Like Tree6Likes
 Old 08-14-2011, 04:59 AM   #1
jonlax's Avatar
Posts: 312   (View Stats)
jonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the worldjonlax is the leader of the world
Default Thoughts on Intercooler sprayer
I pulled some things out of storage from before i joined the military and found 3 of my sneaky pete nos bottles. I originally used them on my 1991 turbo II RX7 for an intercooler sprayer.
I purchaced new and found a cyro style unit to mount to my front mount. worked great when i had to sit at english town and ATCO raceway on race days. Anyway long story short i am looking to adapt it to my top mount unit and eventually move it to my front mount whenever i get some cash for a new core.
Has anyone ran a system such as this with any results? Also anyone know when the NOS bottles need to be pressure tested again? They are 7 years old now and i can't find any thing on how long they are good for....
jonlax is offline   Reply With Quote
 Old 08-14-2011, 05:24 AM   #2
jonlax's Avatar
Also thoughts on changing to Co2 over the No2?
Seems No2 is colder than the Co2 but cost wise the Co2 is about 5 or so a tank.
 Old 08-14-2011, 05:48 AM   #3
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
Well it's been talked about before, so I would suggest searching. More people tend to spray deionized water on the intercooler than nos though.
 Old 08-14-2011, 11:31 AM   #4
darth vader's Avatar
Posts: 665   (View Stats)
Groaned at 9 Times in 9 Posts
....which'll make you a local hero at your track as you hose down the groove or racing line with water droplets....
The Following 2 Users Say Thank You to darth vader For This Useful Post:
Chimmike (08-15-2011), ScarMS3 (08-14-2011)
 Old 08-14-2011, 02:02 PM   #5
jonlax's Avatar
Very true, thus the reason i used No2. I see alot of people complain saying that the No2 is uneffective compaired to meth and water sprayed on the I/C.
Everyone knows water or meth pulles away latent heat but the possibility of water on the track isn't good. Also the effencenty is stated with meth/water being cheaper and No2 not doing much.
Here is my findings when i had my front mount on my RX7. My intake charge was up to 20 degrees colder. Now i never used meth/water spayed on the I/C which would lower it but thats depended on evaporation and we all know summer months it wont happen.
So i come to this.....Does anyone have any logs or evidence of a gain over the dreaded heat soak?
 Old 08-14-2011, 01:59 PM   #6
ScarMS3's Avatar
Groans: 97
If the ic is hot and it is a fine mist I would assume most would evaporate. But +1 for the hero comment.
 Old 08-15-2011, 04:59 AM   #7
shadesofgray19's Avatar
Posts: 794   (View Stats)
Meth/water sprayed in the motor is better, problem solved.
20boxer likes this.
The Following 2 Users Say Thank You to shadesofgray19 For This Useful Post:
08cosmic3 (07-18-2016), Thor Hammer (07-18-2016)
 Old 08-15-2011, 06:31 AM   #8
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Of course there will be a gain over heat soaked engine. You already have the equipment, just do it and post up pics and how to.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 08-15-2011, 09:10 AM   #9
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
I would say water, its all going to evaporate... Unless you are spraying it through a garden hose nozzle. Even if it doesn't evaporate, the valve cover is under the TMIC, and that bitch is hot as hell too. As a matter of fact, everything under the TMIC is hot as hell.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following User Says Thank You to LuczOr For This Useful Post:
Blackspeed (08-15-2011)
 Old 08-15-2011, 09:04 PM   #10
Mistersix's Avatar
Posts: 2,585   (View Stats)
I would try co2 simply because its cheaper. You may find the need to use much of it for a worthwhile effect. The IC's right on top the motor and will probably start heat soaking immediately after you spray.
 Old 08-15-2011, 10:32 PM   #11
86AmishMs3's Avatar
Groans: 338
I would want one just when i'm at the drag strip. when you're moving everything is fine, but when you are sitting there is no air to help cool. A sprayer would help to cool the intercooler before a run. During run it would keep it super cold. I would do it if i had the money
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 08-16-2011, 06:23 AM   #12
Mistersix's Avatar
But if your not moving how would the spray move over the intercooler? One would need some pressure to force the gas down, no?
 Old 08-16-2011, 08:09 AM   #13
86AmishMs3's Avatar
Groans: 338
When no2 or co2 comes out it comes out as a solid and it's also so cold it causes water to condensate and freeze. So it's not like it instantly evaporates
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 08-16-2011, 05:10 PM   #14
Mistersix's Avatar
What i'm saying is air needs to flow over the intercooler in order for it to exchange heat. So if if your staging for a race whatever you spray would HAVE to move threw the bars and fins to chill them.
Hence you would need the gas to spray at some pressure in order to do so. Its not like the intercooler is wide open on the other side its kinda blocked. Without air flowing under the car to create a low pressure zone, there's now vacuum to help air flow in the ducting, over the IC and down around the engine and out.
This is why i wonder, if spraying an IC thats essentially in a tube with no air flowing threw it, would even be effective.
