Like Tree6Likes
  • 1 Post By dooderek
  • 1 Post By dMuze
  • 4 Post By Macedawg
 Old 08-19-2011, 01:18 AM   #1
xjon's Avatar
Posts: 12   (View Stats)
xjon is a splendid one to beholdxjon is a splendid one to beholdxjon is a splendid one to beholdxjon is a splendid one to beholdxjon is a splendid one to beholdxjon is a splendid one to behold
Default Think my boost is gone
This is a stock ms6 with 96k miles on it. Just yesterday I've noticed that I don't get the surge driving around town. So I kept pushing it and with steady throttle the Rpms just went up steadily past 3500 all the way up to 5500.
I dont have a boost gauge so I don't have a before and after pressure numbers.
Needing suggestions on how to diagnose without having to take to a shop.
Thanks in advance.
06 speed6 (7/1/11 96k)
xjon is offline   Reply With Quote
 Old 08-19-2011, 02:30 AM   #2
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
BOOST IS BASED ON LOAD NOT RPMS. STEADILY INCREASING YOUR RPMS WITHOUT INDUCING ENGINE LOAD WILL NOT CREATE BOOST NOR IS IT ANY WAY OF TESTING FOR IT. YOU CAN HAVE VACUUM ALL THE WAY TO REDLINE. THERE CAN BE A NUMBER OF THINGS CONTRIBUTING TO THE LOSS OF "SURGE"
1) HEAT SOAK
2) PSYCHOLOGICAL
3) SOMETHINGS BROKEN
4) BOOST LEAK
WITHOUT A GAUGE OR A SCAN TOOL/OBD READER IM AFRIAD THERE IS NO REAL WAY OF TELLING HOW MUCH BOOST YOU ARE PRODUCING. CHECK YOUR BOOST TUBES (COUPLERS) TO YOUR INTERCOOLER. ALSO YOU MAY WANT TO PRESSURE THE SYSTEM (GOOGLE)
BUT FIRST I HIGHLY ADVISE YOU TO GET SOME SORT OF MONITORING DEVICE. IF YOU ARE TIGHT ON CASH THEN YOU CAN GET A CHEAP MECHANICAL BOOST GAUGE FROM AUTOZONE OR PEPBOYS. IF YOU NEED ADDITIONAL HELP FEEL FREE TO PM ME.
skeeter149 likes this.
The Following 5 Users Say Thank You to dooderek For This Useful Post:
helmetface (08-19-2011), LuczOr (08-24-2011), sellers (08-19-2011), skeeter149 (08-19-2011), tddvrrn (08-19-2011)
 Old 08-19-2011, 02:44 AM   #3
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
Thanks in advance.
I vote heat soak. Summer temps + TMIC = much less power.
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
 Old 08-19-2011, 08:56 AM   #4
xjon's Avatar
Thanks for replies...
Im doubting heat soak. I can run it in the foggy morning and results are the same.
Psychological- probably true. I've only had the car for couple of months and just driving around town it would nudge my head back unexpectedly but not anymore. That's just regular driving and not WOT.
I do have a cheap scan tool but I figure it won't tell me anything since there is no CEL (correct?).
Looks like I'm going to need a boost gauge. Where do I plumb the line to get a pressure reading? I have access to some gauges at work that I think I can fashion as a temporary diagnostic tool.
What are symptoms of a broken waste gate or bov?
I cant hear the turbo spool before or after while driving. Can I listen for it in the engine bay if someone revs my engine?
 Old 08-19-2011, 09:01 AM   #5
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
You can probably use the scan gauge to get manifold pressure. Subtract 14 from that (usually what atmospheric psi is) and you should get approx boost. Or buy an ultra gauge for $60 and do the same..
 Old 08-19-2011, 09:05 AM   #6
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
dude, if you still have stock tmic, it's easy as hell to check for boost leaks.
07 MS3
The original Genpoo Hater
 Old 08-19-2011, 09:07 AM   #7
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
Yep, when I was stock TMIC, those balloon boost tubes would loosen up all the time. T-bolts FTMFW.
The Following User Says Thank You to darth vader For This Useful Post:
SLOWHATCH (08-19-2011)
 Old 08-19-2011, 09:22 AM   #8
Spirry's Avatar
Posts: 700   (View Stats)
Spirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the worldSpirry is the leader of the world
Groaned at 28 Times in 15 Posts
Did you retrace your steps? Maybe you dropped it somewhere...
Spirry is offline   Reply With Quote
The Following 4 Users Say Thank You to Spirry For This Useful Post:
Black Metal (08-19-2011), Chimmike (08-19-2011), jack_hammer (08-19-2011), Nazarite (08-19-2011)
 Old 08-19-2011, 09:24 AM   #9
Blue 2 shims
Nazarite's Avatar
Posts: 2,254   (View Stats)
Groans: 66
I swear if my boost wasn't screwed on...
Nazarite is offline   Reply With Quote
The Following 3 Users Say Thank You to Nazarite For This Useful Post:
Black Metal (08-19-2011), dMuze (08-19-2011), Docnox (08-19-2011)
 Old 08-19-2011, 09:55 AM   #10
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I lose that boost all of the time... It sucks man, good luck with finding it.
403whp/451ft/lb Dry Shot
 Old 08-19-2011, 10:07 AM   #11
03scgt's Avatar
Posts: 400   (View Stats)
03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world03scgt is the leader of the world
BOOST Y U NO HERE??
03scgt is offline   Reply With Quote
The Following 6 Users Say Thank You to 03scgt For This Useful Post:
Abu Zib (08-19-2011), Black Metal (08-19-2011), Chimmike (08-19-2011), NCZ13 (08-19-2011), sellers (08-19-2011), SLOWHATCH (08-19-2011)
 Old 08-19-2011, 11:42 AM   #12
xjon's Avatar
Thanks for all the replies.
