![]() Join Date: Mar 2008
(Thread Starter) | Not Ranked : 0 score 2007 Speed3, 140K miles. Car was running fine down the highway, at 70MPH upshifted to leave an ass tailgating me. When I hit the throttle I hear a "pop" then absolutely no boost. I thought I blew the motor. However, the car runs but I never get any positive boost. At wot the best I could get was -2psi and I here a much much deeper whine now. No CEL's, car runs like a non-turbo car up to 3K rpm. Fuels pressures are okay, idles okay, drives slowly okay. My suspect is the turbo has quit on me. Took off the TIC and I did not see anything, I have yet to try to spin the turbo blades, that is next as soon as I get time. I am thinking the blades won't spin.
__________________ 07 Cosmic Blue Speed 3, BNR S2 Turbo Cobb AP BEGI SRI CNT Catted Downpipe Forge BOV CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter Fidanza Aluminum Flywheel CPE Xflex Stage 2 Driver Side MM CPE Xflex Stafge 2 Rear MM AWR Passenger Mount 88 Duro Power Slot Rotors |
![]() Join Date: May 2013 Location: Santa Cruz, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score How loud was the pop? The 1st thing I'd do is check all the hoses and clamps. Use soap and water, sometimes a crack in a hose will be invisible until it's under pressure.
__________________ '93 RX-7: 100% CARB approved. Just some wheels and stuff. ![]() '03.5 Mazdaspeed Protege: Custom clunk and turkey call. '12 4Runner Limited: Hollister Hills pinstripes, dog hair, beach sand, melted surf wax, a few french fries under the seat... |
| The Following User Says Thank You to Natey For This Useful Post: | Vansquish (01-16-2015) |
(Thread Starter) | Not Ranked : 0 score Pop was very quick, like firecracker pop. All boost tubes are fairly new Corksport silicone tubes, they look okay. When I removed the BOV it was shut. I thought maybe it blew and got stuck open but I am not that lucky. Pop was just loud enough to hear in car. Not super loud.
__________________ 07 Cosmic Blue Speed 3, BNR S2 Turbo Cobb AP BEGI SRI CNT Catted Downpipe Forge BOV CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter Fidanza Aluminum Flywheel CPE Xflex Stage 2 Driver Side MM CPE Xflex Stafge 2 Rear MM AWR Passenger Mount 88 Duro Power Slot Rotors Last edited by Rcimp; 01-11-2015 at 03:58 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Dec 2008 Location: FLORIDA
Rep Power: 1419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,235
| Not Ranked : 0 score How do your AFR's look? I'm hoping it's an easy fix for ya. Good luck.
__________________ 2008 Mazdaspeed3 GT GTX2867r ![]() |
(Thread Starter) | Not Ranked : 0 score Funny thing is AFR's look okay. All the engine parameters, AFR, Fuel Pressure, temperature, etc all looks okay. They care runs fine as long as I don't try to nail it. It just does not get any boost. It literally is just a regular 3 now. The cheapest way to fix it is just change the emblems on the car from Speed3 to 3 lol.
![]() Join Date: Jul 2010 Location: Las Vegas, NV
Rep Power: 523 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,061
| Not Ranked : 0 score Check the lines from the waste gate. Might have cracked a hose. Ask me how I know
__________________ 2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD 2016 CX-5 GT AWD |
![]() Join Date: Dec 2011 Location: Hampton Roads, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,415
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score I was gonna say check the coupler on the throttle body. Same thing happened to me and that was the problem.
__________________ 2012 Mazdaspeed3 Black Mica Cobb AP // Stratified S-OTS+ Stage 2 Tune // Autotech Internals // CorkSport 3" Intake // CX Racing FMIC // NGK Iridium One Step Colder Plugs // JBR Throttle Body Gasket Kit & Coolant Bypass // SURE Return (w/ Dremel mod) // GFB Respons BOV // UR V2 Metal Catted DP // SURE Flow M3 // UR Catback Exhaust // StopTech Front Slotted Rotors + Performance Brake Pads // TWM Phantom Shift Knob // TWM Leather Shift Boot // CorkSport Adjustable Shortshifter // SURE Anchors // Tanabe NF210 Springs // JBR Tru-Torsion.125 Rear Sway Bar // Tanabe Sustec Tower Strut Bar // Tanabe Sustec Front Under Brace // JBR 88a RMM // Rally Armor Mudflaps // CorkSport Hood Scoop // CorkSport Battery Box // CorkSport LED Light Kit // CorkSport LED Fogs // GTA Car Kits iPod Adapter // Weathertech Floor Mats // Motorcraft Unicorn Tranny Juice // Pentosin Super DOT 4 Brake Fluid // Purple Effect Stock Rims // Falken Ziex ZE 329 // Plastidip'd Fog Light Bezels Waiting for install: StopTech Rear Slotted Rotors + Performance Brake Pads, StopTech SS Brake Lines ![]() Soon: Custom Tune by Stratified // Guardian Angel // BT, CorkSport Puppy or BNRs3??? |
(Thread Starter) | Not Ranked : 0 score When you say coupler are you talking about the inter cooler tube that goes to the throttle body? I am waiting for it to warm up a little before I go out and start looking at this stuff. I am also going to check the diaphragm on the waste gate. I think if I can put a tube on it and apply vacuum it should hold. If it doesn't maybe that was the pop I heard?