I think the air flow dynamics need to be addressed before deciding on what gas to use.
The Following User Says Thank You to Mistersix For This Useful Post:
Juyoung (09-15-2012)
 Old 08-16-2011, 09:50 AM   #15
ScarMS3's Avatar
Groans: 97
co2 is a gas, unless its frozen...its not going to come out solid. ie dry ice.
 Old 08-16-2011, 11:44 AM   #16
brantms3's Avatar
Posts: 45   (View Stats)
brantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond reputebrantms3 has a reputation beyond repute
C02 for sure if you really want to try it . I thought about it after i saw some rednecks here in austin icing up there intercoolers before they shut the motors off on a bunch of 1JZ powered toyota sedan turds. but what was funny is that there cars actually idled better and ran better after each race on the streets. Test your theory withsome duster turned upside down or something. then if it shows any real advantage .. make up something permanent
2008.5 SPEEED3 OWNER AS OF 01/17/11.... Cobb SRI ..COBB TIP ... NEW CPE TMIC..CNTRACING CATTED DP AND FULL 3" CNT EXHAUST...KMD CDFP INTERNALS...COBB AP my custom tune. ..SURE SHORTcut and sure bushings and cobb weight .. SURe RMM 90 duro Track bushing..... THULE ROOF RACK W/ big mouth mounts... all rolling on TENZO typ-M 18x8 with 45 offset wrapped in 245's... On CORKSPORT springs
Next mod . MANIFOLD and BNR stage 3
brantms3 is offline   Reply With Quote
 Old 08-16-2011, 01:09 PM   #17
jonlax's Avatar
Well looks like I will be staying away from the Co2 just for the fact Its not as cold as No2 and the amount of Co2 needed is doubled.
Maybe the next nator day ill rig it up.
 Old 09-08-2011, 10:10 AM   #18
Islandromeo's Avatar
Posts: 17   (View Stats)
Islandromeo is infamous around these partsIslandromeo is infamous around these parts
Iv seen this method used very efficiently here in Hawaii where its hot and humid as hell I'd say try it but try to see if you could some how protect the motor from direct spray maby a deflecting under the TMIC
Islandromeo is offline   Reply With Quote
 Old 09-08-2011, 05:37 PM   #19
jonlax's Avatar
If you put a deflector on the top mount you will loose any cooling it offers. A low pressure is below it which helps airflow.
I don't think a deflector would be needed anyway.
 Old 07-18-2016, 02:03 PM   #20
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
g00s3y (07-18-2016), KiwiFlavor (07-19-2016), Vansquish (07-18-2016), WetzMS3 (07-19-2016)
 Old 07-18-2016, 02:15 PM   #21
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
The sky is blue
 Old 07-18-2016, 06:15 PM   #22
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I would like to add something, albeit not spray bar related.
While waiting in the staging lanes with my 88 RX7 TII, I would ice the top mount and leave ice on it when going down the track. Times dropped from around 14s to 13.465 with no other changes. All I had was intake and exhaust...and wicked boost creep.
Funny story, the track official at the starting lights wasn't pleased when a few ice cubes slipped out of my hood scoop after warming up the tires.
Now I'm driving an '06 MS6 GT (w/o Nav). Currently stock with about 125k or so. Got it Dec 2015.
 Old 07-18-2016, 08:12 PM   #23
sheston's Avatar
Posts: 1,847   (View Stats)
I guess I need to go back and read the rules again, I'm sure they've changed in the more than 5 yrs I've been a member.
As far as this forum being unhelpful, it's the only one I use. After a while you will be able to see that it has the right info, best info, etc.
Group hug time :-)
 Old 07-18-2016, 08:27 PM   #24
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
stfu. you're just post whoring. this thread has been dead for a long time. I'd take you back down to 0 posts instead of banning you, and just when you're about to hit 100, do it again.
Mods: stock
The Following 4 Users Say Thank You to faeker For This Useful Post:
KiwiFlavor (07-19-2016), MS3Shadow (07-19-2016), sharksinspace (07-18-2016), Vansquish (07-19-2016)
 Old 07-18-2016, 08:47 PM   #25
I didn't threaten to ban you, i was merely informing you of the rules in case you forgotten,
You tried to sell something while under 100 posts earlier. I could've banned you then.
sent from my Nexus 6P
 Old 07-18-2016, 09:25 PM   #26
6onSpeed's Avatar
Posts: 75   (View Stats)
6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute6onSpeed has a reputation beyond repute
I put dis on my core..keeps it cold as...well...ice
Ok continue. My work is done here
::GTX2867r::Built motor with custom 3" full intake::custom fmic and all other supporting mods::Freaktune::
6onSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to 6onSpeed For This Useful Post:
KiwiFlavor (07-19-2016), sharksinspace (07-19-2016), Vansquish (07-19-2016)
 Old 07-19-2016, 09:04 AM   #27
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Fuck that guy, banninated.
