Mazdaspeed Forums
-   -   Turbo Inlet Hose/Pipe vacuum plug (http://www.mazdaspeedforum.org/forum/forum/f11/turbo-inlet-hose-pipe-vacuum-plug-211238/)
dbeckms3 05-24-2017 04:06 PM
1 Attachment(s)
The vacuum plug on the turbo inlet hose (goes from the TIH to the EBCS) broke. Attached is a picture of my solution. Brass fitting with clear hose and then drill a small hole where the old plug is and put the other end. Not sure how well it's going to do for disassembly if I have to do it again but for now it works okay.
Fstrnyou 05-24-2017 06:14 PM
Should be fine for now. If it leaks, you'll run a bit lean in vacuum and rich in boost.
MSMS3 05-25-2017 06:57 AM
Good tip. The "sensor" is actually the electronic boost control solenoid or EBCS. It's not a sensor, itself, but controls boost by opening and closing the vacuum ports based on a triggering signal from the ECU.
Omega 05-25-2017 07:44 AM
people will never learn to cut the hose off the plastic barb on the ebcs...
dbeckms3 05-26-2017 03:58 PM
Quote:
Thanks for the correction/information!
Tomumass06 09-26-2018 05:35 PM
I broke that piece as well. What did you use to keep the clear tube inplace? Silicone? Or am I interpreting this wrong? Either way, cool fix!
dbeckms3 10-02-2018 06:11 PM
Quote:
You know, I'm looking back at this and I can't for the life of me figure out what that clear hose is for... basically just get a brass fitting and stick it in the hole where the plastic plug was. I've since swapped in the Cobb TIH so I don't really have the issue anymore. Just checked the OEM TIH and it just has the brass fitting. I'll update to post to remove the clear tube.
Page generated in 0.17416 seconds with 11 queries
