Groans: 433
(Thread Starter) | Not Ranked : 0 score I'm leaning towards the TR8L, more flow capacity should make this good eh?
| The Following User Says Thank You to Chimmike For This Useful Post: | jorylee89 (08-19-2013) |
![]() Join Date: Dec 2009 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
| Not Ranked : 0 score I used Cobbs piping kit with the TR8L and it was pretty much an exact copy minus the end tank mounting points. The TR8L has a larger single tapped hole vs. cobb's double tapped holes on each tank. So yeah go with the TR8L, works great on mine. |
| The Following 2 Users Say Thank You to NoLeftTurn For This Useful Post: | Chimmike (02-05-2012), mazdamx3freak (02-05-2012) |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Might as well get the better one especially since there the same price.
__________________ 417whp 428tq 12.037@117.2mph |
![]() Join Date: Mar 2010 Location: Tampa/Zephyrhills, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score Tr8l ftmfw!!!
__________________ 2008.5 CPW JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate. Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score If I'm understanding things correctly, the TR8L flows more efficiently but at the expense of cooling capacity, no? They say it exhibits less pressure drop from a less dense internal fin structure, which I can only surmise will cause it to suffer at least slightly in its ability to exchange heat... It seems like if you're on the K04 (and have no plans to go BT), it might be smarter to use the TR8 (depending on your overall setup). Am I full of shit here??
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following 9 Users Say Thank You to Nliiitend1 For This Useful Post: | ak_spray (02-18-2012), breakfstincluded (10-22-2013), Bucker (03-04-2012), J'sSpeed3 (10-23-2013), jmhinkle (03-25-2012), rfinkle2 (05-04-2012), SLOWHATCH (07-24-2013), TexasSpeed3 (03-25-2012), volcomcinematic (06-11-2015) |
Groans: 433
(Thread Starter) | Not Ranked : 0 score What that told me was it was less resistant to flow, so for motors flowing more air, pressure drop is less and it's probably just as efficient. I'm not on k04 so I'm looking for something with flow. TR8L fills the ticket.
| The Following User Says Thank You to Chimmike For This Useful Post: | Nliiitend1 (02-05-2012) |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score tr 10 ftw with diverter louvers
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following 9 Users Say Thank You to rigor For This Useful Post: | ak_spray (06-12-2012), AZSPEED3 (03-10-2012), EdgeAutosport.com (03-09-2012), helmetface (05-04-2012), J'sSpeed3 (10-23-2013), johnbarr00 (07-03-2013), Koke382 (10-24-2013), mazdafreak (02-08-2012), rfinkle2 (05-04-2012) |
![]() Join Date: Apr 2011 Location: Warsaw, PL
Rep Power: 0 ![]() ![]() Thanks: 6
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Any problems in fitting everything ?? |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score Read brownie.. http://www.mazdaspeedforum.org/forum/foru...rcooler-72644/ |
| The Following User Says Thank You to speed_freak91 For This Useful Post: | emilioestewez (03-09-2012) |
![]() Join Date: Feb 2012 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() Thanks: 5
Groaned at 108 Times in 27 Posts
Explain this a little better? Lol the tank mounting stuff? And prices you paid Fpr it all ((SLIK-6)) | |
Groans: 433
(Thread Starter) | Not Ranked : 0 score TR8L fit fantastic.
| The Following User Says Thank You to Chimmike For This Useful Post: | emilioestewez (03-11-2012) |
| Not Ranked : 0 score Cobb piping kit? I have a ms6 no piping kit for me from Cobb. Does Corksport sell just a piping kit ((SLIK-6)) |
| Not Ranked : 0 score |
Groans: 433
(Thread Starter) | Not Ranked : 0 score the specific reason I bought the TR8L is it fits without sticking below in any way. Low car+low hanging fmic=trouble and ghetto fitment.
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score have you installed it yet, Mike? Pics if so.
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
| The Following User Says Thank You to emilioestewez For This Useful Post: | Chimmike (03-11-2012) |
Groans: 433
| Not Ranked : 0 score How/what did u use to mount it ((SLIK-6)) |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Would the Protege Garage kit work with this core?
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
| Not Ranked : 0 score Not so much, it is pushing my bumper tabs out because it's hitting the pipes around the fog lights area. I trimmed the bumper a lot but still no luck.
| The Following User Says Thank You to Snyeed For This Useful Post: | Tabasco69 (01-22-2014) |
| Not Ranked : 0 score I guess I'm going to wind up getting the Cobb retro-fit kit.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| Not Ranked : 0 score Exactly what I am thinking. maybe... I think the biggest problem is the thickness. I have it mounted exactly where the pg core went using the bracket modifyed. If I mounted the core back a little bit and cut the piping it should fit. It might work if I cut the pipe on the driverside so it's not such a long C bend, start bending up right after the core getting out of the way of the fog light. all I need is an inch or two.
![]() | | #24 | ![]() |
Groans: 433
(Thread Starter) | Not Ranked : 0 score Mounting the TR8L on the genjuan was super easy. There are open bolt holes where the PS cooler used to be mounted to, I made a couple L brackets and mounted accordingly.
| The Following User Says Thank You to Chimmike For This Useful Post: | Atticaz (03-20-2016) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Kind of like how cobb mounts there core?
