(Thread Starter) | Not Ranked : 0 score Anyone ever try copper gaskets? I know for the DP they work OK. Just wondering if copper is heat resistant enough for the turbine inlet. There are a few vendors that sell them T25/T28 Turbo Inlet Gasket, Heavy Duty, 0.043" Copper Columbia River Mandrel Bending
__________________ |
| The Following User Says Thank You to Tomas For This Useful Post: | breakfstincluded (09-15-2015) |
| Not Ranked : 0 score @PHAUZZY; had/has gasket issues. Maybe y'all can collaborate? Don't recall the specifics but I think that's the same one. Sent from my SM-N900V using Tapatalk
![]() Join Date: Jan 2013 Location: Vancouver, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score I know this kind of sucks, but if you can you might want to check the mating surfaces to see if they're flat using a straight edge and feeler gauges. If the flanges are warped/uneven, gaskets won't last long if at all.
__________________ 2011 Mazdaspeed3 non-tech package Drivetrain CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune Chassis JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace Rice LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Yeah, that was going to be my suggestion. If you're blowing gaskets perhaps the surfaces are not true.
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
(Thread Starter) | Not Ranked : 0 score I will check when I change the gasket. But the surfaces were true when first installed. It's a full race manifold mated to an EFR7163 terboh so pretty good quality shit.
__________________ Last edited by Tomas; 09-14-2015 at 01:31 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
![]() Join Date: Apr 2013 Location: Little Rock, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Well, l I'm using a different manifold and turbo but yes I was having gasket issues. My solution? I don't run a gasket at all, copper should be plenty good and we actually used copper spray on the turbo and mani then bolted everything down no issues since
__________________ Top Mount pte 6262 on eBay exhaust mani, custom 3 in vband dp, tial 38mm ewg, blow thru 3.5in maf, synapse bov, jsport 3 port ebcs, custom water to air ic, vcts delete, EGR delete, mild intake mani port, Tig, tb meth spacer, devils own meth, htp battery relocate, unknown front tower brace, 3.5map, kozmic vta occ, Corksport sealed cc, dss axles, Corksport rear diff mount, turbine tech front diff mount, whiteline rsb, twm full replacement short shifter, wire tuck, JBR rmm, JBR pmm, freektune meth+e85 Yeah stock block "intake? What do I need that for" |
| The Following 2 Users Say Thank You to PHAUZZY For This Useful Post: | btstarcher (09-15-2015), Tomas (09-17-2015) |
Groans: 793
| Not Ranked : 0 score I thought the same about TiAL being quality shit, but I had to hand lap every mating surface flat, and it's clear to see by the tri-oval distortion pattern on all their V-band flanges that they just grab each one in a three jaw chuck and face them. Fuckin' sloppy if you ask me. I'm talking flanges that hadn't even been welded on to anything yet as well.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,028
| Not Ranked : 0 score Noob question Tokay but how would one go about lapping the mating surface? I'm talking decent set of tools but definitely no machinist equipment.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTA 3076 | HTP 4" Intake, battery tray, under mount piping | CPE Exhaust Manifold, downpipe, FMIC & Stage 2 RMM | MD TMM and PMM | Tial MV-R ewg w/ Kozmic dump tube | VCTS delete/Ported IM | JBR OCC, EGR delete, BSD w/ oil pan baffle & RSB | SP63 Oil Cap Breather | Synapse SB BPV | UR CBE | Autotech HPFP | H & R Coilovers | Whiteline Endlinks | Manley Pistons & Rods | L19 Head Studs | Kozmic 6th Port w/ DW65c ITFP | Snow Performance Stg 2 Meth | JMF Manifold | SouthBend Stg 3 Endurance Clutch | Tuned with |
| Not Ranked : 0 score Disclaimer: never done this myself! I've heard you can use a decently flat surface (thick piece of glass or granite is ideal) tape sand paper to it and slide the surface in question across the sand paper using even pressure and circular motion. If a really smooth surface is desired, repeat with a finer grit until you get to a surface you like. Sent from my SM-G900V using Tapatalk
| The Following 3 Users Say Thank You to nekret For This Useful Post: |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score Lots of folks swear by using remflex gaskets. They offer a t25 inlet Turbo Gaskets/Garrett, Greddy T25 These will take a ton of abuse and will squish to allow sealing of imperfect flanges. A little info Exclusive features
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! Last edited by Turbo_Steve; 09-16-2015 at 09:56 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 4 Users Say Thank You to Turbo_Steve For This Useful Post: |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
| Not Ranked : 0 score Remflex are fantastic, me and my pops were fighting a header gasket leak forever on the old project car, new gaskets would only last a week or so before they blew out. Snagged a set of Remflex and havent had a problem since. Just something to keep in mind, remflex are quite a bit thicker than standard gaskets because they are made to crush down to fill in the imperfections. Keep this in mind if you have very tight tolerances.
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs |
| The Following User Says Thank You to Hargarbl For This Useful Post: | Tomas (09-17-2015) |
Groans: 793
For the larger ones, like the turbine outlet, I did as mentioned above. Taped some 400 grit wet/dry to my granite surface plate. Always move in a figure 8 pattern and try to maintain full contact whenever possible. As an aside to the last post, tight tolerances don't meant tight fits. Tolerances and allowances are two different aspects of manfacturing that are often misused interchangeably.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 09-16-2015 at 05:38 PM. | |
| The Following 7 Users Say Thank You to Tokay444 For This Useful Post: | btstarcher (09-16-2015), jdmage_mx5 (09-16-2015), Mattyhawk1 (09-17-2015), Mauro_Penguin (09-16-2015), Tomas (09-17-2015), WetzMS3 (09-17-2015), zenit (09-16-2015) |
(Thread Starter) | Not Ranked : 0 score The remflex gaskets look interesting. The picture shows a SS gasket but the description says they are composed of graphite. Just ordered one. I will post pics when received. The reviews on longevity are mixed however. At least one of them. Seems they are pretty good at sealing but longevity could be an issue. Avoid REMFLEX gaskets - NASIOC Copper melting point is about 1900 degs F. That might be ok but since I don't know of any racing applications using it on the turbine inlet I am not sure if it will hold. The one interwebz reference I found is also mixed. Anyone using COPPER turbo inlet gasket? | DSMtuners
| The Following User Says Thank You to Tomas For This Useful Post: | WetzMS3 (09-17-2015) |
| Spy Shots: Mercedes SL prototype says you'll never catch me, copper | Haltech | Automotive News | 0 | 10-31-2011 05:30 PM |
| copper lip rims.. | SpeedSixxx | MazdaSpeed 3/6 - Appearance | 87 | 04-06-2010 10:51 PM |
| SEMA 2008: Factory Five GTM looks slick in copper | Haltech | Automotive News | 0 | 11-09-2008 08:50 AM |
