 Old 03-10-2008, 08:02 PM   #1
yup24z's Avatar
Posts: 56   (View Stats)
yup24z is a jewel in the roughyup24z is a jewel in the roughyup24z is a jewel in the roughyup24z is a jewel in the rough
Default Took of my Forge bpv...so much different!
Like the title says...took off my bpv today to sell it since I'm thinking of going FMIC with vta(at some point). Boost builds SOOOOOOOOOOOO much slower with the stock bpv. I had no idea what a difference that thing made. Could definitely see myself running leaner in the lower rpms with the forge, with spool so much quicker. Also...immediately had to turn the boost up to compensate. Stock bpv ftl!! Sorry for the pointless post...but trying to rack 'em up!
2008 Black Mica MS3--Corksport DP, Turbo XS Racepipe, Custom 3inch Catback, Cobb SRI, Turbosmart Mbc @ 18psi, ATP BCD, Prosport Boost Gauge, Dashhawk, 6000k HID's, 5% tint
Stock Dyno: 227hp/241tq
Dyno w/ Cobb SRI/Corksport DP/TXS RP/MBC @ 18psi- 279hp/315tq
yup24z is offline   Reply With Quote
 Old 03-10-2008, 08:02 PM   #2
post whore
 Old 03-10-2008, 08:10 PM   #3
yup24z's Avatar
post whore
sorry
 Old 03-11-2008, 12:01 PM   #4
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
OK, so finally FedEx delivered my SSQV this morning and I slapped it on before the FedEx guy drove away...
Engine performance is improved!!! I can't say its amazing, but definitely helps. With the stocker, I held at 15.6 PSI and spiked around 16-17 PSI at 50* degree weather, 30* degree weather occasionally spiked at 19, rarely 20 PSI. Todays temps were 79*-80* degrees. I was piking 20 consistently and held boost at 16.6; got an extra 1 PSI. Now, the biggest advantage I found was that the power between shifting!!! With the stocker, the shifts were smooth and progressive...it eased into boost. Now, as soon as you shift and let go of the clutch and floor it, it threw my head back!!!!
Seems like the engine is very responsive between shifts...I know it has something to do with boost... Maybe the valve closes a lot quicker thus recovering boost quicker...?
I like it and I'm happy with it. I wish we could run it VTA though...
2008 Stage 3 Roush Mustang
AutoXRacer is offline   Reply With Quote
The Following User Says Thank You to AutoXRacer For This Useful Post:
occschemguy (03-11-2008)
 Old 03-11-2008, 12:24 PM   #5
phailerider's Avatar
Posts: 4,639   (View Stats)
I notice the same thing about the shifting. Its kinda cool at first.... and when Im in enthusiast mode(which is most of the time). But sometimes it makes me have a headache just driving around. Im worried I may have had too stiff a spring setup in the Forge for the stocker....
 Old 03-11-2008, 05:20 PM   #6
occschemguy's Avatar
Posts: 1,149   (View Stats)
occschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the world
Thumbs up
I felt the same way and got the same results when i first wenk with the SSQV, i think u made a great choice
You can see more on mymyspace
occschemguy is offline   Reply With Quote
 Old 03-11-2008, 03:00 PM   #7
AutoXRacer's Avatar
Thats what I like about the HKS SSQV, no springs or adjustment to mess around with...
It is a little jerky sometimes though; when you are trying to be smooth and just cruise.
The Following 2 Users Say Thank You to AutoXRacer For This Useful Post:
MazdaMOFO84 (03-03-2012), occschemguy (03-11-2008)
 Old 03-12-2008, 01:12 PM   #8
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
i went back to stock at 1 point too. my car lost a full 2 psi !! stock is POS !!
TRU-BOOST is offline   Reply With Quote
The Following User Says Thank You to TRU-BOOST For This Useful Post:
occschemguy (03-12-2008)
 Old 03-12-2008, 11:57 PM   #9
thats for sure!
 Old 03-15-2008, 01:26 PM   #10
yup24z's Avatar
When I went from the forge back to stock, I lost almost 3psi. Had to turn up the boost to compensate.
 Old 03-15-2008, 12:25 PM   #11
trufanatic's Avatar
Posts: 172   (View Stats)
trufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud oftrufanatic has much to be proud of
i got rid of my SSQV simply because of that hesitation feeling / jerk between gears 1-3. i went back with the stocker, the hks going off constantly at part throttle boost got really annoying.
I did build boost quicker though but the change of "smooth" driving made me deal with the stocker.
trufanatic is offline   Reply With Quote
 Old 03-15-2008, 01:47 PM   #12
AutoXRacer's Avatar
Really? My SSQV barely goes off on light throttle lifts...
Are you sure your HKS wasn't defective in some way...