![]() | | #26 | ![]() |
![]() Join Date: May 2008 Location: New orleans, la
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
| Not Ranked : 0 score Would the tr8l be the choice for a k04 car? It seems to me the tr8 claims to cool better due to the denser fins or whatever |
| The Following User Says Thank You to Meder For This Useful Post: | Nliiitend1 (04-17-2012) |
![]() | | #27 | ![]() |
![]() Join Date: Jul 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score So i went ahead and picked up the TR8 + COBB retrofit kit from Eric. What all exactly am I going to need to mount the core correctly? Will I be able to use the supplied brackets that come with the COBB kit? Also, will I need to pick up some bolts from the local hardware store?
__________________ ![]() 2008½ CWP Mazdaspeed 3 - COBB Stage 2+++ |
![]() | | #28 | ![]() |
I know, old thread, but just came across it and thought someone else might have this question eventually. | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | 86AmishMs3 (05-23-2012), SLOWHATCH (07-24-2013) |
![]() | | #29 | ![]() |
Groans: 34
![]() | | #30 | ![]() |
| Not Ranked : 0 score Exactly the info I needed. Thank you.
![]() | | #31 | ![]() |
![]() Join Date: Jul 2009 Location: Toronto
| Not Ranked : 0 score My apologies for bringing this thread back up, but I am also doing my own FMIC setup and like others have asked, would the TR8 be the better option for someone who's staying with the stock K04? I know with the k04 a huge core isn't necessary. On the other hand, I felt that the Godspeed Type C may better suit my needs, but based on everyone's input it seems as though the treadstone is the better core afterall |
![]() | | #32 | ![]() |
![]() Join Date: Jul 2010 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,444
| Not Ranked : 0 score Just go with the treadstone it's a more efficient core for sure. Plus if you continue to add mod's you'll be happy you went with the better core.
__________________ BNR S3 // E85 Mix // Freektune 348tq/367whp -21.5 psi Now - 25-26 psi + JBR 3.5 Intake |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score My thoughts are to stick with a TR8 especially on BT like finkle stated. Straight fins do not give as much surface area for radiating away heat. Might as well just go all the way and go tube and fin.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | rfinkle2 (07-28-2012) |
![]() | | #35 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score Well my TMIC tabs keep snapping so im going the fmic route and am going to be building my own. I have a guy who does fab for a living not too far from me, so I should be good to go if he can help me. Ive decided on the tr8l as my core and probably the cs racing universal piping kit. Anything else I should look at picking up? Am i going to have to cut the crash bar? and my occ is on the drivers side.... is that going to need to get moved? Having a couple sets of hands on this project will make it easy to put together a solid how to for this combo.
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() | | #36 | ![]() |
| Not Ranked : 0 score FYI, The TR8L is essentially on an indefinite backorder currently. They are in limited supply and Treadstone is utilizing all of them in their G35 turbo kits. I was jerked around for 2 months before I gave up waiting and got the TR11 instead which was in stock.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | rfinkle2 (07-28-2012) |
![]() | | #37 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score Does anyone make something comparable to the TR8L, do you have to cut the crash bar with a TR8L?
__________________ Damond Built Speed 6 |
![]() | | #38 | ![]() |
The TR11 requires a Sawzall...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #39 | ![]() |
![]() Join Date: Nov 2010 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 164
| Not Ranked : 0 score I ordered a TR8L from Treadstone and they shipped me a TR8 instead. I called them up to see what was up with that, and they told me TR8L was designed for low boost applications ~10 psi or so. O... k... Can anyone confirm this? Anyway, I have the TR8 mounted on the car with no crash bar modification.
__________________ 08 MS3 CWP, AP Stg 2, CP-E SRI/TIP/RMM, AT Internals, CNT Catted DP, TR8 FMIC, JBR SSP/Knob/EGR Delete, Koni Yellows, DH, RX8's 225/40/18 Conti DW Needs: Plugs, GS EBCS, E85 tune, gauges |
| The Following User Says Thank You to stp For This Useful Post: | SLOWHATCH (07-24-2013) |
![]() | | #40 | ![]() |
Groans: 118
| Not Ranked : 0 score What about the TR8? isnt it taller than the TR8L
| The Following User Says Thank You to Deldran For This Useful Post: | knghong (05-19-2014) |
| Do Yourself FMIC w/treadstone fmic | I Love Brownies | MazdaSpeed 3 - How-To's | 140 | 02-13-2013 09:18 AM |
| my treadstone ic /w cobb piping | mazdamx3freak | MazdaSpeed 3/6 - Turbo Induction | 40 | 07-31-2012 11:16 PM |
| Treadstone tr6 | NinjaT1985 | 2010 MS3 - Turbo Induction | 4 | 11-25-2011 07:10 PM |
| Godspeed Type C vs. Treadstone TR6 | mrmonk7663 | 2010 MS3 - Turbo Induction | 27 | 10-30-2011 10:48 PM |
