![]() Join Date: Mar 2008 Location: Boone, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 241
(Thread Starter) | Not Ranked : 0 score I'm done installing my TXS FMIC- I started the car after checking over everything and I'm getting this weird noise around my power steering pump. Like Driver, I lost a good amount of power steering fluid during the swap of the power steering cooler. I filled it up with some Prestone power steering fluid and that was it... maybe air in the lines? IDK but it doesn't sound like it should. What could it be? How should I go about to fix it? I've still got the bumper off
__________________ -Derek No longer in the Mazdaspeed Family Last edited by Derek88; 04-03-2008 at 09:11 PM. |
(Thread Starter) | Not Ranked : 0 score Nvm. It was trapped air. Fixed it. Off for a test drive
__________________ -Derek No longer in the Mazdaspeed Family |
| Not Ranked : 0 score fixed it 15minutes. impressive! cool.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
| Banned ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
| Not Ranked : 0 score How was the test drive? |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Mine did the same thing. Took a minute to go away. You will love it. That fmic is a big bitch and fits excellent.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score what did you do to fix it? |
(Thread Starter) | Not Ranked : 0 score To fix it I took the cap off of the power steering reservoir and let it run- the air bubbles came to the top- I also added some more fluid. The fit was surprising. For as big as this thing is, everything lines up well- especially for not having instructions on the box and not many pictures to go from. The test drive however... it sounds a lot different- better. And it's more laggy. But honestly, it feels a tad slower than before. I will admit that I only drive it 10 miles, and I got on it 3-4 times, but I wasn't impressed. So the ECU may need to learn this or I may have a boost leak. I'm building a boost leak tester this afternoon- unfortunately, there is nothing that pops out at me that could make it leak. Or hell, this bigass FMIC may be overkill on my stock-ish car. OOOORRRR my stock BPV is trash. The way I look at it is like a street race. With the TMIC I had a torque jump against the other car- then it would steadily pull. With the FMIC I lost my jump due to lag but it isn't pulling hard enough to make up the difference. It looks badass though
| Not Ranked : 0 score We need to talk.... I got a proposal for you |
(Thread Starter) | Not Ranked : 0 score I'm all ears! BTW, if you still have one of your couplers from your old top mount, I'll make you a boost leak tester!
(Thread Starter) | Not Ranked : 0 score I have an appointment for the motor mount recall tmrw at 730- then boost leak test- then floggin' on her for a bit to see if the ECU learns it- maybe some pictures... who knows.
its cause its broke. I told you that your car felt different from mine.... quick response is gone... welcome to the world of high end power. now you need to turn up the boost for it to really help. then you'll see it on the top end | |
__________________ -Derek No longer in the Mazdaspeed Family | |
| Not Ranked : 0 score I know for a fact the car is faster with it. I raced someone before and after. 3 car difference with no other changes. Car does lose that bottom end hit your talking about though. I like it that way. Gets rid of tire spin.
| Not Ranked : 0 score what are you doing about the rub on the manifold? |
Groans: 70
| Not Ranked : 0 score does he have the mani? |
| Not Ranked : 0 score he does. thats why im curious. i have a feeling derek can be bought right now and i want to know if the ic can work with the mani. I know dereks girl... if I buy his birthday present, for full retail value. i got a feeling she'll let him pull the trigger....lol |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score hey your wanting a bigger core rite? can't u just buy a bigger core from a local performance shop and pull a switch?
__________________ |
| Banned ![]() Join Date: Mar 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score It may be possible you lost a pound or so of boost because if the extra piping.. do you have a boost gauge? I hope you do! I installed one 2 weeks after I bought my car. I stock a wide variety of gauges, they are a MUST for every turbo car! |
![]() Join Date: Mar 2008 Location: North America ;)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score I just put mine on as well and the car isn't any faster and I lost about 1-2psi. With my boost controller set to where I normally hit 17-18psi i'm only hitting 15-16psi which I was expecting. I did make a boost leak tester and I don't have any boost leaks. The welds around the bpv flange were leaking on mine so I had to get that fixed myself because of the poor customer service turboxs provided. They still haven't called me back or emailed me back....I only have a test pipe, intake and boost controller..so I figure the intercooler will really shine once I finish my exhaust and up the boost some more ![]() If anyone has the turbo smart boost controller with this intercooler how many clicks are you at?
