Like Tree10Likes
 Old 02-06-2014, 03:03 PM   #1
Outlaw4shrt's Avatar
Posts: 751   (View Stats)
Outlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the worldOutlaw4shrt is the leader of the world
Do you have an idea for pricing and when your T4 manifolds will be available?
2006 TGM MS6
Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's
2008 MazdaSpeed 3 - R.I.P. 1/3/13
- from ENM 2014
well actually, if you count the number of holes you'll see we have just enough
Outlaw4shrt is offline   Reply With Quote
My twin scroll BW s300sx 88-75 BT build djuosnteisn MazdaSpeed 3/6 - Big Turbo Builds 2409 08-31-2013 04:10 PM
Is Twin scroll K04 swap from Cobalt/HHR SS possible? Stormtrooper6 MazdaSpeed 3/6 - Turbo Induction 8 04-30-2012 12:23 PM
removing twin scroll divider turd burglar MazdaSpeed 3/6 - Turbo Induction 11 05-12-2010 11:06 PM
Twin-Scroll K04?!?!? Mfinlay04 Mazdaspeed3/6 General Discussion 37 05-27-2009 06:28 PM
Page generated in 0.27054 seconds with 21 queries
