  • 1 Post By sheston
 Old 12-05-2016, 08:43 AM   #1
GroceryGtr's Avatar
Posts: 472   (View Stats)
Default TMIC Temp Check
Just curious what you upgraded TMIC people are seeing today for BATs. Was 33 this morning and I was seeing 80-90 in stop and go traffic and red lights. cruising at 45 was seeing solid 80.
 Old 12-05-2016, 10:46 AM   #2
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Ive been seeing 20-60 over ambient with colder temps on my tmic. I have heat shielding and in warmer temperatures I see 6-60 above ambient depending on driving.
 Old 12-05-2016, 11:12 AM   #3
Voltwings's Avatar
Posts: 3,713   (View Stats)
The boost air temps are read in the intake manifold, which will heatsoak no matter what and skew your BAT data. Do a quick hit to get a lot of fresh air moving through the core and over the sensor and you'll see your BATs tank.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Gerbilo (12-06-2016), WetzMS3 (12-06-2016)
 Old 12-05-2016, 11:14 AM   #4
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
While cruising I usually saw 20-30 degrees above ambient in the heat. I havnt checked now that its getting cooler.
This is with an ETS TMIC. Which intercoolers are you running?
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 12-05-2016, 03:10 PM   #5
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
CS TMIC here, my BATs tend to hover about 20ish above IAT unless I'm in especially heavy stop/go traffic. Also have JBR TIG on the throttle body and unplugged EGR, for whatever additional minor difference those may make.
Genpoo stuff
 Old 12-05-2016, 06:02 PM   #6
sheston's Avatar
Posts: 1,847   (View Stats)
Like @Voltwings; said, you have to give it some throttle for it to make any sense. If you look at WOT logs, they generally start high, and fall off fairly rapidly until they may start to creep back up by the end. As long as the TMIC itself isn't heat soaked, they work great.
My BATs are usually 10 - 20°F below ambient, because Meth :-)
The Following 2 Users Say Thank You to sheston For This Useful Post:
monkey.bones.007 (12-05-2016), Voltwings (12-05-2016)
 Old 12-05-2016, 09:59 PM   #7
Groans: 126
No log of the run because spur of the moment, but this shows peak BAT/IAT after putting a ricer in his place on my way to pick up the wife; grabbed the photo a few minutes afterward when I thought of this thread. 30* ambient temp.
Genpoo stuff
 Old 12-06-2016, 05:59 AM   #8
With my cpe tmic, thermal gasket between the throttle body and the intake manifold and a thermal gasket between the intake manifold and the block, egr delete, coolant reroute I am seeing the same temps you are. Except mine was 111. Time for meth to cool that intake charge. That's my plan.
 Old 12-06-2016, 06:24 PM   #9
sheston's Avatar
Meth = win! Not really the time of year to notice it much though
MS3Shadow likes this.
MS3Shadow (12-06-2016)
 Old 12-25-2016, 08:00 PM   #10
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Yeah, me to
I have a shrouding project going on. It has so far ^ recovery times
decreased soak amounts
NOT reduced the inevitable crawl upwwards during WOT logs
ore to come
The Following User Says Thank You to meicalnissyen For This Useful Post:
monkey.bones.007 (12-25-2016)
 Old 12-26-2016, 12:15 AM   #11
RazoE's Avatar
Posts: 181   (View Stats)
RazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond repute
My BATs are usually around 30 degrees higher than my air intake temp if I'm steadily cruising and not sitting for long periods of time.
You can see here I did an 18 psi pull and it barely even rose.
only mods are CP-E TMIC, CS intake and cold air intake box.
-2008 Mazdaspeed3
Corksport Stage II SRI - boost tubes - Dual VTA BPV / CP-E TMIC / HKS 3" CBE / JBR shifter bushings - Reverse gate - Modified Raider air dam for TMIC / COBB cold air box - AP V3 / Autotech HPFP / Damond short shift plate / Optima yellow top / Mazdaspeed lowering springs and camber arms / Black Gen Pu wheels
RazoE is offline   Reply With Quote
HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC Chimmike MazdaSpeed 3/6 - Turbo Induction 6 07-04-2011 03:18 PM
Page generated in 0.31647 seconds with 28 queries