__________________ 08 Cosmic Blue MS3 Autox pwns j00!!! |
| Not Ranked : 0 score I have no boost controller and I am at 16-17psi. I did see about a 1psi drop with it but pulls harder none the less.
| Not Ranked : 0 score I didn't notice much lag though....it still eats though the tires...lol. And I have to get rid of the stock bpv....That is where I think i'm loosing most of my boost
(Thread Starter) | Not Ranked : 0 score Oh boy. Lesson learned... I boost leak tested this thing. I built me a boost leak tester and hooked it up to the turbo inlet pipe right after the intake (I know now, that's a no-no). I turned down the air compressor to between 10-20psi and unplugged it just in case. I attached the hose to my tester and filled her up... no leaks... no leaks... POP! What was it? All my intercooler piping was intact. After some inspection, I see I blew my inlet pipe off at the turbo. I had to let the car cool before working on it, but I figured I could wiggle it back on without having to take anything off. I was wrong again. At least everything is good now and I know how to install a turbo inlet pipe if I need to. lol.
| Not Ranked : 0 score For fucking sure. Get the synapse bro, you wont regret it. Shit is sick. If not that get a turbosmart from john at ptp. If I didnt have this one id get that. Chris is running it with very good results.
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I may get a free 1st gen DSM bov to try out for a bit- then I'm going for the synapse. I do have a boost gauge, but I dont have it hooked up b/c I dont have a good enough place to mount it. I did do a baseline dashhawk datalog which shows boost...
![]() | | #25 | ![]() |
![]() So chris is running the turbosmart with good results...I was actually looking at that one a while back but now driver is have such good results with the synapse....decisions.... Overall I like the front mount though
__________________ 08 Cosmic Blue MS3 Autox pwns j00!!! | |
![]() | | #26 | ![]() |
Groans: 102
| Not Ranked : 0 score hmmm losing psi..losing low end?? still woth $450 more than ets 3.5???
![]() | | #27 | ![]() |
![]() Join Date: Mar 2008 Location: Kirkland, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groans: 87
| Not Ranked : 0 score I believe in the long run I will see much bigger gains from the FMIC as I plan on going modified K04. Not to mention the ETS units are on quadruple national backorder...thats a little extreme their IC stock for us sucks. Last edited by Death-From-A-Mile; 04-06-2008 at 09:47 PM. |
![]() | | #28 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| Not Ranked : 0 score yea i dont really see the point of a front mount....and i've had both. I held more boost with the top mount.... Oh well |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2008 Location: West Palm Beach, Fl
| Not Ranked : 0 score did your IAT readings change?
__________________ Ribs. I had ribs for lunch. That's why I'm doing this. sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Your IAT reading will not change seeings how your IAT sensor is with the MAF. The IAT is the air going into the turbo...
![]() | | #31 | ![]() |
| Not Ranked : 0 score sub |
![]() | | #32 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score If I'm not mistaken, the dashhawk and other type readers can pull the data off IAT2 which is charge temp. I don't have mine yet, so I can't verify, but someone was talking about it on 6club. |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
BAT - boosted air temp read off the MAP sensor located on the intake manifold | |
![]() | | #34 | ![]() |
| Not Ranked : 0 score I think that would be something pretty important when analyzing the effectiveness of an intercooler.
![]() | | #35 | ![]() |
Groans: 57
| Not Ranked : 0 score the problem is that the msd changes versions liek i change my underwear and it never reads the same. My boost temps with the tmic were taken wiht a different version, the new version drops them about 100 degrees lol |
![]() | | #36 | ![]() |
| Not Ranked : 0 score I thought OBDII was a standard. The readings shouldn't change because of the software version should they? It'd still reading data from the ECU...
![]() | | #37 | ![]() |
Groans: 57
| Not Ranked : 0 score they have to convert that data into something that makes sense to them.... My boost temps dropped over 100 degrees ont he same day from switching versions |
![]() | | #38 | ![]() |
| Not Ranked : 0 score If this was hondatech, there would be a whole thread about increasing your intercooler efficiency by upgrading your dashhawk version. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score oh I didn't know that you tested twice on the same day. that's weird. seems like a signal should be the same always.
![]() | | #40 | ![]() |
| if you are going to go with any turbo upgrade, a FMIC will reap you better power down the road. If you have a ETS or you are on the fence about it, just buy one, believe me, someone will always take it off your hands down the road.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/turboxs-intercooler-impressions-2066/ | ||||
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 04-02-2008 07:12 PM | |
| Cobb Springs-Impressions | MidwestSpeed3 | MazdaSpeed 3/6 - Suspension & Brakes | 39 | 07-05-2010 01:16 PM |
| How-To: Install Cobb Springs + Impressions. | Sacrilicious | MazdaSpeed 3 - How-To's | 24 | 05-25-2010 02:14 AM |
| Intercooler Article On Sizing/Design/Implementation | Crossbow | MazdaSpeed 3/6 - Turbo Induction | 51 | 12-23-2009 04:17 PM |
| Turboxs FMIC trouble. | Davidb | MazdaSpeed 3/6 - Turbo Induction | 4 | 04-03-2008 10:03 AM |
