 Old 10-25-2009, 03:39 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default turbo experts please chime in
i bought a used gt3076 and i know it had been sitting for 3 months. anyway when it was off the car i plugged the oil feed hole and filled the turbo with oil on the drain side. i wanted to let oil sit on the bearings and lubricate them since it had been sitting. anyway i had the turbo laying on the compressor outlet so it was at a slight downward angle. anyway today i noticed oil had started running down the compressor outlet on the turbo. is this normal for oil to seep thought when its not on the car with no oil pressure?? or did i buy a NO good turbo
bump to keep it on the top
Last edited by 18psiWhiteMS3; 10-25-2009 at 04:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-25-2009, 06:57 PM   #2
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
to actually prime the turbo, you need to pull the fuel pump fuse and turn the car over several times. If it still leaks when you do this, then the sealz r bawd
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 10-27-2009, 06:40 PM   #3
18psiWhiteMS3
Lurkers
Posts: n/a
this is the email that ATP sent me in regards to my question??????????????
Hi Brian,
You'll be relieved to know that the leak described is exactly what the turbo is supposed to in the test described.
The seals don't work until they are in the car, shaft parallel to the ground and is rotating.
Hope that helps.
Thanks!
 Old 10-27-2009, 06:49 PM   #4
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
sounds like a closed thread
How To Increase The Volume of Back Up Warning Chime, How To Inflate Tires With Nitrogen, Replacing Oxygen Sensors, 1985 Haltech Automotive News 0 08-05-2009 11:00 AM
K04 Reworked Turbo Owners, Please Chime In... AutoXRacer MazdaSpeed 3/6 - Turbo Induction 73 09-04-2008 06:21 PM
Cat-less DP Owners, Please Chime In... AutoXRacer MazdaSpeed 3/6 - Turbo Induction 12 08-20-2008 03:56 PM
Page generated in 0.24530 seconds with 21 queries
