![]() Join Date: Mar 2010
Rep Power: 227 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score I have a good seal on the shroud, there's a nice dark black line all the way around the shroud where the rubber meets it... so I don't think it's that. Is there anything else you could think of that would cause me to be seeing 140 after cruising on the highway and then doing a 4 th gear pull on a 65 degree day? The only thing I can think of is I currently don't have that plastic shroud under neath the engine installed, didn't know if that would help create a vacuum and force more air through the intercooler? Here's a pic...
__________________ 2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV |
| Not Ranked : 0 score Do you still have the weatherstripping near the windshield cowl? |
![]() Join Date: May 2012 Location: Ontario
| Not Ranked : 0 score Because TMIC... just the nature of the beast. You either go TMIC with meth injection to keep BATs down or FMIC with optional meth injection for an upgraded turbo. I think you are just producing a crap load of heat (from the BNR) and the intercooler is in the perfect spot to soak it all up. |
(Thread Starter) | Not Ranked : 0 score YUP! I haven't touched anything else on the car...
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score Do a coolant bypass, it should help a bit. But if you live somewhere that gets cold, remember to put the hose back on for winter. I have a log I can post up of the difference later today. But, I also have meth lol. Meth is pretty damn awesome, I suggest everyone do it lol. I was crusimg at 138f on the freeway. Got off and was at 170. Meth hit and I was at 80 in a matter of a second. This was in 110f weather earlier this week. I was cruising after doing the coolant bypass, and was at 100. then got off and idled at 115f. It was 90 outside then, but it for sure is helpful.I should add I did the coolant bypass because I noticed my BATs sky rocket recently lol.
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
| Not Ranked : 0 score Remove the weatherstripping closest to the windshield and you'll drop 10-15*'s off of bat's. If you note your iat vs bat now, vs. after doing so, you'll have evidence it does indeed work. MS6 High Bats Last edited by rfinkle2; 09-20-2013 at 01:05 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | mr.speedy3 (09-20-2013), warlord (09-20-2013) |
I might want to try this out for fun next summer. It's colder in canada now so my bats don't get high this time of year. | |
Every ms6 I've seen with bat problems has benefited and I've never heard of any detriments. Also on gen2 here: (courtesy of djuosnteisn. LOL) How To: Engine Temps and Style Upgrade | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | LaraS (09-20-2013) |
![]() Join Date: Nov 2012 Location: Derry, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 148
Groaned at 44 Times in 10 Posts
| Not Ranked : 0 score The only downside is that sometimes my windshield gets fogged up in rain. I was worried about sucking in hot air into the AC, but it hasn't affected how cold the AC blows. Also, you can see a wave of heat coming out of the hood without it, so definitely dissipates heat. EDIT** You can also remove the rubber seam on the hood in the front. That will let a whole lot of air go through the enginebay and out the back if the cowl is removed as well. The downside may be that you'd be getting a lot more debris and water in there with the additional air.
__________________ 2009 Nissan 370Z. Turbo and BOV sounds made by the driver via mouth. SOLD: 2011 Speed3. Black mica w/tech package Cobb SRI, COBB AP, AT internals, OBX racepipe, Corksport RMM, LOUDASS STRAIGHTPIPE CPE TIP Last edited by usgiorgi; 09-20-2013 at 01:30 PM. |
| The Following User Says Thank You to usgiorgi For This Useful Post: | rfinkle2 (09-20-2013) |
| Not Ranked : 0 score If you are cruising down the highway on a 65F day and are seeing 140F BATs cruising, that is very strange. I have a SU TMIC and on a 65F day cruising down the highway staying mostly off the boost (<5psi), my BATs will be 95-100F consistently. On a 65F day with the K04 during a 4th gear WOT run, I would usually see the BATs drop to maybe 85F before getting up to 115F or so after a WOT run. Is the cold air ducting in the hood still there? You sure the ducting isn't blocked? Was the car heat soaked badly before you got on the freeway to start with? Maybe post a log up and we can see if there is something obvious, though its likely Lex would have already reported on something odd.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
| The Following 2 Users Say Thank You to dale_gribble For This Useful Post: | rfinkle2 (09-20-2013), TiGraySpeed6 (09-20-2013) |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
| Not Ranked : 0 score My fmic gets me bats that are 20-30 degrees above ambient by the end of a pull... Time to go fmic or meth.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
![]() Join Date: May 2013 Location: Aliso viejo CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 99
Treadstone FTW !!! But seriously fmic is the way to go.
__________________ 2012 BLACK MS3 (SOLD) -Cobb AP -CP-E stg 2 RMM -JBR Rear sway bar -K&N SRI -UR TP -AT Internals -JBR TIP -CX Racing fmic piping -TR8L core --------------------------------------------- 2008 WHITE EVO X -UR TP -UR Cat Back Single exit -Eibach springs -UR UICP -TurboSmart dual port set fully recirculated -Injen intake -3 port ...need moar money ! 1995 Miata M Edition - DD -The gay mobile | |
| The Following User Says Thank You to Dead Ms3 For This Useful Post: | Camwilson (12-18-2018) |
| FMIC HIGH BATS | tokoam | MazdaSpeed 3/6 - Turbo Induction | 21 | 10-02-2013 09:27 PM |
| MS6 High Bats | snailD | MazdaSpeed 3/6 - Turbo Induction | 35 | 07-06-2012 12:38 PM |
| FMIC install but still high BATS | KRheeder | MazdaSpeed 3/6 - Turbo Induction | 61 | 07-06-2012 12:33 PM |
| Car withstands unusually hot ignition timing on 93 pump gas | fortressofcomfort | 2010 MS3 - ECU Computer Tuning | 52 | 06-02-2012 12:12 AM |
| My BATs.....High? | MS6FL | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 02-28-2012 10:15 PM |
