 Old 12-12-2016, 12:17 PM   #1
PrinceCaspian42's Avatar
Posts: 120   (View Stats)
PrinceCaspian42 will become famous soon enoughPrinceCaspian42 will become famous soon enough
Groaned at 3 Times in 1 Post
Default Turbo questions
Hey guys so ive decided to get a winter beater and park the speed so i can collect parts for a new turbo build. currently have the stock k04 with catless DP, TMIC and JBR powerpath Stage2 intake HPFP freektuned. car pulls great but since i need to replace the k04 i might as well go for more power. i plan on getting cx racing piping and a tr8 core. also i want to only run 93 oct no meth and theres no e85 near me so thats out of the question. so basically im debating between the BNR S3 and S4, i know most people say just get the s4 but heres the thing, i dont want to build my engine, i want to stay within the limits of the stock block. goals being around 350whp, so what my question is: should i try and max out an s3 or get an s4 and have it conservatively tuned. also is there anything else i should look at getting for these power numbers besides the obvious ebcs and 3.5bar and 3.5in intake? thank you for any input.
94 Miata M-Edition
Bilstein shocks w/ground control coilovers
front and rear swaybars
07 MS3 GT Cosmic Blue (SOLD)
JBR SRI/TIP
Autotech HPFP
CNT Catless DP
Damond RMM
Prosport Boost Gauge
Cobb AP V3
CPE TMIC
FreekTuned
PrinceCaspian42 is offline   Reply With Quote
 Old 12-12-2016, 12:23 PM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Well you won't likely make 350 whp on a BNR S3. As far as I know, they're only good for about 330 on pump alone. I don't know the spool characteristics of a S4 but I'd probably go S4. Goals may change later and you'll have the turbo to do it.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
WetzMS3 (12-12-2016)
 Old 12-12-2016, 12:24 PM   #3
xorphanx's Avatar
Posts: 386   (View Stats)
xorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond reputexorphanx has a reputation beyond repute
CS turbo
2013 MS3 Velocity Red with Techpackage
xorphanx is offline   Reply With Quote
 Old 12-12-2016, 12:31 PM   #4
Originally Posted by xorphanx View Post
CS turbo
i dont want a CS turbo because of their boost creep issues.
yeah thats probably what i will go for, mainly wanted to see if the s3 would be better to preserve the stock block.
94 Miata M-Edition
JBR SRI/TIP
Autotech HPFP
CNT Catless DP
Damond RMM
Cobb AP V3
CPE TMIC
FreekTuned
Last edited by PrinceCaspian42; 12-12-2016 at 12:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-12-2016, 12:39 PM   #5
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Get yer tune right. That's gonna be what preserves the block. lol
Typically speaking you want less lower end torque, so the s4 will probably push torque further out than an s3. With that said, you may still end up with ring issues down the road from a more aggressive setup as it is.
Trouble comes with the turf of modding. Don't want problems, don't create them.
Rich Tuned
330WHP and 363TQ
 Old 12-12-2016, 12:40 PM   #6
xorphanx's Avatar
difference between the s3 and s4 is ~150$... is 150 really breaking your bank?
 Old 12-12-2016, 12:45 PM   #7
as far as the tune goes i would either stay with freektune or since im 2 hours away try and get dynoed by nishan.
no the cost difference between the two turbos isnt what im worried about, more or so the cost and aggravation of rebuilding the motor
94 Miata M-Edition
JBR SRI/TIP
Autotech HPFP
CNT Catless DP
Damond RMM
Cobb AP V3
CPE TMIC
FreekTuned
Last edited by PrinceCaspian42; 12-12-2016 at 12:45 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-12-2016, 12:45 PM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I was referring more to the structure of your tune. Not who did it.
Rich Tuned
330WHP and 363TQ
 Old 12-12-2016, 12:49 PM   #9
ahh gotchya
94 Miata M-Edition
JBR SRI/TIP
Autotech HPFP
CNT Catless DP
Damond RMM
Cobb AP V3
CPE TMIC
FreekTuned
 Old 12-12-2016, 01:13 PM   #10
S4 is the best even for an stock motor.
All it goes down to us the tune.
That'll save or break your motor.
Sent from my Pixel XL
 Old 12-12-2016, 02:19 PM   #11
sounds like ill be getting an S4 then. BTW im super jelly you have the Pixel XL
94 Miata M-Edition
JBR SRI/TIP
Autotech HPFP
CNT Catless DP
Damond RMM
Cobb AP V3
CPE TMIC
FreekTuned
 Old 12-12-2016, 07:29 PM   #12
TheSixthSpeed's Avatar
Posts: 131   (View Stats)
TheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to behold
Just out of curiosity, If one were to run 23psi on the S4, would the torque be too much for the stock motor?
Well I saw a video of an S4 running 24psi on an Mazadspeed 3 and the guy was putting down more than 400 wheel torque. So I assume the engine is build and forged unless it's not and is on the verge of throwing a rod?
TheSixthSpeed is offline   Reply With Quote
 Old 12-12-2016, 07:34 PM   #13
Like i said earlier, your tuner can tone down the torque for your stock motor.
380-400TQ is basically the border for the stock motor. Having meth/E85 would help it last longer.
 Old 12-12-2016, 09:18 PM   #14
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
^this^
That's the thing with tuning, you can turn it up, turn it down, move it up or down the rpm range, etc. My peak load isn't targeted until 3500 with the K04 in an effort to reduce low end torque. I don't need a crap load of torque below that when putting around town. 4000+ is where I run hard...relatively speaking considering my car is stock. You could have a GTX3582R and keep it under 300ftlbs if it was tuned to do that.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 12-13-2016, 04:18 AM   #15
^this^
Oh, ok. Well I guess that means lowering the ignition timing or rich AFR I guess, but most obviously is less boost where you don't want it like down low.
I self tune and I currently have my K04 set up to 22psi at 3000 - 4000 RPM and then 18psi till 5,500 and above that the throttle is open till redline but running like 11psi. Everything below 3,000 is stock. Only reason I run more psi down low is because my stock intercooler is limiting me in the middle. I'm backordered on CP-E TMIC. I'm also set up 12.5 AFR and an ignition timing table I got from this forum where I compared the ethanol ignition maps and set up the minimum with the lowest map setting and then setup the max with the highest map setting.
What I guess I'll do is set 3,000 to 20psi then at 4000 RPM I'm hoping to run 24psi(or a bit more if possible). I'm running methanol injection of course.
BIG TURBO Questions! EdgeAutosport.com EdgeAutosport.com 483 08-21-2016 11:00 PM
New VVT/turbo questions. gjkissel MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 01-30-2016 12:45 PM
Turbo xs dp/rp and hks cbe questions MS3KO MazdaSpeed 3 - How-To's 3 01-01-2010 10:51 PM
turbo questions richie b 74 Mazdaspeed3/6 General Discussion 12 06-08-2009 06:55 PM
Page generated in 0.36260 seconds with 25 queries
