 Old 07-24-2009, 01:33 PM   #1
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
Default Turbo Blanket
Before ANYBODY starts saying there is no need for one, a turbo blanket lowers engine bay temps as well as assists with turbo spool time. thank you....
Anyways, does anybody know where i can find a K04 turbo blanket? I searched for a bit and couldnt find anything on the web regarding the K04, plenty for the larger turbos but nothing for the K04 - i actually found 1 or 2 for the K03
KayWhy is offline   Reply With Quote
 Old 07-24-2009, 01:36 PM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
What about pillow and teady bear? hehe just kidding buddy lol
 Old 07-24-2009, 01:36 PM   #3
QuickSpool's Avatar
Posts: 235   (View Stats)
QuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to behold
There is a universal on one ebay. The guy makes S M and L I think. I emailed him once and asked if it would work and he said yes.
QuickSpool is offline   Reply With Quote
 Old 07-24-2009, 01:38 PM   #4
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
there's a guy on here that wrapped everything he could and he's got a turbo blanket along with other reflective wraps. try searching.
-- Mario Andretti --
 Old 07-24-2009, 02:10 PM   #5
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
Groaned at 56 Times in 41 Posts
Thermo-Tec: Turbo Insulating Kit
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 07-24-2009, 02:46 PM   #6
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Don't be a pussy... pull the turbo off, take off the hot side, and send it off to be thermal coated like a real man.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 07-24-2009, 05:53 PM   #7
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
ive got a heat blanket on my manifold shield using the shield bolts to anchor it down and a reflective sheet underneath the intercooler facing the valve cover, it helps fight heat for a little bit but its been so hot lately the intercooler will still soak pretty quickly.
SubPar is right a good ceramic coat would definitely be more effective and probably easier on our oil since it seemingly has a rough time in our car.
GoSpeed3Go is offline   Reply With Quote
 Old 07-24-2009, 07:09 PM   #8
sleeperstang1994's Avatar
Posts: 569   (View Stats)
Groaned at 7 Times in 5 Posts
+1 for ceramic coating. dont half ass it unless you want to do it again the right way.
 Old 07-24-2009, 07:59 PM   #9
hmmmmm lemmie get this straight. you want to increase spool on a turbo that spools before 3k? and keeping bay temps down? get an FMIC. your wasting your money on a turbo blanket unless your streetunitmark and your hotside DESERVES a turbo blanket.
 Old 07-25-2009, 02:18 PM   #10
mazdaspeed619sd's Avatar
Posts: 170   (View Stats)
mazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud of
DEI makes some. I think this mod, has full potential on keeping engine bay temps down. Who doesn't want a quicker spool? =D. Design Engineering, Inc. - DEI - CryO2 & Thermal Tuning Products They are the real innovators, not that thermo company. -_-
06 MS6 Black Mica
AWD BROTHERS SHALL UNITE!
Boys love straight lines.— Men love curves.— =)— Canyon/Circuit FTW!—
mazdaspeed619sd is offline   Reply With Quote
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold nobmood Mazdaspeed3/6 General Discussion 18 03-01-2009 08:14 PM
PTP Turbo fdkss03 MazdaSpeed 3/6 - Turbo Induction 10 07-22-2008 09:22 PM
Page generated in 0.29278 seconds with 29 queries