KiwiFlavor (07-19-2016), MS3Shadow (07-19-2016), Vansquish (07-19-2016)
 Old 07-19-2016, 10:24 AM   #28
 Old 07-19-2016, 10:26 AM   #29
faeker's Avatar
Groans: 731
I told this clown to watch the line he was walking. Guess his ass didn't listen.
Mods: stock
 Old 07-19-2016, 12:11 PM   #30
PrematureApex's Avatar
Posts: 1   (View Stats)
PrematureApex can only hope to improve
Groaned at 4 Times in 1 Post
I can't see all of his posts, but he probably didn't think that heeding advice from the type of mouthbreather who calls people "faggot fucks" (which is apparently not against the rules?) was a good idea. Can't say I blame him.
RIP20boxer...
PrematureApex is offline   Reply With Quote
The Following 4 Users Say NO Thank You to PrematureApex For This Un-useful Post:
g00s3y (07-19-2016), sharksinspace (07-19-2016), Vansquish (07-19-2016), WetzMS3 (07-19-2016)
 Old 07-19-2016, 12:13 PM   #31
RIP20boxer...
Fuck you, you mouthbreathing premature ejaculating cum guzzler.
faeker likes this.
Code Monkey (07-19-2016), KiwiFlavor (07-19-2016)
 Old 07-19-2016, 12:15 PM   #32
"faggot fucks"
This has been used as a term of endearment many times on this forum.
faeker likes this.
KiwiFlavor (07-19-2016), WetzMS3 (07-19-2016)
 Old 07-19-2016, 01:38 PM   #33
COCKSTRONG
Groans: 890
RIP20boxer...
Peter, commenting in here pretending to be another account is about the oldest trick in the book. And now you get permabanned for creating a second account to circumvent your first ban.
faeker, WetzMS3 and MS3Shadow like this.
The Following 5 Users Say Thank You to SofaKingAwesome For This Useful Post:
g00s3y (07-19-2016), MS3Shadow (07-19-2016), sharksinspace (07-19-2016), Vansquish (07-19-2016), WetzMS3 (07-19-2016)
 Old 07-19-2016, 12:13 PM   #34
faeker's Avatar
Groans: 731
fuck off with your one post faggot. someone ban this dupe account.
Mods: stock
 Old 07-19-2016, 12:15 PM   #35
faeker's Avatar
Groans: 731
the only people who get offended are faggots themselves. suck a dick dupe.
Mods: stock
 Old 07-19-2016, 02:31 PM   #36
Police - Grammarhead
Vansquish's Avatar
Sounds like @PrematureApex; came too early.
The Following 5 Users Say Thank You to Vansquish For This Useful Post:
JSmith (07-19-2016), MS3Shadow (07-19-2016), sharksinspace (07-19-2016), SofaKingAwesome (07-19-2016), WetzMS3 (07-19-2016)
 Old 07-20-2016, 06:01 AM   #37
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Obligatory.
sharksinspace (07-20-2016), SofaKingAwesome (07-20-2016), Vansquish (07-20-2016), WetzMS3 (07-20-2016)
 Old 07-18-2016, 01:56 PM   #38
Originally Posted by 20boxer View Post
I wouldn't want my coils sitting under water tho......
bruh really, 5 year thread bump with nothing to add..
The Following 3 Users Say Thank You to MS3Shadow For This Useful Post:
 Old 07-18-2016, 06:40 PM   #39
Yeah it's an old one. This was more of a quantity post than a quality one. But look at the traction this thread has now! Don't call it a comeback
You can be banned for "Quantity" posts as it's stated in the rules.
Gerbilo (07-18-2016), Vansquish (07-18-2016)
 Old 07-18-2016, 07:41 PM   #40
Vansquish's Avatar
No i still stand by my statement of not wanting my coils sitting under water. Bro it seems like you really enjoy threatening to ban people. This is twice in two weeks you have threatened to ban me. And this time it's because you poked your face into a thread I commented on. Sorry this forum doesn't have any good content that's recent. You post asking a question, you get yelled at to search. You search and comment on a thread, you get a trigger happy mod picking a fight. You obviously have a TON of time on your hands. You obviously couldn't let my lighthearted comment about "quantity over quality" go without getting your panties in a bunch. I paid to be a member on this forum to gain access to a community of people who can help. You are the antithesis of that. Go a head and ban me. Worst $25 I have ever spent.
You read the rules, you knew the rules, you wilfully and intentionally breached the rules. Then you tried to rub it in our faces. This isn't going to end well for you.
DIY intercooler sprayer for gen 1? DubVms3 MazdaSpeed 3 - How-To's 8 06-11-2011 02:27 PM
Dei intercooler sprayer? Ms3speed MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 01-03-2011 03:45 PM
Nitrous fmic sprayer wakeboarddude MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 14 08-08-2009 03:45 PM
TMIC sprayer - Cry02 or similar kit SgtP MazdaSpeed 3/6 - Turbo Induction 10 07-29-2008 09:21 AM
Caddy Heating Problem, Bleeding Brakes on an Audi, Adjusting Toyota Tundra Sprayer Nozzle, AWD and Tire Rotation: Mike A Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.60095 seconds with 41 queries
