 Old 09-25-2009, 07:19 PM   #1
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
Default Turbo Oil Return Line
Can you all look at the pictures attached? I changed my Exhaust Manifold today and had to unbolt this line. When I took it out, I was curious to know if the bent in the curb supposed to be there.
Can someone look and verify my pipe/line to make sure it is not bent?
Sorry for the crappy cell phone pics, the last pic is of my PG Manifold.
Thanks,
Cobb AP, 504whp 492wtq
 Old 09-25-2009, 08:18 PM   #2
awd>fwd
jwdp54's Avatar
Posts: 627   (View Stats)
jwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the worldjwdp54 is the leader of the world
Groans: 27
Groaned at 53 Times in 33 Posts
why did you take this off in the first place? installing any mani on this car should not require it to be removed.
MS3 310whp/320tq- SOLD finally(5/5/10)
evo 8-tuned to E85
jwdp54 is offline   Reply With Quote
 Old 09-25-2009, 08:23 PM   #3
I couldn't line up the top 4 manifold bolts and this line was holding the turbo. When I removed it, it freed up everything and the manifold slid in the bolts.
Does the line look ok?
 Old 09-25-2009, 08:45 PM   #4
awd>fwd
jwdp54's Avatar
Groans: 27
still a little confused.i know you have the v3 but i have the pg v2 and didn't have a single problem. everything lined up and install was easy. no matter what you shouldn't have had to remove that line.
i can't tell ya if that looks correct since it's dark out and i can't get under my car.
evo 8-tuned to E85
 Old 09-25-2009, 09:14 PM   #5
The head bolts lined up perfectly but it was the top 4 bolts that wouldn't line up. I removed the bracket that holds the back of the turbo to the block and it still didn't line up. We were pushing the turbo back so they would fall in but the line was not allowing it so I removed the line.
I know I have the version3 manifold but don't know why I was having such a hard time.
I will appreciate if you can look under car tomorrow,
thanks.
 Old 09-25-2009, 09:26 PM   #6
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Thanks,
I helped install a manifold and the turbo bent the line in that fasion, when flexing it trying to get mani on, we simply bent it str8, NO its not supposed to be like that, its gotta keep circle shape, and be carefully you dont flex too much to fast youll literally break it. its not an issue, stretch it back out and rebolt it. its a full stainless steel line, just be gentle with it.
The Following User Says Thank You to Nitr0EngiE For This Useful Post:
11cruzito11 (09-27-2009)
 Old 09-25-2009, 09:29 PM   #7
awd>fwd
jwdp54's Avatar
Groans: 27
only thing that might be different from my install and yours is the 4 bolts. did you take the studs off to install mani? i had three of the four studs come out from the turbo when trying to loosen the nuts.
install was much easier since i just had to slip the mani onto the head. i then double nutted the studs onto the turbo flange side. everything lined up and i had no problems.
hey what mani did you install that you had that problem?
evo 8-tuned to E85
Last edited by jwdp54; 09-25-2009 at 09:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-25-2009, 09:45 PM   #8
So my line did bent? So should I take it off and stretch it back out?
What would happen if I run the car with that line bent?
 Old 09-25-2009, 09:57 PM   #9
Daily Driver
Nitr0EngiE's Avatar
First off It was not a problem with the manifold, nor did this guy have issue with manifold, its just hard to get it over the 20 bolts with turbo where it sits, and we had to push turbo down a lil to get it on, and we unbolted turbo from bracket. moved turbo, flexed oil line some, got the mani on, flexed it back and rebolted everything.
Just realize for a second how long the studs on turbo and the exauhst heads are, its impossible to get it in there without moving turbo, And if u did it without unoblting turbo .... then I guess youe a god ?
Your line is way more bent then what we had it, but we noticed it was bending in our efforts to install the manifold. so we jsut watched it close and tried not to make it worse..
I would carfully stretch it out to reduce that bend for it causes restricition which may aid our smoking turbo issues, I would fix it
the one i installed was a DNP manifold, we also did full cpe turbo back on his car, and same time we installed cpe dp on my car.
 Old 09-25-2009, 10:00 PM   #10
First off It was not a problem with the manifold, nor did this guy have issue with manifold, its just hard to get it over the 20 bolts with turbo where it sits, and he had to push turbo down a lil to get it on, and we unbolted turbo from bracket. moved turbo, flexed oil line some, got the mani on, flexed it back and rebolted everything.
Thanks man, I will try to fix it tomorrow. but if i can't fix it, do you know if I can purchase this line? Where ?
 Old 09-26-2009, 02:30 AM   #11
Daily Driver
Nitr0EngiE's Avatar
Call mark at Street unit (check my signature, their phone was having issues today), he will help you with that, also I would post int he for sale section "WTB STOCK OIL RETURN LINE FOR STOCK TURBO" Guarantee someone has it for sale, I have one but not willing to get rid of my stock parts incase of zoom zoom boom, ill need stock parts to get new block
ALso the mani i helped with all studs stayed in turbo, and prolly so did this guys thats why we had to move turbo.
 Old 09-27-2009, 09:34 AM   #12
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Just remove the turbo studs, then you don't have that problem.
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to SLS MS3 For This Useful Post:
jwdp54 (09-27-2009), Nitr0EngiE (09-27-2009)
 Old 09-27-2009, 01:10 PM   #13
ROFL @ guy who did mani with all turbo studs still in.
jwdp54 (09-27-2009)
 Old 09-27-2009, 05:14 PM   #14
ROFL ????
 Old 09-27-2009, 05:20 PM   #15
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
god how did i miss this. no your oil return line should not look like that.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 09-27-2009, 06:54 PM   #16
darksun, by any chance do you have a spare one that you are willing to sell? or can you find someone that has one?
Thanks.
 Old 09-27-2009, 07:20 PM   #17
Fux Wit It
Darksun280's Avatar
Groans: 175
Thanks.
nah i only have a spare thats that bottom half. this is one of those instances where you suck it up and order an oem part.
 Old 09-27-2009, 07:31 PM   #18
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
i bought a new one of those lines.
it was like 100 bucks with gaskets or w/e and bolts.
you can buy it from the dealer but they might ask for vin and void warranty.
search the web for it or call mark at SU he`ll hook that shit up or tell you where.
2008 STi
Intake
Turboback
AP
 Old 09-27-2009, 08:28 PM   #19
Thanks dane,
I already PM'ed Mark and will also call him in the morning.
 Old 09-27-2009, 08:35 PM   #20
Fux Wit It
Darksun280's Avatar
Groans: 175
They were asking questions when I bought 175 dollars in stock bolts. I told them it was too late I was voided over a year ago. Can't kill me twice....
The Following User Says Thank You to Darksun280 For This Useful Post:
danesti (09-27-2009)
 Old 09-27-2009, 08:36 PM   #21
danesti's Avatar
Groans: 137
hahaha fuck their couches.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
Darksun280 (09-27-2009)
 Old 09-27-2009, 09:15 PM   #22
Yeah I know, I am going to ask Mark from SU for a price tomorrow.
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
BMW, M-B: Return to 4-bangers in U.S.? Haltech Automotive News 0 04-27-2009 08:30 AM
Camaro Z/28 to return? Haltech Automotive News 0 02-17-2009 10:40 AM
Page generated in 0.42333 seconds with 27 queries
