![]() | | #81 | ![]() |
![]() Join Date: May 2009 Location: Space Coast, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score the IAT's much? I had someone suggest a heavy duty Bilge blower (for I/O boats) and a cowl to evacuate the heat. Sounds a little elaborate to me, BUT it would probably work. Those blowers use a 3 or 4 inch diameter hose, so they must pull a fair amount of air. Question is...where do you blow the hot air TO!?
__________________ 2007 Mazdaspeed 6 Sport - Titanium Gray Modifications: Yes Do I want to list them here: No |
![]() | | #82 | ![]() |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
I've never even been logging my BAT's, so, I haven't the slightest idea how it is working. (I've got an ETS TMIC) But I did pull off the gasket. My hood now vibrates some. Its just a little annoying seeing your hood vibrate. So I was thinking of putting some small amount of gasket in the middle just to steady the hood some. | |
![]() | | #83 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Yesterday it was 97* AMB and on the highway going 80mph the IAT was 97* lol. IAT drops close to AMB or right at AMB when 40mph or faster. But standing still it's normal 110*-160* IAT in 97* weather.
![]() | | #84 | ![]() |
Results? Hoot doesn't vibrate anymore. And, I think, I've made it where the hood clearance is maybe 1/8" more than it was before, so, maybe even getting slightly more venting. Note that the sides where hood rests against the body of the car is still perfect. I didn't do anything to make it look like those crappy hood spacers. It looks totally stock, just no more hood vibration -- and perhaps/perhaps not slightly more venting. Of possible note, I was changing the battery in my Mercury Villager minivan. And I noticed it had essentially the exact same design. It had no gasket, and just two rubber stoppers near the windshield. So, I guess Mercury wasn't concerned about water coming into the engine compartment via that route. I wasn't to begin with, I'm just pointing this out to the person who was wondering if this was a possible issue. | |
| The Following User Says Thank You to Speedie6 For This Useful Post: | bioevolve (10-19-2009) |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score Update: After 6000+ miles everything is still working. Temps are consistent and stable. Only problem since the install was the rubber fill gasket leak. Other than that, it's all good. Currently generating funds for the Killer Chiller Prototype kit for the all MS3/MS6 with L/A setups. Might even have in my hands this month. |
| The Following User Says Thank You to bioevolve For This Useful Post: | xcoldricex (11-06-2009) |
![]() | | #86 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score killer chiller!!! should be pretty fucking awesome |
| The Following User Says Thank You to xcoldricex For This Useful Post: | bioevolve (11-18-2009) |
![]() | | #87 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, it's on the way to me. Look for a thread on that next week hopefully. |
| The Following User Says Thank You to bioevolve For This Useful Post: | xcoldricex (11-18-2009) |
![]() | | #88 | ![]() |
![]() Join Date: Mar 2008
Rep Power: 164 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 169
| The Following User Says Thank You to MS3 Ventura For This Useful Post: | bioevolve (11-27-2009) |
![]() | | #89 | ![]() |
FMIC with IC sprayer vs L/A with Icebox Reservoir, L/A would be cheaper in the long run. L/A with Killer Chiller is gonna be the best setup I think but the most maintenance beside N20 lol. Damn Turkey Day has delayed my Killer Chiller shipment Grrrrrrrrr. Should be in next week. | |
| The Following User Says Thank You to bioevolve For This Useful Post: | MS3 Ventura (11-28-2009) |
![]() | | #90 | ![]() |
![]() Join Date: Nov 2010 Location: Miami, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,290
Groans: 43
| Not Ranked : 0 score So whats the capacity of this system?
__________________ [SIGPIC][/SIGPIC] “From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley |
![]() | | #91 | ![]() |
| Not Ranked : 0 score I dont think it exists anymore, I believe that I actually have his L/A kit, but dont quote me on that lol.
![]() | | #92 | ![]() |
Groans: 43
| Not Ranked : 0 score I just picked one up and am gonna mix in half water wetter and half water. just wondering how much is "half" LOL. Also, perhaps you know. I can add a reserviour for ice??
![]() | | #93 | ![]() |
| Not Ranked : 0 score Yeah you can add a reservior, just make sure you add a bypass for the heat exchanger because it will warm the water back up.
![]() | | #94 | ![]() |
Groans: 43
| Not Ranked : 0 score How would i add a bypass? any Ice kits or something? DIYs? Thanks.
![]() | | #95 | ![]() |
Groans: 43
| Not Ranked : 0 score Ok kind of understand now. Seen some ice reserviors that mount in the trunk. Are drawings available on how this would work with the TT kit? (how to set it up)? Thanks
![]() | | #96 | ![]() |
| Not Ranked : 0 score Honestly home depot and lowes sell water manifolds or valves that can be adapted to 3/4" hose or whatever you are running. You just need two Y pipes and 4 valves or 2 Y manifolds with individual shutoffs.
![]() | | #97 | ![]() |
![]() Join Date: Jun 2011 Location: Clarksville
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Where can I but this L/A kit at, or one like it? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/turbinetech-liquid-air-intercooler-install-journey-33198/ | ||||
| Would you want a CF hood? | This thread | Refback | 06-26-2011 07:20 PM | |
| Would you want a CF hood? - Page 7 - Mazda CX-7 Forums | This thread | Refback | 01-24-2010 05:22 PM | |
| GB Turbine Tech Liquid to Air Intercooler - Mazda6 / Atenza | This thread | Refback | 07-21-2009 03:04 PM | |
| TURBINETECH LIQUID TO AIR INTERCOOLER | bioevolve | MazdaSpeed 3/6 - Turbo Induction | 21 | 07-21-2009 04:25 PM |
| TurbineTech's Liquid to Air Intercooler | aviator79 | MazdaSpeed 3 - Engine, Transmission & Driveline | 39 | 06-18-2009 09:50 AM |
| TurbineTech's Liquid to Air Intercooler | bioevolve | MazdaSpeed 3/6 - Turbo Induction | 23 | 04-01-2009 07:54 AM |
