  • 2 Post By Tokay444
 Old 09-12-2015, 04:48 PM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Default Turbine Inlet Copper gaskets
So this is the 2nd time I've had some fail with the SS gaskets on the turbine inlet.
Anyone ever try copper gaskets? I know for the DP they work OK. Just wondering if copper is heat resistant enough for the turbine inlet.
There are a few vendors that sell them
T25/T28 Turbo Inlet Gasket, Heavy Duty, 0.043" Copper Columbia River Mandrel Bending
breakfstincluded (09-15-2015)
 Old 09-12-2015, 04:54 PM   #2
btstarcher's Avatar
Posts: 4,852   (View Stats)
@PHAUZZY; had/has gasket issues. Maybe y'all can collaborate? Don't recall the specifics but I think that's the same one.
SnailTune in progress
 Old 09-14-2015, 08:58 AM   #3
nekret's Avatar
Posts: 421   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
I know this kind of sucks, but if you can you might want to check the mating surfaces to see if they're flat using a straight edge and feeler gauges. If the flanges are warped/uneven, gaskets won't last long if at all.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 09-14-2015, 09:10 AM   #4
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Yeah, that was going to be my suggestion. If you're blowing gaskets perhaps the surfaces are not true.
 Old 09-14-2015, 01:30 PM   #5
Bob Ross Fanclub
Tomas's Avatar
I will check when I change the gasket.
But the surfaces were true when first installed. It's a full race manifold mated to an EFR7163 terboh so pretty good quality shit.
Last edited by Tomas; 09-14-2015 at 01:31 PM. Reason: MSF Database - Automerged Doublepost
btstarcher (09-14-2015), Mauro_Penguin (09-16-2015), Micha (09-15-2015)
 Old 09-15-2015, 09:30 PM   #6
PHAUZZY's Avatar
Posts: 215   (View Stats)
PHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the worldPHAUZZY is the leader of the world
Well, l I'm using a different manifold and turbo but yes I was having gasket issues. My solution? I don't run a gasket at all, copper should be plenty good and we actually used copper spray on the turbo and mani then bolted everything down no issues since
Top Mount pte 6262 on eBay exhaust mani, custom 3 in vband dp, tial 38mm ewg, blow thru 3.5in maf, synapse bov, jsport 3 port ebcs, custom water to air ic, vcts delete, EGR delete, mild intake mani port, Tig, tb meth spacer, devils own meth, htp battery relocate, unknown front tower brace, 3.5map, kozmic vta occ, Corksport sealed cc, dss axles, Corksport rear diff mount, turbine tech front diff mount, whiteline rsb, twm full replacement short shifter, wire tuck, JBR rmm, JBR pmm, freektune meth+e85
Yeah stock block
"intake? What do I need that for"
PHAUZZY is offline   Reply With Quote
The Following 2 Users Say Thank You to PHAUZZY For This Useful Post:
btstarcher (09-15-2015), Tomas (09-17-2015)
 Old 09-15-2015, 09:45 PM   #7
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I thought the same about TiAL being quality shit, but I had to hand lap every mating surface flat, and it's clear to see by the tri-oval distortion pattern on all their V-band flanges that they just grab each one in a three jaw chuck and face them. Fuckin' sloppy if you ask me.
I'm talking flanges that hadn't even been welded on to anything yet as well.
"Exclusivity" - CP-enis
Demodded.
The Seals
breakfstincluded (09-15-2015), Mauro_Penguin (09-16-2015), Tomas (09-17-2015)
 Old 09-15-2015, 10:00 PM   #8
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Noob question Tokay but how would one go about lapping the mating surface? I'm talking decent set of tools but definitely no machinist equipment.
 Old 09-15-2015, 10:21 PM   #9
nekret's Avatar
Disclaimer: never done this myself!
I've heard you can use a decently flat surface (thick piece of glass or granite is ideal) tape sand paper to it and slide the surface in question across the sand paper using even pressure and circular motion. If a really smooth surface is desired, repeat with a finer grit until you get to a surface you like.
Drivetrain
Chassis
Rice
The Following 3 Users Say Thank You to nekret For This Useful Post:
Mauro_Penguin (09-16-2015), Tokay444 (09-16-2015), Tomas (09-17-2015)
 Old 09-16-2015, 09:56 AM   #10
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Lots of folks swear by using remflex gaskets.
They offer a t25 inlet
Turbo Gaskets/Garrett, Greddy T25
These will take a ton of abuse and will squish to allow sealing of imperfect flanges.
A little info
Exclusive features
Soon to come.
WHO KNOWS? A.D.D. FTW!
Last edited by Turbo_Steve; 09-16-2015 at 09:56 AM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to Turbo_Steve For This Useful Post:
Hargarbl (09-16-2015), Mauro_Penguin (09-16-2015), Tokay444 (09-16-2015), Tomas (09-17-2015)
 Old 09-16-2015, 10:03 AM   #11
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
Remflex are fantastic, me and my pops were fighting a header gasket leak forever on the old project car, new gaskets would only last a week or so before they blew out. Snagged a set of Remflex and havent had a problem since.
Just something to keep in mind, remflex are quite a bit thicker than standard gaskets because they are made to crush down to fill in the imperfections. Keep this in mind if you have very tight tolerances.
The Following User Says Thank You to Hargarbl For This Useful Post:
Tomas (09-17-2015)
 Old 09-16-2015, 05:07 PM   #12
Tokay444's Avatar
Groans: 793
For the smaller wastegate flanges I used a large, machinist's honing stone.
For the larger ones, like the turbine outlet, I did as mentioned above. Taped some 400 grit wet/dry to my granite surface plate.
Always move in a figure 8 pattern and try to maintain full contact whenever possible.
As an aside to the last post, tight tolerances don't meant tight fits. Tolerances and allowances are two different aspects of manfacturing that are often misused interchangeably.
Mauro_Penguin and zenit like this.
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
btstarcher (09-16-2015), jdmage_mx5 (09-16-2015), Mattyhawk1 (09-17-2015), Mauro_Penguin (09-16-2015), Tomas (09-17-2015), WetzMS3 (09-17-2015), zenit (09-16-2015)
 Old 09-17-2015, 02:51 PM   #13
Bob Ross Fanclub
Tomas's Avatar
The remflex gaskets look interesting. The picture shows a SS gasket but the description says they are composed of graphite.
Just ordered one. I will post pics when received.
The reviews on longevity are mixed however. At least one of them. Seems they are pretty good at sealing but longevity could be an issue.
Avoid REMFLEX gaskets - NASIOC
Copper melting point is about 1900 degs F. That might be ok but since I don't know of any racing applications using it on the turbine inlet I am not sure if it will hold. The one interwebz reference I found is also mixed.
Anyone using COPPER turbo inlet gasket? | DSMtuners
Spy Shots: Mercedes SL prototype says you'll never catch me, copper Haltech Automotive News 0 10-31-2011 05:30 PM
copper lip rims.. SpeedSixxx MazdaSpeed 3/6 - Appearance 87 04-06-2010 10:51 PM
SEMA 2008: Factory Five GTM looks slick in copper Haltech Automotive News 0 11-09-2008 08:50 AM
Page generated in 0.34964 seconds with 28 queries