 Old 08-19-2011, 11:46 AM   #13
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
i found a boost the other day, but it didn't have a tag so i put it in a burlap sack and drowned it in a pool... mike vick style.
it's fun to do bad things
Bucker (08-19-2011), Chimmike (08-19-2011), dMuze (08-19-2011)
 Old 08-19-2011, 12:05 PM   #14
Bucker's Avatar
Groans: 451
Have you checked the lost and found box at the library?
The Following User Says Thank You to Bucker For This Useful Post:
I Love Brownies (08-19-2011)
 Old 08-19-2011, 12:10 PM   #15
Rokusek's Avatar
Posts: 5,551   (View Stats)
damn i didnt think you could do that with a burlap sack... im gonna try that next time i find some boost
 Old 08-19-2011, 12:11 PM   #16
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
All your boost belongs to me!
Black Metal is offline   Reply With Quote
The Following User Says Thank You to Black Metal For This Useful Post:
03scgt (08-20-2011)
 Old 08-19-2011, 12:12 PM   #17
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Homeless boost makes me sad
*cue Sarah McLaghlan sad song*
07 MS3
Bucker (08-19-2011), Rokusek (08-19-2011)
 Old 08-19-2011, 12:52 PM   #18
Blue 2 shims
Nazarite's Avatar
Groans: 66
I'm going home to boost the wife at 3:30. Short Friday workday ftmfw.
 Old 08-19-2011, 12:58 PM   #19
Rokusek's Avatar
i can haz moar boost
 Old 08-19-2011, 01:00 PM   #20
Blue 2 shims
Nazarite's Avatar
Groans: 66
If all else fails, you may get a few laughs. Better than nothing, but not by much.
 Old 08-19-2011, 01:06 PM   #21
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
Someone boosted your boost.
Call the police and then your insurance company.
 Old 08-19-2011, 01:07 PM   #22
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
there is a thread from a guy wondering how to make friends in college...he will prob lend you some boost! or you can search how to make a boost leak tester. that's where i would start
Rokusek likes this.
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
The Following User Says Thank You to dMuze For This Useful Post:
 Old 08-19-2011, 01:09 PM   #23
Macedawg's Avatar
Posts: 1,168   (View Stats)
Macedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the world
go to the store and get some more..easy fix
Chimmike, Spirry, tddvrrn and 1 others like this.
Macedawg is offline   Reply With Quote
The Following 7 Users Say Thank You to Macedawg For This Useful Post:
Black Metal (08-19-2011), Chimmike (08-19-2011), jack_hammer (08-19-2011), Nazarite (08-19-2011), Pu Manchu (08-19-2011), Spirry (08-19-2011), wette460 (08-22-2011)
 Old 08-19-2011, 01:11 PM   #24
Rokusek's Avatar
DAMN I DIDNT KNOW YOU COULD BUY BOOST!!! AND ITS IN BULK TOO, HELLS YEA!!!
 Old 08-19-2011, 02:56 PM   #25
Groans: 78
So would that be considered 24psi?
 Old 08-19-2011, 04:33 PM   #26
theurgy's Avatar
Posts: 2,580   (View Stats)
 Old 08-19-2011, 09:29 PM   #27
xjon's Avatar
Originally Posted by theurgy View Post
...thats my question to you guys!
I notified the police...they cant do anything about missing boost unless its been missing over 48 hours.
I've posted "missing boost" flyers all through out the neighborhood though.
thanks for the laughs.
this lost is so depressing im going on vacation. When I come back I'll check back with you boost clowns.
The Following 5 Users Say Thank You to xjon For This Useful Post:
03scgt (08-20-2011), Black Metal (08-19-2011), Chimmike (08-22-2011), Raider (08-22-2011), tddvrrn (08-19-2011)
 Old 08-19-2011, 11:07 PM   #28
tddvrrn's Avatar
Groans: 103
i like your humor sensing. it make me laughing big time. have big time nice on vacation!
The Following User Says Thank You to tddvrrn For This Useful Post:
03scgt (08-20-2011)
 Old 08-22-2011, 01:02 PM   #29
embibb's Avatar
Posts: 49   (View Stats)
embibb is just really niceembibb is just really niceembibb is just really niceembibb is just really niceembibb is just really nice
Groaned at 4 Times in 1 Post
and this one time ... at boost camp...
embibb is offline   Reply With Quote
 Old 08-22-2011, 01:05 PM   #30
Will fuck up ur day
Chimmike's Avatar
Groans: 433
+1 to good noob sense of humor
07 MS3
 Old 08-22-2011, 01:12 PM   #31
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
ona serious note you dont have ANY of the required tools to properly diagnose this. you need at least a AFR gauge and a boost gauge.
can your scan tool read ltft and afr and boost im guessing not
 Old 08-24-2011, 10:14 AM   #32
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
I'm saying its all psychological and heat soak. I know my car is heat soaked to all hell these days.
Sluggish sucks.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following User Says Thank You to LuczOr For This Useful Post:
Chimmike (08-24-2011)
 Old 08-24-2011, 10:20 AM   #33
bender_'s Avatar
Posts: 10   (View Stats)
bender_ has a little shameless behaviour in the past
@ the boost jokes.
bender_ is offline   Reply With Quote
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 05:41 PM
Does Boost Dynamics (Boost Based Tuning) do anything? SJP0tato
Cobb ATR Support
2 04-12-2011 03:42 PM
Smooth Boost or boost jump. What is causing this, I am baffled. FreeFlyFreak
Cobb ATR Support
9 10-31-2009 01:38 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 06:36 PM
Page generated in 0.49583 seconds with 40 queries
