Like Tree7Likes
 Old 06-11-2011, 03:45 PM   #1
Originally Posted by 802_Anthony View Post
Hmm.. I'm a bit worried now! I just installed a SRI the other day and I've noticed that when I let off the gas I hear that compressor surge sound!!!!!!!!!!!!!!!!! Could this have been happening with the stock air box and I just couldn't hear it??? What should I do? I have a TurboXS RFL bov, so perhaps I should experiment with the washers in it to see if the sound will go away? I'm thinking there are too many washers in it so it's not venting the compressed air early enough. Please some one help! Until I saw the video in this write up I figured my SRI was just wobbling and that was the noise I heard
On a good note, this is an amazing write up!
You are likely hearing the bpv sound, or bypass flutter, rather than compressor surge.
Opening up the intake with a sri allows the sound of the bpv to be more audible.
 Old 06-11-2011, 04:15 PM   #2
802_Anthony's Avatar
Posts: 43   (View Stats)
802_Anthony is on a distinguished road802_Anthony is on a distinguished road
I really appreciate this, and I'd like to say you're right.. But the RFL bov vents to atmosphere, and makes a very loud "PSHHHH" sound. The sound I'm hearing is much different than if it were the bov fluttering and letting air out. It would be more like a quick "PSH PSH PSH" sound than the "FLUB FLUB FLUB" that I'm hearing... That's just my thought, unless you can explain it better.
Thanks
EDIT: I did a short drive tonight and couldn't reproduce the sound. The air is MUCH colder tonight than it was yesterday so I don't know if that's a factor.
802_Anthony is offline   Reply With Quote
 Old 07-03-2011, 06:24 AM   #3
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
Thanks
As posted earlier you dont have a problem. Aftermarket intakes allow more sound both ways, if you follow what im saying. You can hear the turbo spool and the BOV operate. Enjoy the sound, its a good thing.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline   Reply With Quote
 Old 07-02-2011, 02:32 AM   #4
kolmi lota's Avatar
Posts: 4   (View Stats)
kolmi lota can only hope to improve
Groaned at 6 Times in 3 Posts
Its awsome. Really U nicely and elaborately discuss about mazda speed 3/6 turbo and attached the engine images. Thanks Demi for your nice sharing.I have mazda 1990 Mazda 929S Tranquil Blue Mica/Dark Grey two tone on Blue leather with wood grain style trim. I really enjoy with it.
West Chicago used auto
kolmi lota is offline   Reply With Quote
The Following User Says NO Thank You to kolmi lota For This Un-useful Post:
faeker (07-02-2011)
 Old 04-29-2012, 08:21 AM   #5
Mazda6kid's Avatar
Posts: 15   (View Stats)
Mazda6kid will become famous soon enoughMazda6kid will become famous soon enough
I'm new to this forum, and this write up really helped me understand a lot thank you
Mazda6kid is offline   Reply With Quote
 Old 10-24-2013, 01:10 PM   #6
LastOfThePrimes's Avatar
LastOfThePrimes has a spectacular aura aboutLastOfThePrimes has a spectacular aura about
Excellent write up! I know the last portion addressed this, but I wanna make sure I'm drawing the right conclusion.
Turbo timer NOT needed on the MS3 because it is water cooled correct? Are there any other benefits of a timer I may be overlooking?
Thanks again!
LastOfThePrimes is offline   Reply With Quote
 Old 10-25-2013, 11:59 AM   #7
Posts: 2,233   (View Stats)
It isn't just because water cooling but because it is water-cooled, it reduce the cool down time enough that most of us can reduce their use of the boost 1-2 minutes before destination and no cool down is needed. But if you do the few last miles under wot, IMO the water won't be enough to remove the heat and the chance for the trapped oil to burn inside the turbo CHRA is much more greater.
In manny case the use of a turbotimer is more to show off and let others know that you have a turbo than really needed in normal driving conditions. If the use you make call for a cool down delay, a remote car starter with a timer option is a wiser idea than just a turbo timer
LastOfThePrimes (10-25-2013)
 Old 10-25-2013, 09:35 PM   #8
Awesome! Ty for the additional detailed info. It's truly appreciated.
 Old 01-04-2015, 11:40 PM   #9
Demi's Avatar
Groans: 61
Sorry I havent kept this uptodated boys. I got an evo, and changed jobs and was in Affuckistan for the longest. Im going to try to stay on top of this and add to.
Should also be noted that only petroleum products COKE. Meaning break down into nasty shit. Runs synthetic and dont drag race into your garage and TTs are for show. Got a super hot running setup? Running old school oil? TT your brains out. Other than that, no. I still give mine rig a one two count before killing it though, just because im meticulous.
Last edited by Demi; 01-04-2015 at 11:40 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-07-2015, 10:38 AM   #10
Originally Posted by Demi View Post
TT your brains out.
I like that one!
i opened 3 blown k04 for fun and all where cooked around the exaust seal like this picture from the web:http://s321.photobucket.com/user/guh...03820.jpg.html
http://s321.photobucket.com/user/guh...03813.jpg.html
I had the impression it was because the trapped oil cooked right there after motor shut off. But i don't know if they were using cheap mineral oil or more used to stop right after a drag race...
I removed mine at 75-80k miles to put a GT28 and it wasn't cooked like that. Was it because of syntetic oil or because of my driving habbits...? i can't say but both made it good!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/turbos-begginers-guide-18309/
LB7: Need help troubleshooting - Duramax Diesels Forum This thread Refback 11-28-2013 09:28 PM
speed boost control - Mazda 3 Quebec This thread Refback 01-16-2013 08:46 AM
Turbo Beginner's Guide... - Mazda CX-7 This thread Refback 01-03-2009 02:34 AM
Fuel Pump Installation Guide 3/08 mrlilguy157 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 09-27-2012 08:49 PM
Cars That Matter mobile price guide Haltech Automotive News 0 08-08-2008 08:10 AM
BMW's Definitive Guide to owning The 'Ring Haltech Automotive News 0 04-18-2008 06:20 PM
NEED Corksport FMIC Install Guide ZoomMS3 MazdaSpeed 3/6 - Turbo Induction 1 04-14-2008 09:04 PM
Page generated in 0.36799 seconds with 26 queries
