 Old 10-14-2009, 08:58 AM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default Vaccume line routing EWG for BT
for the gt3076 i plan to use stock boost control but am going to use External wasteGate. i know i need to tap a seperate boost source since this turbo only has one vs stock with 2. Other then copying the same vaccume routing is a restrictor pill needed in this application??
 Old 10-14-2009, 09:55 AM   #2
brian talk to me on AIM cause i have it setup using the stock solenoid and i know the correct routing
 Old 10-14-2009, 10:26 AM   #3
Deadman's Avatar
Posts: 868   (View Stats)
Deadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the worldDeadman is the leader of the world
Groaned at 31 Times in 16 Posts
Anthony bring that bitch up here ! Dyno @ switzer when you get here
Deadman is offline   Reply With Quote
 Old 12-12-2009, 11:28 PM   #4
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
Not to bring up an old thread but super how did you set this up? I got the GT35 on, but it is only running wastegate spring pressure. How do wire up the stock boost control solenoid?
kore2000 is offline   Reply With Quote
 Old 12-13-2009, 12:07 AM   #5
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
I would also like this info!
Cobb AP, 504whp 492wtq
 Old 12-13-2009, 09:14 AM   #6
18psiWhiteMS3
Lurkers
Posts: n/a
i ended up running straight waste gate pressure. boost goes right up to 20 and stays pegged there. its perfect. but i have a tial 38mm wg with a spring strong enough to do that and i wanted a 20psi tune so its much more consistent and steady then any EBCS
 Old 12-23-2009, 03:55 PM   #7
cageyvet's Avatar
Posts: 715   (View Stats)
are you going to switch to an ebc
 Old 02-22-2010, 06:46 PM   #8
stitchyad's Avatar
Posts: 59   (View Stats)
stitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud ofstitchyad has much to be proud of
How did you get it done? I am trying to do the same thing with my MS3 same turbo and wastegate.
xPRHCx
stitchyad is offline   Reply With Quote
 Old 02-22-2010, 06:48 PM   #9
18psiWhiteMS3
Lurkers
Posts: n/a
 Old 02-22-2010, 06:49 PM   #10
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
did you just copy/paste? hahah
and when i had my gt28 on i ran it straight off the WG spring.
2008 STi
Intake
Turboback
AP
 Old 02-22-2010, 06:51 PM   #11
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Default Re: Vaccume line routing EWG for BT
Lol at copy and paste of a previous post, in the same thread nonetheless!
 Old 02-22-2010, 06:51 PM   #12
18psiWhiteMS3
Lurkers
Posts: n/a
yea dame its really nice this way cause boost is always the same and consistent
 Old 02-23-2010, 03:23 PM   #13
stitchyad's Avatar
Where is the dern pressure source port on the GT3076r?
xPRHCx
 Old 02-23-2010, 03:25 PM   #14
danesti's Avatar
Groans: 137
if its not on the compressor housing already you may have to tap it yourself. picture would be worth 1,000 words.
2008 STi
Intake
Turboback
AP
 Old 02-23-2010, 03:25 PM   #15
18psiWhiteMS3
Lurkers
Posts: n/a
it doesnt have one. I tapped into the line going into the BPV. IT worked perfect
The Following User Says Thank You to For This Useful Post:
danesti (02-23-2010)
 Old 02-23-2010, 03:36 PM   #16
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
so you disconected the EBC totally?
 Old 02-23-2010, 03:41 PM   #17
18psiWhiteMS3
Lurkers
Posts: n/a
completely eliminated it. its only plugged in so i dont throw a CEL
 Old 02-23-2010, 03:43 PM   #18
danesti's Avatar
Groans: 137
i never threw a cel while not using mine.
2008 STi
Intake
Turboback
AP
 Old 02-23-2010, 03:45 PM   #19
18psiWhiteMS3
Lurkers
Posts: n/a
hmmm, interesting. grimmspeed told me i would if it wasn't plugged in. OH well
 Old 02-23-2010, 03:47 PM   #20
danesti's Avatar
Groans: 137
maybe im just made of epic magic so normal rules dont apply. maybe.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
bykeryder4life (02-23-2010)
 Old 02-23-2010, 10:18 PM   #21
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
ok, so is it ideal for an EWG to not use a bc? do i just get a tial mv-s with a 1 & .4 bar and call it a day?
i'm new to this bt thing.
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 02-23-2010, 10:46 PM   #22
stitchyad's Avatar
I talked to ATP and they are sending me a fitting that should've come with the kit, but it did not. That is supposed to fix that.
xPRHCx
 Old 02-23-2010, 10:59 PM   #23
stitchyad's Avatar
OK, now I that I know how everything is supposed to be hooked up. Do I have to remove the internal wastegate from the GT3076r, or it don't matter? Some dude from a speed shop around here told me that I had to, but it doesn't make sense to me. The dern thing is not going to be connected to any vacuum line or anything.
xPRHCx
 Old 02-23-2010, 11:28 PM   #24
tbot's Avatar
Groans: 40
U have to disable the iwg either by removing and blocking off the hole, or tack weld it shut.
