaspeed3 is offline   Reply With Quote
The Following User Says Thank You to nmmazdaspeed3 For This Useful Post:
jambisgone696 (04-11-2014)
 Old 04-11-2014, 06:59 PM   #3
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Ots maps are......ok. but an etune is best for long term. I would stick with stage 1 ots until you have other supporting mods and then get an etune. Intake and occ would be the next things I suggest. Change to ngk or denso plugs.
Big Dog is offline   Reply With Quote
The Following User Says Thank You to Big Dog For This Useful Post:
Page generated in 0.25293 seconds with 22 queries