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | chaser27 (01-13-2015) |
| Not Ranked : 0 score The silicone connecting the intercooler cold pipe to the throttle body. It may have just blown off.
(Thread Starter) | Not Ranked : 0 score It was connected, I have removed the intercooler looking for simple stuff like cracked tubes or tubes that blew off. All of those looked okay and were attached. My next step is to jack the car up and check the wastegate and lines to the wastegate, and then try to see if i can spin the turbo blades. So is the wastegate open or closed by default? If it is closed by defalt and opens with pressure then I don't need to check it because I have no boost pressure at all. If it is open by default and closes with pressure then it is suspect. I would expect it to be closed by default so boost pressure can build.
__________________ 07 Cosmic Blue Speed 3, BNR S2 Turbo Cobb AP BEGI SRI CNT Catted Downpipe Forge BOV CorkSport Turbo Inlet Pipe / Silicone BPH / Boost Tubes / Dry Flow Air Filter Fidanza Aluminum Flywheel CPE Xflex Stage 2 Driver Side MM CPE Xflex Stafge 2 Rear MM AWR Passenger Mount 88 Duro Power Slot Rotors Last edited by Rcimp; 01-13-2015 at 12:10 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Sep 2013 Location: Seattle WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score yeah closed by default. i dont think that's the issue either but i know jack. due to your mileage i too would guess with some kind of hose, it may just have a crack that is hard to see.
__________________ 2007 Mazdaspeed 6 GT 2003 Ford Ranger XLT |
(Thread Starter) | Not Ranked : 0 score Then it is safe to say the wastegate is probably not the issue here since I cannot build any boost at all. Any chance the wastgate can be stuck open, and can I tell without removing the turbo?
| Not Ranked : 0 score You can run a line to one port on the WGA and cap the other. Pressurize the line to ~10-15 psi and the arm should move. I doubt that is your issue but that is the way to rule it out.
| Not Ranked : 0 score i think the AP would show a WGDC then ?
(Thread Starter) | Not Ranked : 0 score So maybe the small line that pressurizes the wastegate blew off or is cracked? It is either something like that of the turbo shaft has fractured. I am trying to figure out what the pop was that I heard. I am hoping for the cracked / broken hose.
| Not Ranked : 0 score If the shaft snapped in that thing you would know lol. That would sound like a bag of metal marbles being tossed into an industrial fan.
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Vansquish (01-16-2015) |
(Thread Starter) | Not Ranked : 0 score Well that makes me feel a lot better, it's got to be a hose or diaphragm somewhere then.
| Not Ranked : 0 score I would also do a boost leak test rather than a visual test. Get a cap with a valve stem and pressurize everything from the TIP back.
(Thread Starter) | Not Ranked : 0 score Yes I already have a boost test kit that I made. I was planning on doing just that. Testing TIP to TB. I bet I will here exactly where the leak is. My old factory boost tubes were leaking (via small cracks) enough to limit my boost pressure to 13psi. After I installed the Corksport silicone boost tubes my boost has been steady at 17psi WOT. Until now lol.
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
| Not Ranked : 0 score Just get the soapy water. Sometimes you can't hear them but the bubbles are obvious when sprayed.
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score Bad news. I can see the input of the turbo and the shaft is bent when I rotate the blades and the blades look bent on the ends. Nothing rubs when I spin it but I cannot spin it very fast either. Currently in process of removing the turbo. Does the whole exhaust manifold have to come out or will the turbo squeeze out some other way?
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score This just keeps getting better. Look at the crack on the exhaust side of the turbo running towards the waste gate valve and goes all the way to the stud on the top right of the picture. What causes that? I am running a CNT free flowing CAT and downpipe.
![]() | | #26 | ![]() |
| Not Ranked : 0 score lol that reminds me of my subaru days, the infamous wastegate crack is too common on the wrx. i think it just happens. probably heat and bad luck.
![]() | | #27 | ![]() |
![]() Join Date: May 2012 Location: Newnan, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 902
| Not Ranked : 0 score 140k miles of heating up and cooling off is a lot of stress to the metal, if that's the stock turbo I'd say you got some damn good life out of it lol
__________________ 08 cwp ms3 |
![]() | | #28 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score Good news, your dreams of needing a reason to buy a BNR S3 have come true!