Honestly bro, i think you need to start reading up a TON on how turbos work in every aspect. But, that's just my opinion. I realize your new to this, but google can answer MOST of the questions you've asked. Not trying to be a dick, but it will seriously help you in the long run.
 Old 02-23-2010, 11:33 PM   #25
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
you need to hold the internal gate shut somehow. This process is normally done by removing the wastegate actuator and using something to hold the wastegate flapper shut.
crap, tbot beat me to it
Murdered out 2007 speed3 GT with navi.
Last edited by mtnrunner; 02-23-2010 at 11:33 PM. Reason: MSF Database - Automerged Doublepost
mtnrunner is offline   Reply With Quote
 Old 02-23-2010, 11:55 PM   #26
danesti's Avatar
Groans: 137
i had a shop weld mine the actuator arm in the shut position. sealed it up perfectly and can easily be reversed if i ever decide to opt for IWG or sell the turbo.
an EBC would be more prime if you can get one to work easily enough.
the problem with only WG spring controlling boost is that you will only have one boost level, and sometimes slowly integrating the boost with rpm`s and having it taper down in the higher rpm`s can be safer for the car and actually faster too depending on boost levels.
2008 STi
Intake
Turboback
AP
 Old 02-24-2010, 12:28 AM   #27
mtnrunner's Avatar
another good thing about running a boost solenoid of the ecu is that it can pull boost when its not running right, ie knock. when running on a stand alone boost controller or just WG spring there is no way to cut boost at all.
 Old 02-24-2010, 07:58 AM   #28
18psiWhiteMS3
Lurkers
Posts: n/a
My IWG flapper is welded shut. Also I think if u get a good tune you don't need to worry about running just the spring pressure. But thats just My opinion. Works perfect on my car but then i never get any knock
 Old 02-24-2010, 01:45 PM   #29
stitchyad's Avatar
Thatis what i have been doing. i am reading a lot about the car, and force induction systems. I already set an appoiment up with a machine shop near by to disable the internal wastegate. I should be able to put everything on using the external wastegate after that is done, shouldn't I?
xPRHCx
 Old 02-24-2010, 02:22 PM   #30
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Just don't jump into everything without knowing what you're getting into. Don't wanna see you... Well you know...
2012 WRX HB w/mudflaps yo!
 Old 02-24-2010, 02:49 PM   #31
tbot's Avatar
Groans: 40
Yeah, if you have to be asking stuff like that, then you probably shouldn't be looking at getting it done. Or you should be just paying boo koo bucks to a shop and have them do everything for you.
 Old 02-24-2010, 03:05 PM   #32
stitchyad's Avatar
I guess that I have to weld were the red is in this pics:
I got that from some dude that is doing the same thing with his STi.
xPRHCx
Last edited by stitchyad; 02-24-2010 at 03:05 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-24-2010, 03:08 PM   #33
18psiWhiteMS3
Lurkers
Posts: n/a
yea man thats were u need to weld but the round flapper u really only need a short beat like 1/4 inch long.
 Old 02-24-2010, 03:09 PM   #34
danesti's Avatar
Groans: 137
you shouldnt have to weld the flapper itself if the actuator arm is done correctly. i didnt weld the flapper at all and i held perfect boost.
2008 STi
Intake
Turboback
AP
djuosnteisn (02-25-2010)
 Old 02-24-2010, 03:23 PM   #35
tbot's Avatar
Groans: 40
^^ to each his own. The best place to apply force on an "arm" is going to be the furthest away from its pivot point and at a 90 degree angle. With that said, the furthest point from any pivot point is going to be the flapper vs the actuator arm. Just some physics for ya
 Old 02-24-2010, 03:26 PM   #36
danesti's Avatar
Groans: 137
pretty common sense with the fulcrum theory there. not really necessary though is all im saying. a small tack that is easily reversible is all im advocating. no need to over due it and complicate things for when this guy blows his car up and sell his turbo to pay for a 98 corolla.
2008 STi
Intake
Turboback
AP
 Old 02-24-2010, 04:14 PM   #37
spnkr21's Avatar
Groans: 105
Rofl
 Old 02-24-2010, 06:54 PM   #38
stitchyad's Avatar
ill get it done as soon as I get my manifold and the dern wastegate. Ill be posting pictures of how the fother mucker takes shape.
xPRHCx
 Old 02-24-2010, 09:20 PM   #39
tbot's Avatar
Groans: 40
A small tack was all I was saying too, I was just saying a smaller tack would be needed on the flapper vs the arm, at least in theory.
And lol at the corola, but it might be true
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
MS6 EWG Dump Tube Routing superskaterxes Mazdaspeed3/6 General Discussion 29 04-16-2009 07:55 PM
CES 2009: Navigon takes routing personal Haltech Automotive News 0 01-10-2009 05:10 PM
3 Line Sig? badams118 Website Help/Feedback 2 12-02-2008 05:56 PM
New traffic re-routing system for navigation systems coming from Inrix Haltech Automotive News 0 05-21-2008 09:48 AM
Page generated in 0.51801 seconds with 31 queries
