 Old 08-31-2015, 09:09 PM   #1
Just_Shep's Avatar
Posts: 8   (View Stats)
Just_Shep is on a distinguished road
Groaned at 4 Times in 1 Post
Default TIH tunning question
hey guys, I'm pretty weak in the tuning department and wanted to get a quick question answered. can I run the Cobb stage 1+ +IC map without having a TIP? From what I have read, the TIP seems like a waste of money and I don't want to spend it if i don't have to. Thanks a lot!!
Just_Shep is offline   Reply With Quote
The Following 4 Users Say NO Thank You to Just_Shep For This Un-useful Post:
Easter Bunny (09-01-2015), g00s3y (09-01-2015), MS3Shadow (09-01-2015), Vansquish (08-31-2015)
 Old 08-31-2015, 09:17 PM   #2
Police - Grammarhead
Vansquish's Avatar
It's not a waste of money, but you can probably run the map. You should, however, take logs on a regular basis to ensure that your AFRs, load and boost are within spec.
Just_Shep (08-31-2015)
 Old 08-31-2015, 09:24 PM   #3
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
Definitely not a waste of money. The stock TIP is puny and restrictive. Check out the tuning section for how-to's on logging and tuning.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 08-31-2015, 10:35 PM   #4
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
Nice intro bruh.
There is a thread here some where that discusses whether an after market TIH increases flow. With as common and reasonably priced as 3" intakes are now, I would suggest going that route instead. I was hesitant but finally grabbed my nuts and did it.
I like it, and mine in all black errrthang looks clean and simple under the hood.
As far as the map question, I agree try it out and log/monitor regularly as Vansquish suggested.
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
Thepedigree13 is offline   Reply With Quote
 Old 08-31-2015, 11:44 PM   #5
Just_Shep's Avatar
Thanks, just wanted to get things squared away before I order the IC and the auto techs. I'm very familiar with logging so I'll be sure to check up with those.
2008 ms3 20k miles MGM
Cobb RMM // Cobb SRI // Damond OCC // Cobb AP // Autotechs // Cobb TIP // CNT TBE... on back order // pilot super sport tires // CXRacing fmic // forge v2 //
 Old 09-01-2015, 06:48 AM   #6
You should just get a 3.5in intake and you'll be done even if you go BT.
volcomcinematic (09-01-2015)
Is tunning needed with big turbo. contreras MazdaSpeed 3/6 - ECU Computer Tuning 21 10-15-2012 12:27 AM
Tunning Noob question apena85 MazdaSpeed 3/6 - ECU Computer Tuning 2 09-18-2012 03:03 AM
Best tunning for the money?? $$$ mazdaspeed4life MazdaSpeed 3/6 - ECU Computer Tuning 5 03-12-2012 02:01 AM
Catless Downpipe Cobb AP tunning YokiMazoku MazdaSpeed 3/6 - ECU Computer Tuning 4 09-21-2009 12:20 PM
Page generated in 0.26331 seconds with 24 queries