__________________ 2007 Mazdaspeed3 GT |
| The Following 2 Users Say Thank You to MD1032 For This Useful Post: | Code Monkey (01-16-2015), cyclist20 (01-23-2015) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can live with that. Just wanted to be sure I didn't have some other problem that might damage the new turbo.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score I was thinking if a direct bolt in from Works Turbo Charger. Here are the specs. No mods necessary. Any one have any experience with Works? WORK also offers a alternative replacement for your turbocharger that incorporates a Garrett GT25 CHRA installed into your compressor and turbine housings for a direct fit. The benifits include: •Improved seal quality, no smoke! •More robust bearing structure, more durable •Updated turbine and compressor wheels, better response and power •2 year warranty •Direct fitment, no modifications necessary •Price is $900.00 + return shipping •Core required, does not have to be rebuidable •Core deposit is $250.00, return your old turbo for credit •Fast turn around, same day shipping on in stock orders! •Stage 1 and Stage 2 performance upgrades available •MFS (billet) compressor wheel upgrades starting at $180.00 Does the BNR S3 require any additional tuning?
![]() | | #31 | ![]() |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Boostin'likeAboss (01-16-2015) |
![]() | | #32 | ![]() |
![]() Join Date: Jun 2009
I did not want a bigger turbo and went that route. Turn around time was just as advertized. The replacement unit with new stock CHRA is working great. I did not go with the Garrett. I figure I can get another 108k out of the turbo and will probably either sell the car eventually or have other issues before the replacement turbo goes. I posted another thread here on what happened to mine. Not nearly as dramatic (fractured compressor vane), but the engine sucked in the fractured part and seems unaffected. Lucky bastard I am. You too, considering the condition of the compressor vanes. They do all seem to still be on the wheel.
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Out with the old, in with the new, this weekend I hope. Not sure what to do with the extra vacuum line. My old one has two lines running to the WG diaphragm, the BNR only has one port on the WG diaphragm. Not sure how to hook the vacuum lines up.
| The Following User Says Thank You to Rcimp For This Useful Post: | Gr8Speed (01-24-2015) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Google the routing diagram. Not too complex. You tee the lines together.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score MSMS3, Works quoted me $585 plus the core since mine was cracked for a reworked K04. This did not include any of the upgrades. I figured spending an extra $300 for a turbo that was better flowing, better seals so no more smoke, was worth it. I also though about the longevity of the turbo vs a 140K mile car. But realistically, I like the car. If I blow the motor I will probably put in a new one, but built internally to handle higher boost. So far I have no plans on getting rid of my MS3, only making it faster.
| The Following User Says Thank You to Rcimp For This Useful Post: | MSMS3 (01-30-2015) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Your deal is better for your purposes. Let us know how the BNR works out. New tune there for sure. If this were not my daily driver and super reliability necessary, I might use this opportunity to do the same. One thing I observed about your photos: that crack on the exhaust side suggests that your tune may have been too aggressive. I could be wrong. There is the "Neuspeed" sticky in this section above. Those guys put on the market a K04 upgrade kit for VW's with a pretty aggressive tune. They found out that if you push the K04 too hard above 5,500 rpm, EGT's can exceed 1500 degrees F. and the turbos were failing. What happened was that the inconel treated shaft (only 5mm in diameter) softens and sags. when that EGT is exceeded. I don't know what AFR's were on those early Neuspeed tunes. I wonder if high EGT (high boost and higher AFR's in combo) might have cracked the exhaust side and also caused the shaft to sag. Just a guess. If so, this might be a lesson for others running the K04 on tunes that might be set with target boost a bit too high or with AFR's leaned out just a bit too much. But, in your case, now that you have the BNR it will be a non-issue in the future. I'm only guessing, as I don't know about your AP tune. My lowly Hypertech was consciously mapped by design to keep EGTs below 1500 F. with AFR's kept pig rich for cylinder cooling. While it probably leaves a little on the table, it is safe. I think my turbo just finally wore out at 108K on a mild tune that relies more on agressive timing and lower boost and rich AFRs. The Neuspeed report was one of the reasons I stuck with the Hypertech, that and knowing that I would not be going big turbo or running ethanol. Let us know how the BNR works out.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 01-30-2015 at 03:56 PM. |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Finished up the install today. Changed oil / filter, antifreeze, started right up, no leaks, lights, or groans. Warmed it up, took it out for test ride. I was gentle to let the turbo break in sort of. The car is sooooo much more responsive now. I am thoroughly impressed with this BNR S2 turbo. The car exhaust even sounds meaner if that is possible. I am going to drive it casually for a few days before I start romping on it. I can't wait, it going to be exciting.
![]() | | #38 | ![]() |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | MSMS3 (02-04-2015) |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score When I talked to Brian I asked for an S1 and he said he didn't have any and that he had S2's available. The receipt says "Mazda Speed 3/6 Stage 2 Turbocharger #3108 . If this really is a stage 2 it is by no means a turd. It is very responsive and boost comes on quick.
| The Following User Says Thank You to Rcimp For This Useful Post: | MSMS3 (02-04-2015) |
| Cracked turbo waste gate. | RiceBurn2.3T | CX-7 > Turbo Induction & ECU Tuning | 20 | 07-30-2012 12:25 PM |
| good and bad for running internal waste gate?? | mason | MazdaSpeed 3/6 - Turbo Induction | 6 | 01-19-2010 05:36 PM |
| waste gate duty ?? | jracer | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 12-05-2009 03:40 AM |
