 Old 05-21-2017, 08:00 PM   #1
We Are Ninja's Avatar
Posts: 50   (View Stats)
We Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant futureWe Are Ninja has a brilliant future
Default Tired of Doing My Best Steam Train Impression...
...is what I've been doing for the last year or so. My k04 has been smoking for a while now. Only for four or five minutes after a cold start, and only during idle. It's not the end of the world, but it's annoying. I'm tired of trying to look casual while my car "idles" at 1500 RPMs (which is me sitting there with my foot just barely touching the gas), but I don't want to actually raise my idle either.
About the car... It's a 06 MS6 with just over 130K miles. Engine/power-wise, it's got HPFP internals, AP, SRI, TIP, upgraded TMIC, CS catless downpipe, CS catless, resonated race pipe, Forge BPV, and a Cobb dyno tune good for 277/337 AWHP on the stock, well-used k04. I've got a second, used k04 that I picked up that's supposedly not smoky. But I realize that it, too, will probably start to smoke eventually given my meager mods. After giving it some thought, I figure it'd make sense to upgrade.
Honestly, I'm happy with the car's power level now. It's fun. I'm not looking to be the king of Mexico, or a dyno god, or to wave my e-peen at people online. I really just wanna replace the k04 with something more reliable and less shitty than the k04. BNR seems to be pretty damned popular, and a S1 looks to be a direct drop-in. But everybody, and I mean EVERYBODY says that I might as well get an S3. Reliability is my first, second, and third priority. And I don't want to do any add'l supporting mods... At most, I'd like to drop in a turbo and get a get a tune.
If I splurge and get a BNR S3, can I drop it in with just a tune? If no, what about a [discontinued] S2? Stick with an S1? Corksport? Rebuild my k04?
I'm open to all advice and/or suggestions...
2006 Velocity Red Mica Mazdaspeed6
AWR / Cobb / Corksport / CP-E / Forge / H&R / JBR / KMD / Moog / NBK / Rota / Sparco / StopTech / Sumitomo / Turbine Tech / Wedge
We Are Ninja is offline   Reply With Quote
 Old 05-21-2017, 08:08 PM   #2
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Get an S3. No reason to get anything else.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
MD1032 (05-22-2017), We Are Ninja (05-22-2017)
 Old 05-21-2017, 09:02 PM   #3
SaveMelMac's Avatar
Posts: 485   (View Stats)
Hell go VIP and get a brand new S4 for the price of an S3. Hint hint I got one for sale
The Following User Says Thank You to SaveMelMac For This Useful Post:
 Old 05-22-2017, 03:38 AM   #4
Will an S3 require any other supporting mods?
 Old 05-22-2017, 06:01 AM   #5
Police - Grammarhead
Vansquish's Avatar
No. It's a drop-in turbo. The only thing you might find yourself needing is an extension for the hose that runs beneath the turbo inlet (though I didn't have this problem).
If you enjoy your insta-spool on the K04, then be warned: anything bigger than the K04 will cause a noticeable amount of lag.
 Old 05-22-2017, 09:33 AM   #6
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
The S3 is a sweet spot for these cars in general. Both the S3 and S4 will have noticeable lag compared to a K04 on a well flowing setup. The S3 is similar in size to a 2871 and spools around 32-3300. The S4 is like a baby 3076 and spools around 3600. Personally I prefer the response of the K04. You can buy rebuilt K04's from BNR for $400 I believe, with upgraded turbo seals. No core charge.
2007 Mazdaspeed3 GT
Vansquish (05-22-2017), We Are Ninja (05-22-2017)
 Old 05-23-2017, 10:05 PM   #7
Posts: 2,826   (View Stats)
I went BNR Stage 1 because I'm only interested in replicating the K04 flow with my modest mods while getting Garrett 28 series CHRA in the K04 housing. Its a good option with my mods. I like the fast spool in a daily driver and am satisfied with the power level and curing the smoking problem for good.
I'm in a minority on the issue, but 300/300 is good enough for me and uber reliable.
We Are Ninja (06-21-2017)
 Old 06-21-2017, 08:43 AM   #8
I've decided to go with the Corksport Turbo. It's super direct install looks to be super direct, and it comes with a 3.5 bar MAP for the super low price of free. Although I didn't want to do any add'l supporting mods, it looks like I'll be picking up an EBCS and a larger intake as well before getting a tune. I may as well take advantage of the turbo's extra oomph. EBCS' look pretty similar; I couldn't find any discernible difference between brands. I'll probably go with Corksport as well. Them intakes, tho'. I'll probably stick with JBR since the JBR stuff I currently have is quite nice and works well. But I don't know if I should go with 3 inch or 3.5 inch. From what I've read, the 3 inch should be sufficient (and it wouldn't involve a smaller battery, battery tray, and moving the ECU around). The 3.5 would be more in line with future-proofing down the road in case I ever decided to go legit big turbo (and/or providing a bit of downstairs compensation), as I couldn't find any real benefit over the 3-incher in this particular application.
To be clear though, would there be any noteworthy benefit in running a 3.5-inch intake with a BNRS3/Corkspot-sized turbo as opposed to a 3-inch?
 Old 07-21-2017, 05:39 PM   #9
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
How did the install go?Did you wait before getting a tune? I'm installing a cs turbo tommorrow and haven't heard anything back from pdtuning yet.
Sent from my XT1565 using Tapatalk
tom10122 is offline   Reply With Quote
ISC N1 Coilover Impression jrho MazdaSpeed 3/6 - Suspension & Brakes 8 05-03-2015 09:50 AM
So tired of looking for a lip... Spectrum24x MazdaSpeed 3/6 - Appearance 9 02-03-2012 08:08 PM
80 RMM Impression. breakfstincluded JAMES BARONE RACING 30 02-01-2012 05:34 PM
Page generated in 0.30887 seconds with 26 queries