 Old 03-19-2008, 01:37 PM   #13
ikillforfunok's Avatar
Posts: 58   (View Stats)
ikillforfunok has a spectacular aura aboutikillforfunok has a spectacular aura about
So is the everyday driveability better with the Forge or the HKS? Anyone had both?
ikillforfunok is offline   Reply With Quote
 Old 03-19-2008, 03:35 PM   #14
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
yeah i'm running turboxs vta it definatly holds boots better than stock.. but i heard forge holds the best..
 Old 03-19-2008, 04:06 PM   #15
AutoXRacer's Avatar
I doubt Forge holds the best...wouldn't HKS SSQV hold better due to design?
Not saying that because I have it...
Regarding drivability, I've had no issues... I think the upgraded BPV is better overall for all out performance and everyday use. It prevents the turbo from spooling needlessly just to provide XX amount of pressure. What I mean is, if your BPV is leaking, the turbo is spooling much faster just to compensate for the lost boost.
 Old 03-19-2008, 04:08 PM   #16
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
I was starting to lead towards getting the HKS...but I guess the recirc line and the Cobb SRI get in the way
 Old 03-19-2008, 04:09 PM   #17
gsrtype1's Avatar
Groans: 102
driver311 said the forge almost holds to much boost
 Old 03-19-2008, 04:13 PM   #18
aaronc7's Avatar
Groans: 370
Holds too much boost? What is that supposed to mean, lol
 Old 03-19-2008, 04:14 PM   #19
gsrtype1's Avatar
Groans: 102
if i recall he said he was going to 26psi with the forge...
 Old 03-19-2008, 07:56 PM   #20
 Old 03-20-2008, 10:38 AM   #21
gsrtype1's Avatar
Groans: 102
Originally Posted by occschemguy View Post
??? ask driver...
 Old 03-19-2008, 04:13 PM   #22
gsrtype1's Avatar
Groans: 102
after vta i'm not turning back its sweeet!!
 Old 03-19-2008, 07:58 PM   #23
aaronc7's Avatar
Groans: 370
sounds like he had major boost spike problems? lol
 Old 03-19-2008, 08:06 PM   #24
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
Groans: 70
i noticed a definite increase in boost when i put my ssqv on
Grim is offline   Reply With Quote
 Old 03-22-2008, 12:17 AM   #25
mk_slayr's Avatar
Posts: 182   (View Stats)
mk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond reputemk_slayr has a reputation beyond repute
I've seen about a 1 psi increase with my forge. Boost comes on faster and the car definitely spools harder. I've eased it into first then went wot at about 10mph and spun the tires through first and second into third. Daily drive-ability hasn't really been affected. After I got my DH I noticed that I rarely got into the boost during my daily drive. I usually stay at a 7 vacuum when cruising. The car does nose a bit more when I let off throttle under wot then I get kicked back farther when the boost hits.
I love it though, even the girly "pink". Faster Spool + 1Psi + Uncontrollable laughter of friends when vents = Epic success.
I've noticed about a 1 mpg increase too. I'm up to 22 mpg
mk_slayr is offline   Reply With Quote
 Old 03-22-2008, 05:48 AM   #26
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
I’m not sure the Forge actually "increases" boost rather then lets you keep your hard earned boost, something the stocker seems to have a problem with. But I could see how you would feel like you are picking up a PSI Enjoy it !
NYpest is offline   Reply With Quote
 Old 03-22-2008, 05:50 AM   #27
The stocker can leak an avg of 1-3 psi, depending on which Japanese dude sat on your valve prior to install.
I didnt notice any increae in boost with my car, from the stock valve to the forge, HOWEVER, i had my valve 2 days after i got the car. So, there realy is no real data. To be honest with you, i have no fuckin clue where my stock valve is even at. lol
 Old 03-24-2008, 10:25 PM   #28
surfwagon's Avatar
Posts: 456   (View Stats)
surfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the world
...about the OEM BPV, could this be one reason for all the boost spike seen is the MS3? I'm spiking to around 20 psi and settling dow to 15.6.
surfwagon is offline   Reply With Quote
 Old 03-24-2008, 10:31 PM   #29
Spike isnt uncommon in these cars, but the erratic boost has been pinpointed from the stock valve. If you can pony up the $$, get something like a forge on the low end or a turbosmart if you have $250.
 Old 03-24-2008, 10:43 PM   #30
ZooZoom's Avatar
Posts: 178   (View Stats)
ZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to allZooZoom is a name known to all
Forge BPV FTW!
ZooZoom is offline   Reply With Quote
 Old 03-24-2008, 11:16 PM   #31
NYpest's Avatar
Originally Posted by ZooZoom View Post
Forge BPV FTW!
+1
Page generated in 0.49879 seconds with 34 queries
